MCC 118 – 100kS/s Stackable DAQ HAT For Raspberry Pi
https://www.electronics-lab.com/mcc-118-100ks-s-stackable-daq-hat-for-raspberry-pi/
Measurement Computing Corporation (MCC) has released a $99 measurement DAQ (Data acquisition system) HAT for the Raspberry Pi. It is highly optimized for single point and waveform voltage. MCC claims their board allows greater accuracy with high resolution. It has much faster sample rates than many other DAQ HAT add-ons for the Raspberry Pi. The new “MCC 118” provides […]
Installing the Arduino Bootloader on the Atmega328p Microcontroller
https://www.electronics-lab.com/installing-the-arduino-bootloader-on-the-atmega328p-microcontroller/
Cost and size, just to mention a few, makes using an Arduino board in certain projects an overkill, often times its always too big, or too expensive for the scope of the project especially when it’s a project that we need to make several units. One good way to retain the simplicity that comes with the […]
Flashing Arduino Bootloader on Atmega328p Microcontroller
https://www.electronics-lab.com/project/installing-the-arduino-bootloader-on-the-atmega328p-microcontroller/
Introduction Cost and size, just to mention a few, makes using an Arduino board in certain projects an overkill, often times its always too big, or too expensive for the scope of the project especially when it’s a project that we need to make several units. One good way to retain the simplicity that comes with […]
muArt – A Simple Serial Adapter Like No Other
https://www.electronics-lab.com/%ce%bcart-a-simple-serial-adapter-like-no-other/
UART has become a popular term with microcontroller applications, with the rise of the Arduino, Raspberry Pi, and other open hardware electronics. UART has become a standard for microcontrollers to communicate with each other and exchange data. A UART can be used not just for data exchange between microcontrollers, single board computers, and other hackers […]
NanoPi M4 – RK3399 Based RPi Clone SBC Costs $65
https://www.electronics-lab.com/nanopi-m4-rk3399-based-rpi-clone-sbc-costs-65-only/
FriendlyElec has launched the NanoPi M4. It is one of the smallest, most affordable Rockchip RK3399 based SBC yet. The NanoPi M4 has essentially the same layout as the latest Raspberry Pi 3 Model B+ and has all of its stand out features. Aside from the different processor, this is a very close resemblance of the RPi 3 B+ except for […]
Tachyon – 120MHZ 32-bit Arduino Compatible Microcontroller
https://www.electronics-lab.com/tachyon-120mhz-32-bit-arduino-compatible-microcontroller/
The Tachyon is a new lightning-fast open-source Arduino Zero-compatible board developed by Rabid Prototypes, currently on Kickstarter for funding. It features a 32-bit ARM M4F processor running at 120MHz and contains 128K of RAM. The Tachyon’s pinout is nearly identical to both the Neutrino and Arduino Zero, making it a go-with replacement for practically any project using either one. The Tachyon is an open […]
Tutorial, Experiment & Teardown of a 24GHz Doppler Radar Module
https://www.electronics-lab.com/tutorial-experiment-teardown-of-a-24ghz-doppler-radar-module/
In this episode Shahriar demonstrates a full analysis of a CDM324 24GHz Doppler radar module from IC Station. Opening the module reveals a series of microwave PCB components and several active devices. A complete analysis of the module is presented. The unit is then measured and the impact of antenna impedance and power supply voltage […]
Display kit turns panel PCs into fully featured digital displays
https://www.electronics-lab.com/display-kit-turns-panel-pcs-into-fully-featured-digital-displays/
AAEON, a major developer of industrial computing solutions, is releasing a Display Box Kit to work in conjunction with its successful OMNI Series. The new kit builds on the series’ modular design and allows users and distributors to quickly convert panel PCs into digital displays and vice-versa. In addition to connecting Display Box Kits to […]
Smart fan with face detection camera
https://www.electronics-lab.com/project/smart-fan-with-face-detection-camera/
Smartphone’s camera detects your face and the fan moves automatically according to your face. This is an easy project using obniz, servo motor, smartphone, and a fan. Required Components Obniz Servo motor Small USB fan USB <-> Pin header Pin header Cable USB-Cable USB-Adaptor How it works We use HTML5 Multimedia to use smartphone’s camera. […]
The Fishino Piranha – A Development Board With 120MHz 32bit Microcontroller
https://www.electronics-lab.com/the-fishino-piranha-a-development-board-with-120mhz-32bit-microcontroller/
A few weeks ago Open Electronics announced their new “Fishino Piranha” board. It is one of the first boards to imitate the Arduino MKR. The Fishino Piranha follows with the release of their Uno-inspired “Fishino 32” board, which was released at the start of last year. The Piranha has the same 32-bit Microchip PIC32MX as the previous board with […]
