Arduino Announces Nicla Vision Board for Computer Vision Applications at Edge
https://www.electronics-lab.com/arduino-announces-nicla-vision-board-for-computer-vision-applications-at-edge/
Today, famous Italian electronic embedded device manufacturer, Arduino launched an ultra-compact dual-core Nicla vision board for computer vision applications deployed at the edge. The minimalistic design gets a 2MP color camera that will aid in image detection, facial recognition, automated optical inspection, vehicle plate reading and many other vision-based applications. Nicla’s series of boards has […]
CLEAR is Customizable and Programmable ASIC by ChipIgnite
https://www.electronics-lab.com/clear-is-customizable-and-programmable-asic-by-chipignite/
Efabless has launched a 100% open-source FPGA chip CLEAR, built on Caravel – an open-source ASIC platform provided as a base (SoC) and offering an end-to-end open design, right down to the CPU core. The explanation of the product is simple and quite relatable to the maker’s community – “create your own ASIC.” The process […]
CUI Devices Launches New Circular Connectors Product Line
https://www.electronics-lab.com/cui-devices-launches-new-circular-connectors-product-line/
CUI Devices’ Interconnect Group today announced the addition of circular connectors to its connectors product portfolio. Available in M12 connector types, CUI Devices’ CDM12 family offers a range of male or female versions with contact position options of 3, 4, 5, 8, and 12 pins. As A-coded devices that support 1 Gbit Ethernet, all M12 […]
FWS-2280: Offering Connectivity to a Variety of Network Structures
https://www.electronics-lab.com/fws-2280-offering-connectivity-to-a-variety-of-network-structures/
AAEON, experts in white box solution and network appliance manufacturing, have once again partnered with flexiWAN, a leading provider of open-source SASE and SD-WAN software. Part of this partnership has prompted the certification of the FWS-2280, allowing customers access to a wider range of deployment options. Powered by the latest Intel® Atom™ x6000E Processor (formerly […]
onsemi NTHL045N065SC1 Silicon Carbide (SiC) MOSFET
https://www.electronics-lab.com/onsemi-nthl045n065sc1-silicon-carbide-sic-mosfet/
onsemi NTHL045N065SC1 Silicon Carbide (SiC) MOSFET uses a completely new technology that provides superior switching performance and high reliability compared to Silicon. This compact chip-sized MOSFET is designed with low ON resistance and ensures low capacitance and gate charge. The NTHL045N065SC1 MOSFET features high efficiency, faster-operating frequency, increased power density, reduced EMI, and reduced system […]
Monolithic Power Systems (MPS) MP6610 55V 3A Half-Bridge Power Drivers
https://www.electronics-lab.com/monolithic-power-systems-mps-mp6610-55v-3a-half-bridge-power-drivers/
Monolithic Power Systems (MPS) MP6610 55V 3A Half-Bridge Power Drivers offer current measurement and regulation features in a small pin package. The MP6610 features up to 3A of output current across a wide 4V to 55V input voltage range is ideal for driving brushed DC motors, solenoids, and other loads. The device has an internal current-sense […]
DC2412-UPSP2 – DC/DC Supply with UPS function is Open Frame 60W / 16-32VDC / 12VDC / 5A / 480F Supercaps
https://www.electronics-lab.com/dc2412-upsp2-dc-dc-supply-with-ups-function-is-open-frame-60w-16-32vdc-12vdc-5a-480f-supercaps/
Uninterruptible 12VDC power supply! Powerful DC UPS module with maintenance-free Supercaps and wide-range input 16… 32VDC The robust DC2412-UPSDP2 is a maintenance-free 12VDC emergency power supply in open frame design. To protect against voltage fluctuations, flicker, voltage drops or failures in the supply voltage, the DC UPS modules are equipped with Supercaps as energy storage […]
Siglent SDG7000A 1GHz Advanced Arbitrary Waveform Generator Series
https://www.electronics-lab.com/siglent-sdg7000a-1ghz-advanced-arbitrary-waveform-generator-series/
The SiglentSDG7000A Series of 2-channel AWGs offers models in maximum frequencies of 350MHz, 500MHz, and 1GHz, with 5Gsa/s sampling, 14-bit vertical resolution, and a memory depth of 512Mpts.  Arbitrary waveforms are generated with sample rates from 0.01Sa/s to 2.5GSa/s, and vector signals at 500MSa/s. A wide variety of test signals can be generated, with the option […]
Add PlainDAQ Carrier Board to Raspberry Pi Pico for Analog Functionality
https://www.electronics-lab.com/add-plaindaq-carrier-board-to-raspberry-pi-pico-for-analog-functionality/
We have already come across tens if not hundreds of Raspberry Pi’s in-house silicon tapeout RP2040 integrated boards. The RP2040 was first seen in Raspberry Pi’s own microcontroller board– RPi Pico that features a dual-core Arm Cortex-M0+ processor with 264KB internal RAM and support for up to 16MB of off-chip flash storage. To add analog […]
Codasip announces two RISC-V-based embedded cores for AI/ML edge customizations
https://www.electronics-lab.com/codasip-announces-two-risc-v-based-embedded-cores-for-ai-ml-edge-customizations/
Last week, Codasip, known for edge tools and IPs, has announced RISC-V-based embedded cores for AI/ML edge customizations – L31 and L11 RISC-V processor cores. In addition to the existing low-power embedded cores, the L31 and L11 are aimed towards easing the customization process using Codasip Studio tools for deep neural network applications with low-power […]
