Sipeed NanoCluster: Compact Multi-SOM Computing Platform with RISC-V Gigabit Ethernet Switch and PoE Support
Sipeed’s RPi-sized NanoCluster is a compact computing platform designed for multi-SOM configurations, balancing size and functionality. It supports up to seven system-on-modules (SoM), including the LM3H, CM4, CM5, and M4N, and features an onboard open-source RISC-V Gigabit Ethernet switch, 60W PD/PoE power support, and UART/PWR control.
Sipeed NanoCluster
Sipeed’s RPi-sized NanoCluster is a compact computing platform designed for multi-SOM configurations, balancing size and functionality. It supports up to seven system-on-modules (SoM), including the LM3H, CM4, CM5, and M4N, and features an onboard open-source RISC-V Gigabit Ethernet switch, 60W PD/PoE power support, and UART/PWR control. This makes it suitable for various distributed computing applications.
With dimensions of just 85 mm x 56 mm, the NanoCluster is significantly smaller than a standard mini-ITX board, occupying only one-sixth of its size. Despite its compact form, it integrates an embedded RISC-V Gigabit Ethernet switch with OpenSDK support, enabling robust networking capabilities. It supports ACL, SVL, VLAN, and QoS, ensuring efficient data management across different applications.
NanoCluster + LM3H Modules
Storage configurations depend on the SOM used. The LM3H module includes eMMC storage, while the CM4 and CM5 variants support TF/eMMC with optional SSD storage. The M4N module offers both eMMC and SSD storage, providing flexible data management options. Additionally, a dedicated slot is reserved for a baseboard management controller, with power and UART interfaces for further control.
For connectivity, the primary slot includes two USB 2.0 ports, while USB-C connectivity is available via an adapter for the M4N, CM4, and CM5 modules. A single HDMI output is also provided for display support.
NanoCluster + CM4 Modules
Sipeed NanoCluster Specifications:
  • SoM Count and SoM type: 7 SoM including LM3H, M4N, and Raspberry Pi CM4/CM5
  • Video Output: 1x HDMI port
  • Storage Options:
    • LM3H: eMMC Flash
    • M4N: eMMC Flash + NVMe SSD support
    • Raspberry Pi CM4/CM5: Micro SD Card + eMMC Flash + NVMe SSD support
  • Networking:
    • Embedded RISC-V Gigabit Ethernet switch with OpenSDK support
    • ACL, SVL, VLAN, and QoS for efficient data management
  • USB:
    • 2x USB 2.0 ports for NanoCluster + LM3H module
    • USB-C connectivity for M4N and Raspberry Pi CM4/CM5 modules (via adapter)
  • Expansions:
    • Slot 1 of NanoCluster + LM3H Module reserved as Baseboard Management Controller (BMC)
    • Power and UART Interfaces (4 SOM system UART in slot1 is accessible)
  • Power Input: USB-C PD/PoE Module up to 60W
  • Dimensions: 85 mm x 56mm
  • Weight: 200 grams (NanoCluster + Raspberry Pi CM4 Module)
Sipeed NanoCluster comparisn
The NanoCluster will be available starting at $39. According to Sipeed’s social media updates, the board will be open for orders soon.
via linuxgizmos.
