TPS7B86-Q1 Automotive LDO Linear Regulator
https://www.electronics-lab.com/tps7b86-q1-automotive-ldo-linear-regulator/
Texas Instruments’ adjustable regulator features power-good and is designed for powering always-on components in standby systems Texas Instruments’ TPS7B86-Q1 is a low-dropout (LDO) linear regulator that is designed to connect to the battery in automotive applications. The device has an input voltage range extending to 40 V, which allows the device to withstand transients (such […]
Texas Instruments LDC3114/LDC3114-Q1 Inductance-to-Digital Converter
https://www.electronics-lab.com/texas-instruments-ldc3114-ldc3114-q1-inductance-to-digital-converter/
Texas Instruments LDC3114/LDC3114-Q1 Inductance-to-Digital Converter is an inductive sensing device that enables touch button design for human-machine interface (HMI) on a wide variety of materials. This feature is done by measuring small deflections of conductive targets using a coil that can be implemented on a small printed circuit board (PCB) located behind the panel. This […]
Infineon Technologies MOTIX™ BTN9990LV Motor Control IC
https://www.electronics-lab.com/infineon-technologies-motix-btn9990lv-motor-control-ic/
Infineon Technologies MOTIX™ BTN9990LV Motor Control IC contains one p-channel high-side MOSFET and one n-channel low-side MOSFET with an integrated driver IC in one package. The interfacing to a microcontroller is made easy by the integrated driver IC and the EMI is minimized due to the p-channel high-side switch. This integrated driver IC features logic-level […]
DIGI ConnectCore® 8M Nano System-On-Modules (SOM)
https://www.electronics-lab.com/digi-connectcore-8m-nano-system-on-modules-som/
DIGI ConnectCore® 8M Nano System-On-Modules (SOM) are designed for industrial reliability and the 10+ year product lifecycles of embedded devices. These SOMs feature up to 4x power efficient Arm® Cortex®-A53 cores and 1x Cortex-M7 core that minimizes power consumption while maintaining a high standard of performance. The 8M Nano SOMs feature TrustFence® for critical security and […]
Instrumems Launches Into Flow Sensor Market With a Breakthrough Multi-sense Solution
https://www.electronics-lab.com/instrumems-launches-into-flow-sensor-market-with-a-breakthrough-multi-sense-solution/
Instrumems announced its formal entry into the flow sensor market with a breakthrough solution that offers multi-sense capabilities. The company is an innovative spin-off of Princeton University research developed by Professor Marcus Hultmark and Dr. Gilad Arwatz. Instrumems was founded to advance flow sensing capabilities and broaden adoption into more markets such as medical, IoT, […]
FWS-2277: Compact Network Solution for Small Office Deployments
https://www.electronics-lab.com/fws-2277-compact-network-solution-for-small-office-deployments/
AAEON, an industry leader in network white box solutions, announces the FWS-2277 compact desktop network appliance. Not much larger than typical consumer-grade network switches, the FWS-2277 delivers the performance and functionality to bring network functions to Small Office/Home Office (SOHO) deployments, including Unified Threat Management (UTM), VPN, and Next-Generation Firewall (NGFW). With many offices and […]
Infineon Technologies BTG7090-2EPL PROFET™ Load Guard
https://www.electronics-lab.com/infineon-technologies-btg7090-2epl-profet-load-guard/
Infineon Technologies BTG7090-2EPL PROFET™ Load Guard is a smart high-side power switch, providing protection functions and enhanced diagnostic capabilities. The BTG7090-2EPL is equipped with adjustable overcurrent limitations to offer high reliability for protecting the system. This feature ensures that PCB traces, connectors, and loads are protected in case of a short circuit to ground. The BTG7090-2EPL […]
Texas Instruments TPSM265R1 Power Module with Ultra-Low IQ
https://www.electronics-lab.com/texas-instruments-tpsm265r1-power-module-with-ultra-low-iq/
Texas Instruments TPSM265R1 Power Module with Ultra-Low IQ is a compact, easy-to-use module that fully integrates a controller, MOSFETs, and an output inductor. The TPSM265R1 Power Module operates over a wide input voltage range up to a maximum continuous input voltage of 65V. The Power Module is designed to quickly and easily implement a power […]
5G-Ready Embedded Computing Systems with 11th Gen Intel Core Processors
https://www.electronics-lab.com/5g-ready-embedded-computing-systems-with-11th-gen-intel-core-processors/
IBASE Technology Inc., recognized as a world leader in the design and manufacture of industrial motherboards and embedded computing systems, has launched the ASB200-953 compact box PC housing IBASE’s IB953 3.5-inch SBC powered by 11th Gen Intel® Core™ i7-1185G7E, i5-1145G7E and i3-1115G4E processors (formerly Tiger Lake) with a 15W TDP threshold. Aimed at smart applications […]
New R&S LCX strengthens Rohde & Schwarz portfolio for high performance impedance measurements
https://www.electronics-lab.com/new-rs-lcx-strengthens-rohde-schwarz-portfolio-for-high-performance-impedance-measurements/
With a completely new family of high performance LCR meters, the frequency range of impedance measurements provided by Rohde & Schwarz test equipment is dramatically extended to cover AC components operating from 4 Hz to 10 MHz, supporting all practical applications. The R&S LCX family of LCR meters serves all established impedance measurements plus specialized […]
