Machine learning inference for embedded applications reference design
https://www.electronics-lab.com/machine-learning-inference-embedded-applications-reference-design/
This reference design demonstrates how to use TI Deep Learning (TIDL)/Machine Learning on a Sitara AM57x System-on-Chip (SoC) to bring deep learning inference to an embedded application. This design shows how to run deep learning inference on either C66x DSP cores (available in all AM57x SoCs) and Embedded Vision Engine (EVE) subsystems, which are treated […]
Get AI Solutions from AAEON powered by Intel Myriad X
https://www.electronics-lab.com/get-ai-solutions-aaeon-powered-intel-myriad-x/
AAEON, an award winning leader in AI@Edge solutions, presents its AI platforms powered by Intel Movidius Myriad X. As the first company to produce an mPCIe module to feature the Intel Myriad X VPU, AAEON is continuing to lead the industry in offering powerful, flexible AI platforms with Intel solutions. At the heart of AAEON […]
Digilent’s Analog Discovery 2 Pro Bundle
https://www.electronics-lab.com/digilents-analog-discovery-2-pro-bundle/
Start verifying and testing a wide range of projects with the Analog Discovery 2. With the addition of the BNC adapter and scope probes, professional or experienced engineers can access the full 30MHz bandwidth oscilloscope and 12MHz bandwidth waveform generator. Digilent also offer the Analog Discovery 2 Maker Bundle and Analog Discovery 2 Student Bundle […]
NXP Semiconductors Layerscape Freeway FRWY-LS1046A Evaluation Boards
https://www.electronics-lab.com/nxp-semiconductors-layerscape-freeway-frwy-ls1046a-evaluation-boards/
The QorIQ FRWY-LS1046A provides a flexible, small form factor and low-cost platform to evaluate a variety of different applications including AI/ML with facial recognition, industrial safety as well as data analytics and other edge computing applications, based on four Arm® Cortex®-A72 cores. NXP Layerscape Freeway FRWY-LS1046A Evaluation Boards are edge computing platforms that support QorIQ® […]
Pine64’s SoEdge-RK1808 AI Module Delivers 3.0 TOPS using Rockchip RK1808 SoC
https://www.electronics-lab.com/pine64s-soedge-rk1808-ai-module-delivers-3-0-tops-using-rockchip-rk1808-soc/
A few time ago, Ameridroid reported that Pine64 would soon launch SoRock and SoEdge systems-on-module, but at the time there was virtually no info except SoRock would be likely based on either RK3328 or RK3399 and work on the existing Clusterboard. SoEdge would be an AI Neural module for Artificial Intelligence tasks, with up to […]
ON Semiconductor NCP51820 half-bridge gate driver
https://www.electronics-lab.com/semiconductor-ncp51820-half-bridge-gate-driver/
The NCP51820, a high-speed gate driver, is designed to meet the requirements of driving enhancement mode. The NCP51820, a high-speed gate driver, is designed to meet the requirements of driving enhancement mode (e-mode) and gate injection transistor (GIT) GaN HEMT power switches in offline, half-bridge power topologies. Both drive stages employ a voltage regulator to […]
Free Article from Elektor: Aviation Scanner
https://www.electronics-lab.com/free-article-elektor-aviation-scanner/
Original publication: Elektor magazine January 2013. Author: Gert Baars, Free download expires: Friday 9 August, 2019. For aircraft enthusiasts and in particular plane spotters, it’s always interesting to listen to communications between aircraft and control towers. This receiver makes it easy to listen to all traffic in the civil aviation band. It is easy to […]
Arduino Voltmeter using SH1106 OLED display
https://www.electronics-lab.com/arduino-voltmeter-using-sh1106-oled-display/
A voltmeter is an important tool on the workbench of every electronics hobbyist, maker or hardware design engineer. As it’s name suggests, allows the user to measure the voltage difference between two points. For today’s tutorial, we will look on how you can build an Arduino based DIY voltmeter, for use in situations where you […]
Elk’s Development Board is suitable Cryptocurrency Applications
https://www.electronics-lab.com/elks-development-board-suitable-cryptocurrency-applications/
An Egyptian startup known as Elk has scored a Kickstarter funding for a tiny (55 x 25.5mm) IoT development board designed for decentralized web applications that can traffic in cryptocurrency payments using blockchain through Ethereum. According to Elk, the Elk board is built for blockchain-enabled IoT networks with privacy guarantees that are not feasible with […]
https://www.electronics-lab.com/project/arduino-voltmeter-using-sh1106-oled-display/
A voltmeter is an important tool on the workbench of every electronics hobbyist, maker or hardware design engineer. As its name suggests, allows the user to measure the voltage difference between two points. For today’s tutorial, we will look at how you can build an Arduino based DIY voltmeter, for use in situations where you […]
