MAIWO K2024 USB4 NVMe SSD Enclosure with ASMedia ASM2464PDX Controller and 1-to-3 SSD Cloning
The MAIWO K2024 is a USB4 NVMe M.2 SSD enclosure that supports up to four M.2 NVMe SSDs ranging from 2230 to 2280 sizes. It features a USB4 interface, enabling data transfer speeds of up to 40Gbps, significantly outperforming traditional USB 3.0 enclosures.
The MAIWO K2024 is a USB4 NVMe M.2 SSD enclosure that supports up to four M.2 NVMe SSDs ranging from 2230 to 2280 sizes. It features a USB4 interface, enabling data transfer speeds of up to 40Gbps, significantly outperforming traditional USB 3.0 enclosures. The device also includes a 1-to-3 SSD duplicator function, allowing users to clone drives without a host system.
Built with an aluminum enclosure, the MAIWO K2024 provides efficient heat dissipation, making it suitable for high-performance workloads such as video editing and data-intensive applications. It supports M-key and B+M-key NVMe SSDs with a maximum storage capacity of 8TB. The enclosure is compatible with systems featuring USB4 and Thunderbolt 4 ports, ensuring broad device compatibility.
MAIWO K2024 USB4 enclosure specifications:
  • Chipset: ASMedia ASM2464PDX USB4/Thunderbolt 3 to PCIe/NVMe controller with USB 3.2/3.1/3.0/2.0 backward compatibility
  • Storage:
    • Up to 4x M.2 NVMe M-Key SSDs
    • Supports M.2 NVMe SSDs in 2230, 2242, 2260, and 2280 form factors
    • Supports up to 32TB storage (4x 8TB SSDs)
  • USB: USB4 interface with 40Gbps transfer rate
  • Misc:
    • Up to 16Gbps transfer rate with a single SSD (PCIe Gen4 x1)
    • Up to 10Gbps transfer rate per SSD when using four SSDs
    • 1-to-3 offline SSD cloning without a computer
    • The power button and clone button
    • SSD status LED indicators and four LEDs for cloning status
    • Integrated cooling system with thermal pads and built-in fan
    • Magnetic cover for easy SSD installation and removal
  • Power Supply: 12V/5A (60W) via DC jack
  • Dimensions: 145 x 145 x 32mm (Aluminium Alloy case)
The M.2 USB4 enclosure ships with six silicone plugs, four silicone thermal pads, four aluminum plates, a USB Type-C to Type-C cable, a 60W power adapter, and a power cord. Supported Operating Systems include Windows, Mac OS, Linux, and iOS.
The MAIWO K2024 is currently available on Banggood for $195.99 as part of a flash sale, with its regular price set at $249.99. It can also be found on AliExpress for $283.06 with free shipping.
