Exclusive Interview: How DRAM Volatility is Redefining Edge AI
In this Electronics-Lab exclusive, Hailo CTO Avi Baum explains how rising costs are driving a pivot to efficient, low-memory models and dedicated accelerators.
When Hailo mentioned to us that DRAM pricing was impacting AI deployment, we wanted to know more. Avi Baum, Chief Technology Officer for Hailo, was willing to answer our questions and provide insights into the market dynamics that affect engineering design decisions.
Avi Baum, CTO of Hailo
Avi Baum, Chief Technology Officer at Hailo
Designing Through the DRAM Supply Squeeze
Electronics-Lab: How are current market forces, like DRAM pricing and increasingly long procurement times, shaping how AI is being employed at the edge?
Avi Baum: DRAM pricing is affecting AI deployment much earlier in the design process than ever before. As prices climb in some cases by nearly 200 percent and lead times stretch well into 2026, particularly for high-capacity modules in the 4 to 16 GB range, AI systems built around large memory footprints are becoming increasingly difficult to source.
Even hyperscalers, typically at the front of the procurement line, are reportedly receiving only about 70 percent of their allocated volumes. That level of constraint is pushing teams to reassess not just where AI runs, but how these systems are designed from the ground up.
Micron DRAM module over industrial vision system
DRAM is a key component of many edge AI systems. Composite image used courtesy of Micron and Adobe Stock
At Hailo, we’re promoting a shift toward systems designed around smaller, more efficient memory footprints. As lower-capacity models around 1-2 GB remain more stable and accessible, developers are favoring models that deliver practical intelligence without depending on scarce resources.
As developers design AI workloads to operate within real-world constraints, they are increasingly moving frequently used inference closer to the edge. In practice, this allows organizations to avoid bottlenecks, reduce exposure to price volatility, and deploy AI in a way that is both operationally and economically sustainable.
Efficiency Over Complexity
Electronics-Lab: In edge AI applications, there seems to be a natural tendency to employ increasingly complex models that require more costly compute hardware and more power consumption. What are some alternatives that edge AI system developers should be considering?
Baum: Rather than defaulting to large models, edge AI developers should consider architectures that are optimized for efficiency and task specificity. Many real-world edge use cases do not require the full generality of large models and instead benefit from smaller networks that are trained or fine-tuned for a particular function.
Model-optimization techniques that minimize reliance on off-chip memory allow AI workloads to run more efficiently, reducing both latency and power consumption while maintaining performance.
A Case for Dedicated AI Accelerators
Electronics-Lab: For system developers who are still getting started with edge AI, what are some reasons they should be considering AI accelerators?
Baum: Accelerators offer a way to run advanced models locally without requiring systems to be built around large memory footprints or cloud dependence. By handling inference on dedicated hardware, AI workloads can be executed efficiently and predictably on the device, even as models become more capable.
Accelerators also help developers design edge systems around realistic constraints. Offloading inference reduces reliance on high-capacity external memory and enables frequently used AI functions to remain available locally, rather than depending on network access. This makes it easier to deploy consistent, responsive AI at the edge while avoiding the cost, complexity, and fragility associated with memory-heavy or cloud-only architectures.
Hailo AI accelerator of demonstration of AI vision operating at traffic intersection
AI accelerators can reduce the reliance on high-capacity external memory. Images used courtesy of Hailo
Future-Proofing via Privacy and Adaptability
Electronics-Lab: With new application requirements and security and privacy directives that often require field updates, how can edge AI systems be designed to be future-proof?
Baum: Future-proof edge AI systems are built around flexibility. As models become embedded in routine interactions such as summarizing conversations, translating speech or interpreting images, processing that data locally becomes a foundational privacy safeguard rather than an optional feature.
Keeping inference on the device or within a nearby gateway ensures that sensitive information does not travel to a remote server simply to be interpreted, which aligns more naturally with evolving privacy expectations and regulatory requirements.
To support this over time, edge AI systems need to be designed for adaptability. Hybrid architectures reinforce this approach by allowing developers to keep privacy-sensitive intelligence local while selectively using the cloud for updates or less sensitive tasks. Together, local processing and flexible update paths allow edge AI systems to remain compliant, trustworthy, and reliable as both technology and privacy expectations continue to evolve.
Addressing Misconceptions
Electronics-Lab: Are there any other common misconceptions about edge AI applications or hardware AI accelerators that you would like to address?
Baum: One common misconception is that edge AI and cloud AI are mutually exclusive. In practice, some real-world deployments benefit from a hybrid approach, where routine and time-sensitive workloads run locally while the cloud handles aggregation, retraining, or large-scale analytics. Edge AI is not about replacing the cloud but about using it more strategically.
Another misconception is that edge accelerators limit innovation. In reality, constraints often drive better system design. Working within defined memory, power, and latency boundaries encourages developers to build solutions that are more robust, efficient, and deployable at scale, especially as AI becomes embedded in everyday products.
