Arduino Real Time Clock and temperature Monitor using the DS3231 RTC and 3.2″ Color TFT display
https://www.electronics-lab.com/project/arduino-real-time-clock-and-temperature-monitor-using-the-ds3231-rtc-and-3-2-color-tft-display/
Time is a critical element of our existence that will never get old, and with technology, we can find better and more intuitive ways to measure it. In one of our past tutorials, we looked at how the DS3231 real time clock module can be used with Arduino to display time on a 16×2 LCD […]
Via Unveils AI System Powered by Qualcomm®️ Snapdragon 820E
https://www.electronics-lab.com/via-unveils-ai-system-powered-by-qualcomm%ef%b8%8f-snapdragon-820e/
VIA Technologies has unveiled a mini-PC that runs Android 8.0 on a Snapdragon 820E named the VIA ALTA DS 3 Edge AI. The VIA ALTA DS 3 Edge AI operates an Android 8.0 “Oreo” BSP for the Snapdragon 820E, which also powers the Arrow/Qualcomm DragonBoard 820c SBC. The Snapdragon 820E is a close replica, variant […]
Malleable Micro – Batteries for Wearable Technology
https://www.electronics-lab.com/malleable-micro-batteries-for-wearable-technology/
A new innovative technology for wearables is taking over the market of future technology. Wearables are portable systems that house sensors to make measurements from the wearer’s body. Powering these wearables requires flexible batteries that adapt to the specific material, and deliver the power needed for the system. Fraunhofer Institute for Reliability and Microintegration IZM […]
ANTENNINO – Arduino-RF multifunction board
https://www.electronics-lab.com/antennino-arduino-rf-multifunction-board/
Antennino (the name Antennino is the combination of Antenna and Arduino) is a low-cost and low-power board based on the Atmel chip, then 100% compatible with the traditional Arduino IDE. The board integrates sensors and bus communication to get external information, as well as a wireless link to communicate with the outside. <span title=”A seconda […]
TPSM84824 – 4.5V to 17V Input, 0.6V-10V Output, 8A Power Module
https://www.electronics-lab.com/tpsm84824-4-5v-to-17v-input-0-6v-10v-output-8a-power-module/
The TPSM84824 power module is an easy-to-use integrated power supply that combines an 8-A DC/DC converter with power MOSFETs, a shielded inductor and passives into a small form-factor QFM package. This power solution allows as few as six external components while maintaining the ability to adjust key parameters to meet specific design requirements. Ultra-fast transient […]
Variscite Releases Headless Version of Its Linux-friendly DART-6UL CoM
https://www.electronics-lab.com/variscite-releases-headless-version-of-its-linux-friendly-dart-6ul-com/
Variscite is releasing another pin-compatible version of their 50 x 25mm DART-6UL computer-on-module. This time it will be loaded with NXP’s headless new i.MX6 ULZ variant of the single Cortex-A7 core i.MX6 UL. This yet unnamed module lacks display or LAN support. It is described as “a native solution for headless Linux-based embedded products such as IoT devices and smart […]
AVR MCUs now beta supported in MPLAB X IDE
https://www.electronics-lab.com/avr-mcus-now-beta-supported-in-mplab-x-ide/
Microchip has launched MPLAB X IDE version 5.05 which beta supports the majority of AVR MCUs – allowing developers to easily incorporate AVR MCUs into any application. [via] Further support for additional AVR MCUs will be provided in MPLAB versions. AVR support will continue to be added to Atmel Studio 7 and Atmel START for […]
Space Limitations Are No Constraint for AAEON’s Latest IoT Gateway
https://www.electronics-lab.com/space-limitations-are-no-constraint-for-aaeons-latest-iot-gateway/
(Taipei, Taiwan – October 4, 2018) – AAEON, a leading developer of advanced IoT solutions, releases the UPC-GWS01, the world’s smallest x86-based industrial computer. Just 91mm x 67mm x 55.2mm in size, the system is highly versatile and boasts onboard storage, WiFi, Bluetooth, and a comprehensive I/O interface. The UPC-GWS01, which has already won a […]
200V DC High voltage pocket generator
https://www.electronics-lab.com/200v-dc-high-voltage-pocket-generator/
Aki made this DIY pocket HV generator: There are times you find yourself looking for a relatively high voltage (100V to 200V often in my case) but low current DC power supply. I have zener diodes that are higher than 30V, which makes the lab supply useless, and filament LEDs with forward voltage over 60V. […]
NANO-GLX- IEI’s Low TDP SBC Designed for IoT applications
https://www.electronics-lab.com/iei-low-tdp-sbc-designed-for-iot-applications/
IEI is rejuvenating the G-Series with a 165 x 115mm EPIC form factor SBC named the Nano-GLX, which runs on the dual-core G-Series LX and has TDP ratings as low as 4.5W. This is the latest, and the most power efficient of the G-Series family. This is the pioneer G-Series based EPIC board. OS support […]
