6 Channel RF Remote Controller Using CC2500 RF Modules
https://www.electronics-lab.com/project/6-channel-rf-remote-controller-using-cc2500-rf-modules/
The 6 Channel RF Remote Controller designed using CC2500 RF Transceiver modules and PIC16F1847 micro-controller from microchip. Transmitter provided with 6 tact switch, 4 Address Jumpers to pair multiple unit so they don’t interfere with each other. Board provided with power LED, valid transmission LED. Project works with 5 V DC, On board LM1117-3.3V regulator […]
Bluetooth Smart module is only 11x8x1.8mm
https://www.electronics-lab.com/bluetooth-smart-module-11x8x1-8mm/
By Julien Happich @ eedesignnewseurope.com: Amber wireless GmbH’s AMB2621 Bluetooth Smart module is a 2.4 GHz BLE wireless module based on the Bluetooth Smart 4.2 standard, measuring only 11x8x1.8mm and offered with or without integrated antenna. Bluetooth Smart module is only 11x8x1.8mm – [Link]
Using a supercapacitor for power management and energy storage with a small solar cell
https://www.electronics-lab.com/using-supercapacitor-power-management-energy-storage-small-solar-cell/
Jean Mars & Julia Leem @ edn.com writes: In Part 1 of this series, we have reviewed solar cell performance, how to select and size the supercapacitor, requirements of supercapacitor charging circuits and charging IC characteristics. We will now use two case studies to illustrate these properties in detail. Using a supercapacitor for power management […]
1 Cent Lab-On-A-Chip For Early Diagnostics
https://www.electronics-lab.com/1-cent-lab-chip-early-diagnostics/
Researchers at the Stanford University School of Medicine have developed a way to produce a cheap and reusable diagnostic “lab on a chip” with the help of an ordinary inkjet printer. At a production cost of as little as 1 cent per chip, the new combination of microfluidics, electronics and inkjet printing technology could usher in […]
New Release For EAGLE CAD with PCB Alignment Tools
https://www.electronics-lab.com/new-release-eagle-cad-pcb-alignment-tools/
Since Autodesk acquired Eagle CAD, big changes have been made to Eagle CAD. Regardless of the new licensing system using subscription model, which was a subject to criticism by a lot of users, the new management of Eagle from Autodesk has successfully added a lot of demanding features that old team failed to bring out. […]
Simple circuit indicates health of lithium-ion batteries
https://www.electronics-lab.com/simple-circuit-indicates-health-lithium-ion-batteries/
Fritz Weld @ edn.com proposes a simple circuit to check li-ion battery health. He writes: Lithium-ion batteries are sensitive to bad treatment. Fire, explosions, and other hazardous condition may occur when you charge the cell below the margin that the manufacturer defines. Modern battery chargers can manage the hazardous conditions and deny operation when illegal […]
Boost Converters and Buck Converters: Power Electronics
https://www.electronics-lab.com/boost-converters-buck-converters-power-electronics/
Boost Converters and Buck Converters: Power Electronics – [Link]
Exploring Eagle CAD ULPs #6 – Group-aps_v4.ULP Autoplace by Group
https://www.electronics-lab.com/exploring-eagle-cad-ulps-6-group-aps_v4-ulp-autoplace-group/
Welcome to the 6th post of the “Exploring Eagle CAD ULPs” series. Each post will be discussing one useful ULP in Eagle CAD. “ULP” User Language Program is a plain text file which is written in a C-like syntax and can be used to access the EAGLE data structures and to create a wide variety […]
Fast Single-Pixel Camera
https://www.electronics-lab.com/fast-single-pixel-camera/
Compressed sensing is an new computational technique to extract large amounts of information from a signal. Researchers from Rice University, for example, have built a camera that can generate 2D-images using only a single light sensor (‘pixel’) instead of the millions of pixels in the sensor of a conventional camera. This compressed sensing technology is […]
Raspberry Pi Publishing MQTT Messages to ESP8266
https://www.electronics-lab.com/raspberry-pi-publishing-mqtt-messages-esp8266/
Rui @ randomnerdtutorials.com tipped us with his latest tutorial. He writes: In this project you’ll create a standalone web server with a Raspberry Pi that can toggle two LEDs from an ESP8266 using MQTT protocol. You can replace those LEDs with any output (like a relay that controls a lamp). Raspberry Pi Publishing MQTT Messages to […]
