Raspberry Pi Zero Docking Hub
https://www.electronics-lab.com/raspberry-pi-zero-docking-hub/
Add more connectivity to your Raspberry Pi Zero with this docking hub. Available on kickstarter for 16 USD and has 34 days to go. The Pi Zero USB Docking Hub is a stackable USB Hub that comes with 5 x USB 2.0 data and charging ports, a micro USB port for power input, an RJ45 […]
Arduino Breathalyzer Using MQ3 Gas sensor and OLED Display
https://www.electronics-lab.com/project/arduino-breathalyzer-using-mq3-gas-sensor-oled-display/
Introduction Hi guys, Welcome to this tutorial. Today we will build a breathalyzer using the MQ3 gas sensor, an OLED display and Arduino. A breathalyzer is a generalized trademarked name for devices used for determining blood alcohol content from a breath sample. This means the device can detect from your breadth, the amount of alcohol […]
PCBite 2.0 – Hands-free & steady solution for your measurements
https://www.electronics-lab.com/pcbite-2-0-hands-free-steady-solution-measurements/
SensePeek launched a kickstarter campaign about their PCBite 2.0, a hands free assistance for your electronic measurements. The campaign has 17 days to go, with pledges starting from 30 USD. Last year we created the flexible and rock solid PCB holder – the end to wobbly circuit boards on your workbench. TODAY we proudly present […]
RadarBox24.com – Live Flight Tracker and Flight Status
https://www.electronics-lab.com/radarbox24-com-live-flight-tracker-flight-status/
AirNav Systems develops flight tracking software able to live track flights from around the globe. The solutions are developed by real aviation professionals (airline pilots, engineers and air traffic controllers) -and RadarBox24 was developed on a real world aviation environment. ADS-B receivers used are AirNav RadarBox Pro and AirNav RadarBox 3D. Every RadarBox receiver is […]
Raspberry Pi Internet Weather Station
https://www.electronics-lab.com/raspberry-pi-internet-weather-station/
The RPi Internet Weather Station project displays the weather information such as temperature, humidity and successive weather forecast. The 4DPi-35-II is a 3.5″ 480×320 Primary Display for the Raspberry Pi, which plugs directly on top of a Raspberry Pi and displays the primary output which is normally sent to the HDMI or Composite output. It […]
How to reduce Arduino Uno power usage by 95%
https://www.electronics-lab.com/reduce-arduino-uno-power-usage-95/
Patrick Fenner @ deferredprocrastination.co.uk shows us how to reduce the power consumption of Arduino UNO. He achieved that by modifying the following parts. To reduce the overall power usage of the Arduino UNO board significantly: replace the linear regulator with a DC-DC converter, adjust the USB-to-Serial circuit so it’s only powered from the USB port, […]
Instrumentation Amplifier For Pressure Sensor
https://www.electronics-lab.com/instrumentation-amplifier-pressure-sensor/
General purpose differential amplifier project has been designed for various pressure sensor amplifier applications. Circuit provided with multiple resistors, capacitors, dual sensor options and 4 pin Header connector to interface other external sensors. Schematic is an example from NXP application AN1318 Figure 2. The most popular silicon pressure sensors are piezo-resistive bridges that produce a […]
https://www.electronics-lab.com/project/instrumentation-amplifier-pressure-sensor/
8×8 pixel Time-of-Flight sensor is only 2.65×2.7mm
https://www.electronics-lab.com/8x8-pixel-time-flight-sensor-2-65x2-7mm/
Swiss company Espros has completed its cwTOF imager family with the epc611, its smallest Time-of-Flight sensor to date, measuring only 2.65×2.7mm and delivering a 8×8 pixel field. by Julien Happich @ eenewseurope.com: Sampling now and in volume production at TSMC, the chip can either be used as an 8×8 pixel imager for simple gesture recognition, […]
Solar supercapacitor creates electricity and hydrogen fuel on the cheap
https://www.electronics-lab.com/solar-supercapacitor-creates-electricity-hydrogen-fuel-cheap/
Researchers in University of California, Los Angeles (UCLA) made a device that may help bring hydrogen powered vehicles to the masses. This device uses sunlight to produce both hydrogen and electricity at the same time. The UCLA device is a hybrid unit that combines a supercapacitor with a hydrogen fuel cell, and runs on solar […]
