6A/6V Buck Converter with 16V Input Operates at up to 2MHz
https://www.electronics-lab.com/6a-6v-buck-converter-16v-input-operates-2mhz/
16V, 6A, High Efficiency, Synchronous, Step-Down Converter with Adjustable Current Limit. Monolithic Power Systems (MPS) introduced the MPQ8626, a fully integrated, high-frequency, synchronous, buck converter. According to MPS, the MPQ8626 offers a very compact solution that achieves up to 6A of output current with excellent load and line regulation over a wide input supply range. […]
PicoScope 4 Channel 5GHz Sampler-Extended Real Time Oscilloscope
https://www.electronics-lab.com/picoscope-4-channel-5ghz-sampler-extended-real-time-oscilloscope/
The PicoScope 9404-05 oscilloscope brings very high speed performance at less than half the cost of traditional benchtop solutions. Saelig Company, Inc. has introduced the PicoScope 9404-05 5GHz oscilloscope – a unique PC-based high-resolution device which brings affordable high-speed performance by combining the benefits of real-time and equivalent-time sampling with very high analog bandwidth. The […]
Teeny-Tiny Bluetooth Transmitter Runs on Less Than 1 mW
https://www.electronics-lab.com/teeny-tiny-bluetooth-transmitter-runs-less-1-mw/
Bluetooth Low Energy data packets can now be sent by millimeter-size IoT motes. By Samuel K. Moore @ spectrum.ieee.org Engineers at the University of Michigan have now built the first millimeter-scale stand-alone device that speaks BLE. Consuming just 0.6 milliwatts during transmission, it would broadcast for 11 years using a typical 5.8-millimeter coin battery. Such […]
Ugoos AM6 Fan-Cooled S922X TV Box is launching Soon
https://www.electronics-lab.com/ugoos-am6-fan-cooled-s922x-tv-box-launching-soon/
The popular UGOOS brand has announced the launch of a TV Box powered by Amlogic S922X SoC called UGOOS AM6. Ugoos AM6, in contrast with older model, will include a fan for active cooling, providing optimal performance for the new Amlogic processor. While there are no available photos of the enclosure so far, Ugoos share some […]
UP Xtreme – High Performance SBC Features 8th Gen Whiskey Lake
https://www.electronics-lab.com/xtreme-high-performance-sbc-features-8th-gen-whiskey-lake/
Aaeon has recently announced specifications for a Linux-ready “UP Xtreme” SBC with a 15W TDP, 8th Gen Intel Whiskey Lake-U CPU, up to 16GB DDR4 RAM and 128GB eMMC, 2x GbE, 6x USB, SATA, and optional AI Core X modules via M.2 and mini-PCIe. Aaeon first launched their UP board family back in 2015 with […]
BOXER-8130AI: Machine Vision that Sees the Whole Picture
https://www.electronics-lab.com/boxer-8130ai-machine-vision-sees-whole-picture/
AAEON, a leading developer in AI and Industry 4.0 solutions, announces the BOXER-8130AI, the newest product in our line of compact, fanless embedded Edge AI systems. Powered by NVidia Jetson TX2, the BOXER-8130AI is perfect for machine vision and AIoT gateway applications. The BOXER-8130AI features the powerful NVidia Jetson TX2 CPU paired with 8GB LPDDR4 […]
Merit Sensor TVC is a fully compensated harsh media pressure sensor series
https://www.electronics-lab.com/merit-sensor-tvc-fully-compensated-harsh-media-pressure-sensor-series/
The TVC series is a fully compensated harsh media pressure sensor from Merit SensorTM designed to handle today’s toughest pressure sensing environments. This pressure sensor series offers a pressure range from 15psi to 300psi, over a broad temperature range of −40°C to +150°C, with an accuracy of ±2.5%. The only requirement to operate the TVC series […]
Chirp launches SDK to deliver data-over-sound for ESP32 Arduino projects
https://www.electronics-lab.com/chirp-launches-sdk-deliver-data-sound-esp32-arduino-projects/
The kit is available for ESP32 modules to offer developers cost-effective data transmission via sound waves. Chirp, the pioneers in data-over-sound technology today announced the launch of its new SDK for Arduino, providing developers with audio-based data transmission capabilities to enhance projects created on the platform. Now supporting ESP32 development boards, Chirp’s SDK for Arduino […]
CIPOS™ Micro IPMs are qualified for harsh environments
https://www.electronics-lab.com/cipos-micro-ipms-qualified-harsh-environments/
600V intelligent power modules (IPMs) from Infineon make up the CIPOS Micro IPMs. They are qualified for harsh humid environments, passing 1000 hours of high voltage, high temperature and high humidity reverse bias (HV H3TRB) stress testing. This makes the energy-efficient IPM suitable for power appliance motor drives particularly in circulator hydronic pumps, drain pumps […]
Geniatech Launches AI-Enhanced RK3399Pro Based SBC And 5 Others
https://www.electronics-lab.com/geniatech-launches-ai-enhanced-rk3399pro-based-sbc-5-others/
Geniatech has posted about the launch of their DB3399 and DB3399 Pro SBCs equipped with the RK3399 and RK3399Pro SoCs, and their specifications. The Android 8.0-powered DB3399 Pro SBC runs the new AI-enhanced RK3399Pro version of the hexacore SoC.  A similar DB3399 SBC is also launched with the standard RK3399 SoC, as well as a […]
