Li-Po/Li-Ion Arduino Charger Shield using BQ21040
https://www.electronics-lab.com/project/li-po-li-ion-arduino-charger-shield-using-bq21040/
This Li-Po/Li-ion Arduino charger shield is mainly designed to power up the Arduino from single 3.6V Li-Po battery. Li-Ion and Li-Pol Charger/ DC-DC Boost converter Arduino shield provides 6.5V/400mA from single Lithium Polymer battery. The Arduino shield is equipped with BQ21040 battery charger IC and CS5171 step up DC-DC converter. The shield also has prototype […]
Raspberry Pi Based Enviro+ pHAT Detects Indoor and Outdoor Atmospheric Conditions
https://www.electronics-lab.com/raspberry-pi-based-enviro-phat-detects-indoor-outdoor-atmospheric-conditions/
If you reside in an area with high levels of outdoor air pollution, you will probably be breathing more indoor pollutants, which is not good for your health. Of course, that depends on your home’s ventilation system and potential pollution sources. Indoor pollutants range from smoke and carbon monoxide to fumes from carpets, industrial cleaners, […]
Miniature vertical side-actuated detection switches ideal for safety applications
https://www.electronics-lab.com/miniature-vertical-side-actuated-detection-switches-ideal-safety-applications/
C&K’s FDSD and FDSE series are micro-mini, side-actuated detection switches suitable for applications which require vertical side detection. They are particularly useful for safety control applications, and for medical and consumer devices. An example of the use of these switches is in inhalers, where they detect the presence of a cartridge, activating the drug delivery […]
LM5164 – 6V to 100V input, 1-A synchronous buck DC-DC converter with ultra-low
https://www.electronics-lab.com/lm5164-6v-100v-input-1-synchronous-buck-dc-dc-converter-ultra-low/
The LM5164 synchronous buck converter is designed to regulate over a wide input voltage range, minimizing the need for external surge suppression components. A minimum controllable on-time of 50 ns facilitates large step-down conversion ratios, enabling the direct step-down from a 48-V nominal input to low-voltage rails for reduced system complexity and solution cost. The […]
Coilcraft Releases Power Line EMI Chokes in 16 Sizes/Configurations
https://www.electronics-lab.com/coilcraft-releases-power-line-emi-chokes-16-sizes-configurations/
Coilcraft offers the Cx family of surface mount, common mode EMI chokes. There are 16 sizes and configurations to meet the design needs of a broad range of power line circuits, says the company. They suppress high frequency common mode noise up to 100MHz and offer greater than 40dB common mode attenuation, making them particularly […]
KB-IDE Supports Arduino, ESP32 and others in Dual Style Coding
https://www.electronics-lab.com/kbide-supports-arduino-esp32-others-dual-style-coding/
Maker Asia is an organization in South East Asia which owns Maker Lab; a place where makers put their creativity in use. They have recently released a new software product and Maker Asia, who have mostly focused on a hardware product line is eventually into a new space. The newly launched product is an open […]
Arduino Clock on IN-18 Nixie Tubes with a LONG Service Life
https://www.electronics-lab.com/arduino-clock-18-nixie-tubes-long-service-life/
Build your own Nixie tube clock/thermometer/display with ease. by Grisha Anofriev @ www.hackster.io We set out to create a Nixie clock or just an information indicator on the largest ex-Soviet IN-18 tubes as an Arduino shield-compatible with both Uno and Mega boards. After a long reading of lots of information about IN-18 tubes on the […]
Room Weather Station Using Arduino and BME280
https://www.electronics-lab.com/room-weather-station-using-arduino-bme280/
We have built quite a number of weather stations in several past tutorials, with each one differing from the other by the use of a different sensor, different display, etc. Today, we are going to build another weather monitoring station using the BME280 Temp and humidity sensor from Adafruit and an OLED display. The BME280 […]
Room Weather Station Using Arduino and BME280 Sensor
https://www.electronics-lab.com/project/room-weather-station-using-arduino-bme280/
emUSB-Device Video – Easily transmit video via USB
https://www.electronics-lab.com/emusb-device-video-easily-transmit-video-via-usb/
SEGGER introduces video class (UVC) support for emUSB-Device. An Embedded System with a USB device interface can now enumerate as a video camera. Once connected to a Host (Windows, Mac, Linux or Tablet), it is recognized as a camera. Video content can come from a live camera feed, a prerecorded video, or can be generated […]
