With ECC Memory, the COM-APLC6 can be Relied On to Perform in any Environment
https://www.electronics-lab.com/ecc-memory-com-aplc6-can-relied-perform-environment/
(Taipei, Taiwan – July 3, 2018) – AAEON, a leading manufacturer of embedded controllers, launches the COM-APLC6, a powerful COM Express Type 6 module. Responding to customer requirements and market trends, the innovative tech giant has fitted its latest module with a series of features designed to strengthen applications and speed up development processes. Powered […]
Fully-integrated smoke detector reduces false alarms
https://www.electronics-lab.com/fully-integrated-smoke-detector-reduces-false-alarms/
With the introduction of the ADPD188BI, Analog Devices (ADI) kills two birds with one stone: First, this smoke detector meets the latest international regulatory standards. Second, the device that integrates two LEDs, photodiode, and analog front-end (AFE) in a single package, help reduce false alarms often caused by steam and dust. The ADPD188BI is engineered […]
Using Waveshare 4.3″ E-paper Display with Arduino
https://www.electronics-lab.com/using-waveshare-4-3%e2%80%b3-e-paper-display-arduino/
Screen technologies have evolved over the years since the cathode ray tube was first demonstrated in 1897, we have moved from plasma to LCDs, followed by LEDs, OLEDs, and more recently e-paper which is what we will look into today. Electronic paper/e-paper displays are display devices which were created to mimic the appearance of ink […]
https://www.electronics-lab.com/project/using-waveshare-4-3-e-paper-display-arduino/
Screen technologies have evolved over the years since the cathode ray tube was first demonstrated in 1897, we have moved from plasma to LCDs, followed by LEDs, OLEDs, and more recently e-paper which is what we will look into today. Electronic paper/e-paper displays are display devices which were created to mimic the appearance of ink on […]
Infrared Thermometer with Arduino and MLX90614 Temperature Sensor
https://www.electronics-lab.com/infrared-thermometer-arduino-mlx90614-temperature-sensor/
Most of the temperature measurement techniques around the world require some sort of physical contact between the temperature sensor and the object or environment whose temperature is to be measured, but as technology advanced, this changed too. The need to be able to measure the temperature of an object without physical contact arose. This need […]
https://www.electronics-lab.com/project/infrared-thermometer-arduino-mlx90614-temperature-sensor/
LoraDunchy – Arduino Compatibile LoRa module
https://www.electronics-lab.com/loradunchy-arduino-compatibile-lora-module/
Lora board with Arduino nano compatibile pinout and simple battery management. Small board with arduino nano compatibile pinout with power management and Murata ABZ LoRa module with STM32L0 microcontroller Features: LoRa module: Murata ABZ Single cell LiPo cell charger on-board with charging signal internally connected to PA11 (via jumper) Buck/Boost switching power supply for delivering […]
Get Paid By Sharing Your Technical Expertise With The Maker’s Community
https://www.electronics-lab.com/get-paid-sharing-technical-expertise-makers-community/
PCBWay, is a leader in the manufacture of PCB and PCBA services and a friend of the community who always have interest of the maker’s community. We have seen PCBWay has put a lot of effort providing sponsorship for PCB based projects already, but they are not stopping there. PCBWay is continuing this community grooming with […]
OPEN MOTOR CONTROL – An open source motor controller for everyone
https://www.electronics-lab.com/open-motor-control-open-source-motor-controller-everyone/
It is open source and based upon the ATmega32U4 microcontroller, and provided with drivers for two DC brush motors and a stepper motor. It receives commands via USB or serial ports, or via the I²C bus. For those dealing with robotics, one of the problems to solve is the management of the motors used for […]
Tracksoar V2 – the smallest, lightest, open source APRS tracker
https://www.electronics-lab.com/tracksoar-v2-smallest-lightest-open-source-aprs-tracker/
What is Tracksoar Tracksoar is one of the smallest, lightest, open source APRS trackers available. It makes tracking weather balloons, model rockets, RC aircraft, and anything else that flies simple and easy. It is able to report location, altitude, temperature pressure and humidity to the internet or direct to an amateur radio once a minute […]
