SniffPhone – Screening for cancer made easy
https://www.electronics-lab.com/sniffphone-screening-cancer-made-easy/
A newly developed handheld medical diagnostic tool called the SniffPhone, analyses exhaled breath and is able to detect early signs of gastric cancer. The SniffPhone links via Bluetooth to a smartphone and is a totally novel application using nanotech chemical sensors, offering enormous benefits to clinicians and patients alike. Its development has been supported by […]
NVIDIA Announces Jetson Nano: $99 Tiny Developer Kit
https://www.electronics-lab.com/nvidia-announces-jetson-nano-99-tiny-developer-kit/
NVIDIA today announced the Jetson Nano™, an AI computer that makes it possible to create millions of intelligent systems. The small but powerful CUDA-X™ AI computer delivers 472 GFLOPS of compute performance for running modern AI workloads and is highly power-efficient, consuming as little as 5 watts. Unveiled at the GPU Technology Conference by NVIDIA […]
Free Tech Start-up Infographic and 15% discount code from Farnell
https://www.electronics-lab.com/free-tech-start-up-infographic-and-15-discount-code-from-farnell/
Successful tech entrepreneurs share the lessons learned from starting a new business with expert contributions from Pi Supply, Matrix Labs and futurehome. Download the free infographic for step-by-step advice on taking the first leap all the way through to learning from failure. Whether you plan on customising existing platforms or designing from scratch, the experts […]
Convert a $20 Router To Home Automation Gateway For IoT Devices
https://www.electronics-lab.com/convert-20-router-home-automation-gateway-iot-devices/
WiFi based home automation products are cheaper compared to ZigBee or Z-Wave products, but the downside is that WiFi devices need an internet connection to perform their function. A lot of those IoT devices don’t just communicate on your local network, they also talk to the outside world via the internet. IoT devices like simple […]
Raspberry Pi Web-Based Data logger using MySQL and PHP
https://www.electronics-lab.com/raspberry-pi-web-based-data-logger-using-mysql-php/
Over the past few weeks, we worked on different projects around IoT. Today, we will continue on this track and we will build a web-based data logger using the Raspberry Pi 3 and the Pi Sense Hat. For this project, we will designate the Raspberry Pi to measure temperature, humidity and barometric pressure using the […]
Robust high-bandwidth passive DIY probes
https://www.electronics-lab.com/robust-high-bandwidth-passive-diy-probes/
Tomi Nihtilä build his own high-bandwidth passive probes to solve some issues with classic oscilloscope probes he describes on the article. He writes: Before presenting this great tip I must admit I did not come up with this idea. This type of measurement probe is presented in the book High Speed Digital Design – A […]
https://www.electronics-lab.com/project/raspberry-pi-web-based-data-logger-using-mysql-php/
USB Type-C™ and Power Delivery Multiport Adapter Reference Design
https://www.electronics-lab.com/usb-type-c-power-delivery-multiport-adapter-reference-design/
The TIDA-03027 reference design represents a multiport adapter solution that enables products with a USB Type-C interface to connect to HDMI 2.0 and USB 3.0 Type-A interfaces. It also includes an additional USB Type-C full feature receptacle, which allows the user to simultaneously connect USB Type-C chargers (up to 20V / 3A) or devices. This […]
New Kontron KBox B-201-CFL Embedded Box PC
https://www.electronics-lab.com/new-kontron-kbox-b-201-cfl-embedded-box-pc/
KBox B-201-CFL with Powerful 8th Generation Intel® Core™ i3/i5/i7 Processors – Compact Housing, Low-Noise Operation and Flexible Mounting Options Kontron, a leading global provider of IoT/Embedded Computing Technology (ECT), introduces the KBox B-201-CFL to its family of embedded box PCs. The KBox B-201-CFL features high performance in a compact housing and with low noise level (maximum […]
Bosch BMI088 Inertial Measurement Units
https://www.electronics-lab.com/bosch-bmi088-inertial-measurement-units/
Bosch’s BMI088 features high vibration suppression for drone and robotic applications. Bosch Sensortec’s BMI088 is a high-performance 6-axis inertial sensor consisting of a 16-bit digital, triaxial, ±24 g accelerometer and a 16-bit digital, triaxial, ±2000°/s gyroscope. BMI088 allows highly accurate measurement of orientation and detection of motion along three orthogonal axes. With high vibration robustness and […]
