Seven Segment Display Arduino Thermometer
https://www.electronics-lab.com/seven-segment-display-arduino-thermometer/
by Ardumotive_com @ instructables.com: Today I will show you how to make your own 7 segment – 2 digit – thermometer with Arduino uno and DS18B20 temperature sensor. I prefer to build my own arduino based circuit by using the ATmega328p uno possessor, but this is optional for you. You can also use breadboard to build […]
Inside the Intel RealSense Gesture Camera
https://www.electronics-lab.com/inside-the-intel-realsense-gesture-camera/
by Sinjin Dixon-Warren @ chipworks.com: The Intel® RealSense™ gesture camera represents another foray by Intel into the consumer products space. The camera has been incorporated into the Lenovo ThinkPad Yoga 15. Intel disclosed at IDF14 that the device is formed using three components: a conventional color CMOS image sensor camera, an infrared images sensor, an infrared […]
Even you switch ecologically?
https://www.electronics-lab.com/even-you-switch-ecologically/
More exactly, we talk about switching-off a device. Marquardt 1550 Eco Switch enables this extraordinarily easily. Do you know a situation, when a seemingly usual thing is fact not that usual… Whether it´s a car with a hybrid drive or a lot of devices which we meet every day – usually in every segment can […]
Making A SMD Reflow Oven
https://www.electronics-lab.com/making-a-smd-reflow-oven/
by packetbob @ instructables.com: I decided to put together a toaster oven and wanted something that could handle large boards and possibly do small production runs. Doing a web search, you will find many options for toaster oven reflow controllers. They range from one-off designs to DIY boards to full kits. A large number of them […]
Making PCBs with CNC
https://www.electronics-lab.com/making-pcbs-with-cnc/
Rui written an article on how to build your own PCBs using a CNC machine. Rui Cabral writes: The PCB manufacturing method i used before buying my CNC machine was the lithography method and worked as follows: First i printed the board design on an acetate sheet. This sheet was placed over a pcb with […]
Buck battery charger handles multiple chemistries
https://www.electronics-lab.com/buck-battery-charger-handles-multiple-chemistries/
by Susan Nordyk @ edn.com: The LTC4015 synchronous step-down battery charger controller from Linear Technology offers charge current of up to 20 A, multiple-chemistry operation, and onboard digital telemetry. The controller transfers power from a variety of input sources, such as wall adapters and solar panels, to a Li-Ion polymer, LiFePO4, or lead-acid battery stack with […]
Simple circuit lets you characterize JFETs
https://www.electronics-lab.com/simple-circuit-lets-you-characterize-jfets/
by John Fattaruso @ edn.com: When working with discrete JFETs, designers may need to accommodate a large variation in device parameters for a given transistor type. A square-law equation is usually used as an approximate model for the drain-current characteristic of the JFET: ID=β(VGS−VP)2, where ID is the drain current, VGS is the gate-to-source voltage, β […]
2.5A BIPOLAR STEPPER MOTOR DRIVER LV8772E
https://www.electronics-lab.com/2-5a-bipolar-stepper-motor-driver-lv8772e/
Tiny Board has been designed around LV8772 IC from On-Semi. This driver is capable of micro-step drive and supports 4W 1-2 phase excitation. It has Low on Resistance with motor current selectable in four steps. The board is equipped with unusual condition warning LED and input Pulse Monitor LED. It is most suitable for the […]
LCD Adapter Board
https://www.electronics-lab.com/lcd-adapter-board/
Simple LCD adapter board offers an easy way to interface a standard 16X2 LCD to your project. Specifications Very Tiny PTH PCB Onboard Preset to set the Contrast Easy interface with 10 PIN Box Header Connector LCD Adapter Board – [Link]
IO expander board
https://www.electronics-lab.com/io-expander-board/
I/O Expander Board offers a convenient way to interface upto 16 I/O pins in your project using SPI/I2C bus.  This kit uses the famous MCP23S17 IO chip from Microhip. Specifications Supply sourced through the interfacing Box Header connector The kit has 2 separate Box Header type connector for the 16 pins of I/O port and […]
