Bosch BME280 sensor combines pressure, humidity and temperature measurement
https://www.electronics-lab.com/bosch-bme280-sensor-combines-pressure-humidity-temperature-measurement/
Bosch Sensortec announces a world first in sensor technology: the BME280 Integrated Environmental Unit combines sensors for pressure, humidity and temperature in a single package. This unique sensor has been developed to support a broad range of emerging high performance applications such as indoor navigation, home automation control, personalized weather stations and innovative sport and […]
Three Ways to Make Arduino Works As A USB/TTL Converter
https://www.electronics-lab.com/three-ways-make-arduino-works-usbttl-converter/
Even if you have years working with electronics, you will still find some simple hacks that you never thought about before. Personally and to save money, when I was a student with a very limited budget I knew that my Arduino UNO can work as a USB/TTL(serial) converter. I used to remove the Atmega328P from […]
A New Soundproof Air-Transparent Window
https://www.electronics-lab.com/a-new-soundproof-air-transparent-window/
Imagine you have a window that isolates noises and passes only nature sounds like sea waves in addition to fresh air. Seems like it will happen in dreams only, right? Actually, researchers from South Korea, bring this window from dreams to the real. Soundproofing is difficult and expensive, it usually relies on transferring sound into a medium […]
Voladd: The First Fully Integrated 3D Printer
https://www.electronics-lab.com/voladd-first-fully-integrated-3d-printer/
The Spain based Voladd company introduces their fully integrated 3D printer on a kickstarter campaign. The heart of printer is a BeagleBone Black single board computer running Debian Linux that connects to cloud service directly without need of an attached computer. With your smartphone, tablet or laptop, you have the power to search for thousands […]
Researchers Developed Low Cost Battery From Graphite Waste
https://www.electronics-lab.com/researchers-developed-low-cost-battery-graphite-waste/
Lithium-ion batteries are flammable and the price of the raw material is increasing. Scientists and engineers have been trying to find out a safe yet efficient alternative to the Lithium-ion technology. The researchers of Empa and ETH Zürich have discovered promising approaches as to how we might produce powerful batteries out of waste graphite and […]
Sensor board for micro:bit
https://www.electronics-lab.com/sensor-board-microbit/
The MonkMakes Sensor Board for micro:bit allows you to sense sound level, temperature and light level. Features 3V and GND connections can be made from either side and allow you to power a second board such as the MonkMakes Relay Board or MonkMakes Speaker. LED ‘power on’ indicator Reverse polarity protection All three sensors are analog […]
SprintIR6S, World’s Fastest NDIR CO2 Sensor
https://www.electronics-lab.com/sprintir6s-worlds-fastest-ndir-co2-sensor/
Gas Sensing Solutions (GSS) Ltd is a designer and manufacturer of low power, high speed Non-Dispersive Infrared (NDIR) carbon dioxide gas sensors. Recently, it has claimed a new speed record for its SprintIR6S NDIR CO2 sensor. The new sensor comes with response rates that had never been reached before by any other NDIR CO2 sensors. It can […]
2018 Will Mark A Milestone in GNSS Technology with 30-centimeter Accuracy
https://www.electronics-lab.com/2018-will-mark-milestone-gps-technology-30-centimeter-accuracy/
You’re in a crowded street with many high buildings around you and you find your car position on Google maps is wrong. That’s usual, right? This is caused from (fake/distorted) GPS signals reflected from the high buildings around you which make your GPS receiver do some wrong calculations. So be careful don’t always listen to […]
50V – 10A Bidirectional DC Motor Driver Using A3941
https://www.electronics-lab.com/50v-10a-bidirectional-dc-motor-driver-using-a3941/
This tiny board designed to drive bidirectional DC brushed motor of large current. DC supply is up to 50V DC. A3941 gate driver IC and 4X N Channel Mosfet IRLR024 used as H-Bridge. The project can handle a load up to 10Amps. Screw terminals provided to connect load and load supply, 9 Pin header connector […]
https://www.electronics-lab.com/project/50v-10a-bidirectional-dc-motor-driver-using-a3941/
This tiny board is designed to drive a bidirectional DC brushed motor of large current. DC supply is up to 50V DC. A3941 gate driver IC and 4X N Channel Mosfet IRLR024 used as H-Bridge. The project can handle a load of up to 10A. Screw terminals are provided to connect the load and load […]
