Voice Modulator (Sound Effects – Funny Sound)
https://www.electronics-lab.com/project/voice-modulator-sound-effects-funny-sound/
Voice Modulator project is designed around HT8950A to provide two special sound effects viz. Vibrato & Robot. Description This project provides two special effects: vibrato and robot. The vibrato effect is generated by alternating the frequency of an input signal up and down at a rate of 8Hz. The robot function, on the other hand, […]
Tape Head Pre-Amplifier
https://www.electronics-lab.com/project/tape-head-pre-amplifier/
This project is a tape head Pre-Amplifier circuit. Description The circuit is built around a popular Sanyo stereo head preamp IC LA3161. Low electrical signals from the playback heads are fed to pins 1 and 8 of IC1 via DC decoupling capacitors, respectively. Components between pins 2 and 3 and pins 6 and 7 provide […]
120 Seconds Voice Record – Play Back
https://www.electronics-lab.com/project/120-seconds-voice-record-play-back/
This project is a message recording board capable of recording 120 secs of audio. Description This project is designed around ISD25120 which can store 120 Seconds audio. Recording and playback operations are controlled with tact switches. The kit has an onboard microphone and LED to indicate the functions of Play and Recording. IC has a […]
20 Seconds Voice Record – Playback
https://www.electronics-lab.com/project/20-seconds-voice-record-playback/
This project is a message recording board capable of recording 10 to 20 secs depending on audio quality. Description This project has been designed around Winbonds ISD1616 IC (SMD) IC, which is fully integrated, single-chip, single message voice record and playback device ideally suited to a variety of electronics systems, Message duration is user selectable […]
RIAA Corrector
https://www.electronics-lab.com/project/riaa-corrector/
Description To listen old vinyl LP’s in a correct sounding on a sassy with dynamic cartridge you need a circuit, named RIAA corrector. This circuit you can find in old amps, but it isn’t embedded in home cinema equipments or amplifiers can be obtained nowadays. Also, if you want to archive your vinyl LP’s in […]
Cheap Audio Booster
https://www.electronics-lab.com/project/cheap-audio-booster/
Universal Preamplifier
https://www.electronics-lab.com/project/universal-preamplifier/
Description Most audio amplifier systems must have preamplifiers with many different characteristics. These include high-gain linear response for magnetic microphones, low-gain linear response for tuners, and high-gain RIAA equalization for magnetic phone cartridges. To meet this broad requirement, most amplifier designers include a single universal preamplifier circuit. Basically a high-gain linear amplifier, its characteristics can […]
Portable Audio Amplifiers
https://www.electronics-lab.com/project/portable-audio-amplifiers/
Description Above circuits are based on TEA2025 is a monolithic integrated audio amplifier in a 16-pin plastic dual in line package manufactured by UTC .Circuit has an Internal Thermal Protector. It is designed for portable cassette players and radios. You can also use it as your PC Audio Amplifier. A few external components required to […]
600W Audio Amplifier
https://www.electronics-lab.com/project/600w-audio-amplifier-2/
Description The circuit is based around {LM4702} manufactured by NATIONAL semiconductors & {MJ11029-MJ11028} by ON semiconductors It is a high fidelity audio power amplifier. Designed for demanding consumer and pro-audio applications. You can also use this circuit with AV receivers, Audiophile power amps, Pro Audio High voltage industrial applications etc Amplifier output power maybe scaled […]
5-Band Graphic Equalizer
https://www.electronics-lab.com/project/5-band-graphic-equalizer/
Description This complete high quality, low noise 5-BAND GRAPHIC EQUALIZER circuit is based around Monolithic Linear integrated circuit LA3600 manufactured by SANYO. This circuit is very easy to build and has good Quality. You can use it with Portable component stereos, tape-recorders, radio-cassette recorders, car stereos etc… It is On-chip one operational amplifier. 5-band graphic […]
