UP AI CORE X – Neural network accelerator for AI
https://www.electronics-lab.com/ai-core-x-neural-network-accelerator-ai/
Neural network accelerator for AI on the edge. Up to four trillion ops/sec with just a few watts. Neural Networks are the future of AI and these boards comes into play to help you develop your intelligent visual system with ease. UP AI CORE X is a complete product line of neural network accelerators for […]
Ultra small DC-DC Converter with integrated inductor
https://www.electronics-lab.com/ultra-small-dc-dc-converter-integrated-inductor/
The XCL206 series is a synchronous step-down micro DC/DC converter which integrates an inductor and a control IC in one tiny package (2.5mm×2.0mm, H=1.0mm). A stable power supply with an output current of 600mA is configured using only two capacitors connected externally. Operating voltage range is from 2.0V to 6.0V(XCL20xG:1.8V-6.0V). Output voltage is internally set […]
Libre Computer Project launches Open Source La Frite SC
https://www.electronics-lab.com/libre-computer-project-launches-open-source-la-frite-sc/
Libre Computer has successfully launched a smaller, less powerful follow-up to its Le Potato SBC, the “La Frite SBC. The La Frite SBC is a small version of the Le Potato SBC, that has a quad -A53, HD-only Amlogic S805X, a Raspberry Pi A+ footprint and GPIO connector, and mainline Linux support. The 64 x […]
SP209 Series – 9 channel 200 MSPS logic analyzer with protocol decoders
https://www.electronics-lab.com/sp209-series-9-channel-200-msps-logic-analyzer-protocol-decoders/
SP209 series logic analyzers and protocol decoders offer in depth analysis of logic signals and protocols with 200MHz (5ns) timing resolution. 9-channel operation allows 8-bit parallel data to be captured along with a clock or strobe signal. SP Series is composed of two devices, SP209 and SP209i: The SP209 is the standard edition and SP209i […]
BL651 Series – Bluetooth 5 modules
https://www.electronics-lab.com/bl651-series-bluetooth-5-modules/
Laird’s BL651 Series contains the latest Nordic nRF52810 silicon with Bluetooth 5 Low Energy capabilities and groundbreaking ultra-low power performance. Building on Laird’s multi generation module developments utilizing Nordic silicon (BL600, BL652, BL654) – now comes the latest series offering cost effective Bluetooth 5 enablement for simple BLE applications. The BL651 series exposes all the […]
Constant-on-time buck-boost regulator converts a positive input to a negative output
https://www.electronics-lab.com/constant-time-buck-boost-regulator-converts-positive-input-negative-output/
This is a LM5010 buck-boost regulator able to convert a positive input ranging from 10-50Vdc to -12V output. by Robert Bell @ www.edn.com Buck regulators find wide application as step-down regulators for converting large positive input voltages into a smaller positive output voltages. Figure 1 shows a simplified buck regulator that operates in continuous-conduction mode—that […]
PureThermal Mini – FLIR Lepton Smart I/O Module
https://www.electronics-lab.com/purethermal-mini-flir-lepton-smart-o-module/
PureThermal Mini is a hackable thermal webcam for the FLIR Lepton (2.x – 3.x) LWIR camera core. It is the result of listening to our thousands of PureThermal 1 users and giving them what they want: four mounting holes, pads for optional EM shielding, less complex circuitry, and perhaps best of all, USB DFU. That’s […]
Latest Nucleo boards access open source 8-bit MCU I/Os
https://www.electronics-lab.com/76609-2/
STMicroelectronics has introduced two STM8* Nucleo development boards, letting the 8-bit world experience the ease of access and extensibility already proven with the STM32* Nucleo range. Leveraging the formula that has kickstarted countless STM32 embedded projects, the STM8 Nucleo boards give full access to all STM8 MCU I/Os through ST morpho headers, and contain Arduino™ […]
2.1″ 212x104px Flexible E-Ink Paper with SPI interface
https://www.electronics-lab.com/2-1-212x104px-flexible-e-ink-paper-spi-interface/
DisplayModule introduced a tiny 2.1″ E-paper display with 212×104 pixels resolution. The display can be interfaced using SPI and a Raspberry Pi shield is available for the ones that what to connect it to the popular SBC. Features Flexible and 0.3mm thickness E-Paper 2.13 Inch is suited to E-Label or wearing equipment. 212×104 resolution E-Ink raw […]
Nano-sandwiches in Electronics Significantly Reduce Risk of Overheating
https://www.electronics-lab.com/nano-sandwiches-electronics-reduce-risk-overheating-significantly/
A new study about “Reduction of overheating of 2D materials” published in the Journal of Advanced Materials. The work put behind the study is credited to the researchers at the University of Illinois at Chicago College of Engineering. By joining together two-dimensional materials used in nanoelectronic devices between their three-dimensional silicon bases, they formed an ultrathin layer […]
