BLE Micro is a Tiny Bluetooth 4.0 Development Board
https://www.electronics-lab.com/ble-micro-is-a-tiny-bluetooth-4-0-development-board/
DFRobot Bluno is a Bluetooth 4.0 LE development board following Arduino UNO form factor, and powered by TI CC2540 chipset. The board sells for $24.90 on their online store, and the company provides firmware and mobile app source code, but if you ever wanted a similar solution in a much smaller form factor, and powered […]
Getting Started with the NodeMCU (ESP8266 Based Development Board)
https://www.electronics-lab.com/getting-started-with-the-nodemcu-esp8266-based-development-board/
As the popularity of Arduino boards increased, the demand for boards which comes embedded with some of the add-ons used with the Arduino increased. One of the most popular add-ons were the WiFi modules which are used to connect Arduino boards to the internet. Several boards were released by different manufacturers which used the Arduino […]
https://www.electronics-lab.com/project/getting-started-with-the-nodemcu-esp8266-based-development-board/
FRAMOS adds Sony’s Spresense line
https://www.electronics-lab.com/framos-adds-sonys-spresense-line/
FRAMOS has been appointed as an approved supplier for the Sony’s Spresense product line of professional developer boards in the United States. [via] These boards are powered by Sony’s 6 core CXD5602 MCU, which are based on an ARM Cortex-M4F with 6 cores operating at up to 156 MHz. The board is supported by the […]
Molex’s thin-film battery can be applied to a curved surface
https://www.electronics-lab.com/molexs-thin-film-battery-can-be-applied-to-a-curved-surface/
Molex’s thin-film battery can be applied to a curved surface with a bend radius of 25 mm or greater. Molex’s thin-film battery is a low-profile, flexible, disposable battery with a small footprint designed for low-power, single-use applications. This battery can be applied to a curved surface with a bend radius of 25 mm or greater. […]
Tiny GNSS module by STMicroelectronics supports GPS, Galileo, GLONASS and BeiDou
https://www.electronics-lab.com/tiny-gnss-module-by-stmicroelectronics-supports-gps-galileo-glonass-and-beidou/
STMicroelectronics lunched the first GNSS module (Global Navigation Satellite System) with the name Teseo-LIV3F. The module is interesting because it contains some cool features. The GNSS module supports GPS, Galileo, GLONASS, QZSS and also BeiDou.  The dimension of module is 9.7 x 10.1 mm and the communication interface is standard UART and I2C (100/400KHz). The […]
Two bits per transistor: high-density ROM in Intel’s 8087 floating point chip
https://www.electronics-lab.com/two-bits-per-transistor-high-density-rom-in-intels-8087-floating-point-chip/
Ken Shirriff has a detailed write-up about the multi-level ROM in Intel’s 8087 floating point chip: The 8087 chip provided fast floating point arithmetic for the original IBM PC and became part of the x86 architecture used today. One unusual feature of the 8087 is it contained a multi-level ROM (Read-Only Memory) that stored two […]
Octavo Creates a 1GHz Computer That Fits into A 27x27mm SiP Package
https://www.electronics-lab.com/octavo-creates-a-1ghz-computer-that-fits-into-a-27x27mm-sip-package/
The OSD335x C-SiP System-in-Package (SiP) developed by Octavo, is a concept package that is modeled on its previous Sitara AM335x based SiP by including up to 16GB eMMC, an oscillator along with 1GB DDR3, PMIC, LDO, and EEPROM. The OSD335x C-SiP, is the most consolidated System-In-Package (SiP) module ever made. Modeled like its predecessors, the […]
Interesting Sensors To Add To Your Weather Station Project
https://www.electronics-lab.com/interesting-sensors-to-add-to-your-weather-station-project/
A Weather station project is a project that gives you information about the weather in a particular area and is quite useful for a lot of things like planning of the day, farming and several others. A weather station project is one of those projects where you can have different types of sensors attached to it. […]
DarkRISC-V Targets low-cost Xilinx Spartan-6 Family of FPGAs
https://www.electronics-lab.com/darkrisc-v-targets-low-cost-xilinx-spartan-6-family-of-fpgas/
Developed in the dark hours of the night, between 2 and 8 o’clock in the morning of August 19th by Marcelo Samsoniuk, the DarkRISC-V stack is an experimental open source implementation of the RISC-V standard targeting the low-cost Xilinx Spartan-6 family of FPGAs. Following a week of debugging, Samsoniuk has released the implementation to GitHub […]
