Iridium Certus 9704 Module and Development Kit with Microchip ATSAMD21J18A and U-blox MAX-M10S for Satellite IoT Applications
Iridium has introduced the Iridium Certus 9704 Module and Development Kit, powered by Iridium Messaging Transport (IMT) technology. This module, the smallest and most powerful from Iridium, is designed to support satellite IoT applications requiring real-time data analysis, analytics, and automated decision-making.
Satellite IoT Developer Kit
Iridium has introduced the Iridium Certus 9704 Module and Development Kit, powered by Iridium Messaging Transport (IMT) technology. This module, the smallest and most powerful from Iridium, is designed to support satellite IoT applications requiring real-time data analysis, analytics, and automated decision-making. It is ideal for use cases like predictive maintenance, diagnostics, telemetry monitoring, remote asset tracking, and command and control for aircraft, vehicles, and vessels.
The Iridium Certus 9704 simplifies data transfer with its IMT technology, which includes built-in topic-sorting to efficiently organize messages for delivery to the appropriate processing engine. This allows the module to handle various types of real-time data, including audio and images. IMT enables terminals to send and receive data over the Iridium network using standard terrestrial IoT/data transaction methods, streamlining the design, development, integration, and message management process.
Beyond IoT applications, IMT also supports machine-to-machine communications and over-the-top (OTT) services, such as email, group messaging, and weather forecasts, as well as other non-persistent data transactions. This makes the Iridium Certus 9704 a versatile solution for a broad range of satellite communication needs.
Satellite IoT Developer Kit front and back
Iridium Certus 9704 Satellite IoT Developer Kit specifications:
  • Iridium Certus 9704 Module
    • Max Message Size: 100 KB (including images & soundbites) via Iridium Messaging Transport (IMT) service
    • Command Interface: JSON-Based Serial Protocol for REST (JSPR)
    • Interfaces: Serial data, SPI, GPIOs, GNSS pass-through antenna (RF pin), digital interface
    • Dimensions: 42 x 31.5 x 3.8 mm
    • Weight: 12 grams
    • Operating Temperature Range: -40°C to +85°C
    • Certifications: FCC, EU/UK (CE), Canada (ISED); certifications in progress
  • Launch Pad Developer Board
    • MCU: Microchip ATSAMD21J18A Cortex-M0+ microcontroller, 48 MHz, 256 KB flash, 32 KB SRAM
    • Storage: MicroSD card slot
    • GNSS: U-blox MAX-M10S
    • Antenna: Helical Iridium Antenna with SMA right-angle adapter
    • USB: USB Type-C full-speed port for power and programming
  • MCU I/Os and Expansion
    • 3x UART for Iridium 9704 module, GNSS module, and expansion
    • 2x SPI for microSD card and expansion
    • 1x I2C
    • 22x digital I/O pins, 12x PWM pins, 8x analog inputs
    • Expansion headers: Adafruit FeatherWing headers, Arduino Shield headers, Qwiic/STEMMA QT connector, Arduino I2C (ESLOV) connector
    • External control: 10-pin connector for external control
    • Debugging: SWD connectors
  • Miscellaneous
    • Reset and user push-buttons
    • Power LEDs: Power, charging, Tx, user LED
    • Piezo buzzer
    • Power Management: 5V via USB-C port, 2-pin battery connector, Texas Instruments BQ24195L charger IC
  • Physical Specifications
    • Dimensions: 77 x 67 mm (including antenna connector)
    • Weight: 43 grams
    • Battery: 2,500 to 3,000 mAh Lithium-Ion battery
    • Accessories: USB-C cable, microSD card
 Iridium Certus 7900 IoT module
The Iridium Certus 9704 Development Kit is a complete testing platform that includes a motherboard, power supply, antenna, module, and software, all designed for use with the Iridium Certus 9704 Module. This kit exclusively supports Iridium Messaging Transport (IMT), a cloud-native messaging format optimized for the Iridium network, enabling efficient data transfer in industrial IoT applications. It offers a solution for developers to test and integrate satellite IoT capabilities with real-time data analysis.
In collaboration with Blynk, Iridium provides a streamlined platform for data visualization. The integration with the Arduino IDE and Blynk IoT Cloud allows developers to transfer data to and from a customizable dashboard. This dashboard communicates with the Iridium satellite network via Blynk’s cloud platform, enabling real-time data visualization and remote control through both web and mobile interfaces. The development kit offers an all-in-one solution for creating and managing satellite IoT applications. Further details are available on the GitLab Iridium 9704 Launch Pad and Blynk Cloud dashboard pages.
The Iridium Certus 9704 Satellite IoT Developer Kit is priced at $499. To order the kit, customers need to complete a form available on the product page. For more information, it is recommended to review the product page, GitLab documentation, the press release, and the GitLab-hosted reference materials.
