An introduction to GPIO Settings
https://www.electronics-lab.com/introduction-gpio-settings/
Working with microcontrollers means managing GPIO pins at some point. Many configurations have been developed for modern microcontrollers which can lead to some “fancy” terms that may confuse programmers. Its important to understand all of this to avoid confusion and errors while programming. First, some terms need to be understood. GPIO pins have tri-state logic […]
my-ssd1306 an HTML interface to SSD1306 OLED display
https://www.electronics-lab.com/ssd1306-html-interface-ssd1306-oled-display/
A board that transforms your SSD1306 OLED Display into an RS232 monitor with HTML built-in parser. Now live on kickstarter. My-SSD1306 allows you to connect any device equipped with RS232 to the I2C SSD1306 displays. My-ssd1306 board should be put between the RS232 source and the I2C SSD1306 target. Two series of connection pins are […]
LoRa-to-Ethernet Gateway
https://www.electronics-lab.com/lora-ethernet-gateway/
A WIZ750SR based device that allows sending and receiving messages over LoRa and LoRaWAN. I got some LoRa modules with SPI communication interface. One of the options it would have been to connect them to my Raspberry Pi. But, I didn’t really like the idea because I already have some stuff connected to my Raspberry […]
High Efficiency MPPT Solar Charger
https://www.electronics-lab.com/high-efficiency-mppt-solar-charger/
A 75 watt MPPT Solar Charger with tons of features. Efficiency > 97%, USB interface, data logging, 2 USB charging ports and much more…by Lukas Fässler This is an open source project that I’ve been working on for several years now. From its modest beginnings it has evolved to a rather sophisticated device with a […]
AAEON’s Intel Core-Powered PICO-KBU4 will Help Your Applications Take Flight
https://www.electronics-lab.com/aaeons-intel-core-powered-pico-kbu4-will-help-applications-take-flight/
(Taipei, Taiwan – June 19, 2018) – AAEON, a leading developer of embedded controllers, announces the launch of the PICO-KBU4, a rugged and expandable compact SBC with the capacity to revolutionize the field of robotics and open up the drone market for x86 embedded controllers. Fitted with a 7th Generation Intel® Core™ i processor (formerly […]
The Internet of Arduino Challenge – Build an IoT Arduino Powered Product and you could win up to $50,000
https://www.electronics-lab.com/internet-arduino-challenge-build-iot-arduino-powered-product-win-50000/
The Arduino has been the number one development board for hackers, hobbyists, engineers and even product designers for a while. The Arduino Movement has powered a powerful maker’s community where anyone that can think of an idea can quickly make it happen, and this has birthed several Arduino powered products. The Internet of Things is […]
Linux Powered Apalis iMX8 SoM Built On NXP’s QuadMax
https://www.electronics-lab.com/toradex-launches-linux-powered-apalis-imx8-som-built-nxps-quadmax/
Toradex, a Swiss embedded technology firm announced the world’s first embedded board built on NXP’s i.MX8 QuadMax back in Mar. 2017. Recently, Toradex has opened early access for selected customers to the SODIMM-style Apalis iMX8 module. A sign-up form offers the potential for newcomers to get an early look. This new Linux powered, wireless-enabled Apalis iMX8 uses the […]
Nvidia’s Jetson Xavier is an AI Computer boasting a $10,000 Worth Of Power For Your Machines and Robots
https://www.electronics-lab.com/nvidias-jetson-xavier-ai-computer-boasting-10000-worth-power-machines-robots/
NVIDIA Jetson Xavier is the latest addition to the Jetson platform. It’s an AI computer for autonomous machines, delivering the performance of a GPU workstation in an embedded module for a consumption under 30W. With multiple operating modes at 10W, 15W, and 30W, Jetson Xavier has greater than 10x the energy efficiency and more than […]
PCBWay 2nd Edition of PCB Design Competition – The Pride Of A Maker
https://www.electronics-lab.com/pcbway-2nd-edition-pcb-design-competition-pride-maker/
Late of last year, PCBWay, a leading manufacturer in PCB and PCBA, announced the first of it’s kind PCB design contest in close partnership with SpainLabs (Well-known Spanish electronic forum) with amazing prices and even cash prices was offered to some of the best PCB and Product design from several competitors which all ended up in […]
uArt- A small Solution For a Big Problem
https://www.electronics-lab.com/uart-small-solution-big-problem/
Coming soon to Crowd Supply is the ultimate USB-UART converter. μArt is a device that offers safe and reliable USB-to UART conversion. The voltage levels, electric potentials, and communication speeds are no longer a concern, and it can be used for data exchange or for Programming Arduino or ESP. μArt was designed for enthusiasts and […]
