ESP32-A1S Wi-Fi+BT Audio Development Kit
https://www.electronics-lab.com/esp32-a1s-wi-fibt-audio-development-kit/
ESP32-A1S is an ultra-small multi-functional audio module. It adopts ESP32 with dual-core processor as the main control. The main frequency is up to 600DMIPS. The module is internally equipped with 4M PSRAM and CodeC audio processing chip, which can be widely used for IoT. ESP32-Audio-kit is a small size audio development board based on ESP32-A1S […]
DFRobot Ships Its Kaby Lake based LattePanda Alpha SBC
https://www.electronics-lab.com/dfrobot-ships-kaby-lake-based-lattepanda-alpha-sbc/
After several months of delay, DFRobot is shipping its Kaby Lake based LattePanda Alpha SBC model, with 8GB RAM and 64GB eMMC with OS support for Windows 10 or Ubuntu 16.04 LTS. Public sales have moved from pre-order to in-stock fulfilment for at least one model. Just like the earlier Intel Cherry Trail based LattePanda, […]
Tiny Function Plotter using ATtiny85
https://www.electronics-lab.com/tiny-function-plotter-using-attiny85/
David Johnson-Davies build a OLED display function plotter based on ATtiny85 microcontroller. He writes: This project describes a simple routine for plotting a function on a 128×64 I2C OLED graphics display. Unlike most Arduino graphics libraries this routine doesn’t require a RAM buffer, and so will work on any processor down to an ATtiny85: The […]
3 New Products from Particle.io Improves IoT Development
https://www.electronics-lab.com/3-new-products-particle-io-improves-iot-development/
At Spectra, Particle’s annual conference, they announced three new products designed to improve enterprise-level IoT development. They are bringing IoT to maturity with total development, deployment, and maintenance platform that goes all through to the enterprise level by design. The 3 new products include: The Particle IoT Rules Engine, Particle Workbench, and Particle Mesh SoMs. […]
Advantech Builds Gaming SBC powered by AMD’s Ryzen V1000
https://www.electronics-lab.com/advantech-builds-gaming-sbc-powered-amds-ryzen-v1000/
Advantech announced a new gaming and lottery board, the DPX-E265. The gaming board is based on AMD’s Ryzen V1000, which features a 4x DP++ ports, 2x SATA, plus M.2, PCle x16, and PCIe x4 expansion. Prior to the DPX E265, in February of this year Advantech announced the DPC-E140 casino gaming board with AMD’s Ryzen […]
1 Square Inch 20MSPS Oscilloscope
https://www.electronics-lab.com/1-square-inch-20msps-oscilloscope/
A 1″ by 1″ 20msps Oscilloscope based on the PIC32MZ @ hackaday.io by “Mark Omo”. He writes: This project is designed around a PIC32MZ EF processor. We use its internal ADCs in an interleaved mode in order to get the full 20Msps. We have found that in practice we are able to achieve approximately 1MHz […]
Decoding Russian Meteor-M2 satellite images in real time
https://www.electronics-lab.com/decoding-russian-meteor-m2-satellite-images-real-time/
The Meteor-M N2 is a polar orbiting Russian weather satellite that was launched on July 8, 2014. Its main missions are weather forecasting, climate change monitoring, sea water monitoring/forecasting and space weather analysis/prediction. Meteor-M N2 transmits images using the digital LRPT protocol at around 137.1 MHz with can be received with an RTL-SDR. The chipset […]
Using the 433MHz RF Transmitter and Receiver with Arduino
https://www.electronics-lab.com/using-433mhz-rf-transmitter-receiver-arduino/
While building microcontroller based projects, there are occasions where communication will be required between two devices, either in a duplex/transceiver based operation (where both devices can transmit and receive at the same time) or in a simplex-based operation where communication is one way (Receiving device cannot transmit and the transmitting device cannot receive). Several options […]
https://www.electronics-lab.com/project/using-433mhz-rf-transmitter-receiver-arduino/
Introduction While building microcontroller based projects, there are occasions where communication will be required between two devices, either in a duplex/transceiver based operation (where both devices can transmit and receive at the same time) or in a simplex-based operation where communication is one way (Receiving device cannot transmit and the transmitting device cannot receive). Several […]
MPLAB Snap debugger programmer
https://www.electronics-lab.com/mplab-snap-debugger-programmer/
RS Components is now stocking Microchip’s MPLAB Snap in-circuit debugger/programmer, for simple and quick debugging and programming of most Microchip PIC, AVR and SAM flash MCUs. [via] The MPLAB® Snap In-Circuit Debugger/Programmer allows affordable, fast and easy debugging and programming of most PIC®, dsPIC® and AVR flash MCUs, using the powerful graphical user interface of […]
