It’s the end of C as we know it!
https://www.electronics-lab.com/end-c-know/
beningo.com discuss about the future of C language and it’s use in embedded systems. The C programming language has been with embedded software developers since its creation in 1972. Ever since then C has been a blazing constant, surviving even the big push in the late 90’s and early 21st century to move to C++ […]
Bi-Directional Voltage Level Translator
https://www.electronics-lab.com/bi-directional-voltage-level-translator/
Lukas Fassler from Soldernerd shares his experience designing a bi-directional voltage level translator and manufacturing the board with DirtyPCBs. While most of my microcontroller designs run on 3.3 volts there is still the occasional 5 volt design. Or I do something with an Arduino. So the need may arise to interface between logic working at different […]
Cheap homemade 30 MHz – 6 GHz vector network analyzer
https://www.electronics-lab.com/cheap-homemade-30-mhz-6-ghz-vector-network-analyzer/
Henrik Forstén has done amazing job designing a homemade vector analyzer with the goal to fit it’s budget of 200EUR. The design is open source and available on github. Vector network analyzer (VNA) are used to measure scattering parameters of high frequency circuits. When frequency is high enough the reflections of the waves start to […]
Projecta: A Solution For PCB Printing
https://www.electronics-lab.com/projecta-solution-pcb-printing/
Projecta, the Affordable & Faster PCB Prototyping Machine is going to launch their kickstarter campaign soon. Check the draft kickstarter page and feel free to post your feedback. Projecta is an affordable desktop CNC machine optimized for making circuit boards in new innovative way. Projecta: A Solution For PCB Printing – [Link]
Siglent oscilloscope SDS1102X review
https://www.electronics-lab.com/review-siglent-oscilloscope-sds1102x/
Harry Baggen @ elektormagazine.com reviews the Siglent SDS1102X oscilloscope. Before we take a look at the instrument itself, I would like to say something about the characteristics of an oscilloscope for ‘small users’. What do you really need for your daily tasks? Even the cheapest models from Chinese manufacturers already have a sample rate of […]
Dual 90V/10A Unregulated Power Supply
https://www.electronics-lab.com/dual-90v10a-unregulated-power-supply/
This project is designed to provide symmetrical output unregulated, high voltage, high current for your demanding needs.  Right choice for Audio Amplifiers, Power Drivers, Motor Drivers etc Features Input – maximum 65 VAC center-tap, 10Amp Symmetrical unregulated, individually fused outputs 10A bridge rectifier on board LED indication for both the outputs PCB mounted LUGS for […]
https://www.electronics-lab.com/project/dual-90v10a-unregulated-power-supply/
This project is designed to provide symmetrical output unregulated, high voltage, high current for your demanding needs.  Right choice for Audio Amplifiers, Power Drivers, Motor Drivers. Features Input – maximum 65 VAC center-tap, 10Amp Symmetrical unregulated, individually fused outputs 10A bridge rectifier on board LED indication for both the outputs PCB mounted LUGS for connecting […]
Inkjet printing of text or photos as solar cells
https://www.electronics-lab.com/inkjet-printing-text-photos-solar-cells/
by Denis Meyer @ elektormagazine.com: Research is in progress at the University of Aalto in Finland on the development of a process for inkjet printing of text, photos or any illustrations as solar cells. The idea is not new but these researchers are covering new ground which will allow the use of ordinary materials. According […]
Combo sensors fit wearable devices
https://www.electronics-lab.com/combo-sensors-fit-wearable-devices/
Two combination accelerometer-gyro sensors, the KXG07 and KXG08 from Kionix, a subsidiary of Rohm, provide six axes of motion sensing. Both devices feature a configurable low-power architecture and a large 4096-byte FIFO buffer with timestamps for use in gaming systems, smart phones, and wearable devices. by Susan Nordyk  @ edn.com Unlike conventional sensor signal-detection methods […]
The IoT Project Builder “myDevices” Has Added Arduino Support
https://www.electronics-lab.com/iot-project-builder-mydevices-added-arduino-support/
“myDevices”, creators of IoT platform Cayenne, announced in a press release a partnership with Arduino to integrate Arduino support in their system. The partnership seems to be with Arduino SRL not with Arduino LLC. The currently supported Arduino boards, beside variety of sensors and actuators, are: Arduino Due Arduino Leonardo Arduino Mega Arduino Nano Arduino […]
