Dual Screen Netatmo Weather Station
https://www.electronics-lab.com/dual-screen-netatmo-weather-station/
Netatmo Weather Station is a module that measures your indoor comfort by providing vital information such as temperature, humidity, air quality, and CO2, alerting you when you need to air out your home to bring down its pollution levels. One of the Netatmo limitations is that you need to use a smartphone to view the […]
ElectroCalc – Electrical and Electronics Calculator
https://www.electronics-lab.com/electrocalc-electrical-electronics-calculator/
“Tiago” tipped us with his latest Android App. His app, ElectroCalc is a fast calculator for electrical and electronic circuits. The calculator includes many tools and comes in a free and a Pro version. Check it out! ElectroCalc – Electrical and Electronics Calculator – [Link]
Make Your Own Power Meter/Logger
https://www.electronics-lab.com/make-power-meterlogger/
In this tutorial GreatScottLab will show us how to build a power meter and logger using Arduino and INA219 power monitor IC: In this project I will show you how I combined an Arduino, an INA219 power monitor IC, an OLED LCD and a Micro SD Card PCB in order to create a power meter/logger […]
LTC3786 – Efficient boost controller takes the heat
https://www.electronics-lab.com/ltc3786-efficient-boost-controller-takes-heat/
Linear Technology has launched a higher-temperature 150°C version of its LTC3786 step-up DC/DC controller that boasts 98% efficiency. This H-grade device replaces the boost diode with an N-channel MOSFET for higher efficiency and reduced power loss. by Susan Nordyk @ edn.com: The controller produces a 24-V, 5-A output from a 12-V input with up to […]
4 Channel Relay Board
https://www.electronics-lab.com/4-channel-relay-board-2/
4 Channel Relay Board is a simple and convenient way to interface 4 relays for switching application in your project. Very compact design that can fit in small area, mainly this board is made for low voltage applications. Features Input supply 12 VDC @ 170 mA Output four SPDT relay Relay specification  10A/24V DC Trigger […]
Large Current Relay with Dual Output DC-DC Converter for Hobby CNC/Router
https://www.electronics-lab.com/large-current-relay-dual-output-dc-dc-converter-hobby-cncrouter/
Single Channel Large current relay board with dual DC-DC converter board is mainly designed for Hobby CNC, Routers, and Plasma cutters. Hobby CNC controller requires multiple DC outputs to drive various things.  This board provides 5V DC and 12V DC 1Amp each. The dual supply helps driving LPT breakout board, Sensors, Limit switches and few […]
Badgerboard, LoRa Future IoT Development Board
https://www.electronics-lab.com/badgerboard-lora-future-iot-development-board/
The LoRa Alliance™ is an open, non-profit association of members who believe that the Internet of Things era is now, its LoRaWAN is a Low Power Wide Area Network with features that support low-cost, mobile, and secure bidirectional communication for Internet of Things (IoT), machine-to-machine (M2M), smart city, and industrial applications. LoRaWAN is optimized for […]
https://www.electronics-lab.com/project/4-channel-relay-board-2/
LC-04 4 Channel Logic Converter 3.3V – 5.0V
https://www.electronics-lab.com/lc-04-4-channel-logic-converter-3-3v-5-0v/
If you have ever tried to connect a 3.3V device to a 5V system, you know what a challenge it can be. The LC-04 bi-directional logic level converter is a small device that safely steps down 5V signal to 3.3V and steps up 3.3V to 5V at the same time. In this instructable, mybotic explained the […]
Introducing Autodesk Circuits Simulator For Beginner
https://www.electronics-lab.com/introducing-autodesk-circuits-simulator-beginner/
Circuits.io is an online platform created by Autodesk for hardware hackers. It provides a browser-based application for designing, simulating electronic circuits and creating PCB boards. Autodesk circuits simulator can simulate Arduino-based projects for testing designs and programs before creating them in real life. The simulator allows you to learn electronics using a virtual Arduino board […]
