Pool Buddy – Monitor your pool water quality
https://www.electronics-lab.com/pool-buddy-monitor-pool-water-quality/
Monitor and log water quality (pH & ORP) and temperature from everywhere. Instead of performing regular checks with tester kits to maintain adequate pH and chloride levels in our (small) swimming pool, I decided to build a project that monitors the water continuously and registers the data online so I can easily inspect it. Pool […]
AMY Robotics, Multifunctional Autonomous Mobile Robots
https://www.electronics-lab.com/amy-robots-multifunctional-autonomous-mobile-robots/
Earlier this month, the multifunctional autonomous mobile robots “AMY A1” and “AMY M1” had been launched as the first batch of products of AMY Robotics. Amy Robotics is an innovative technology company focusing on research and development of service robots that enhance quality of life with robotic technologies, products and services. Both AMY Robots are intelligent mobile-service robots characterized […]
Bosch glue pen teardown
https://www.electronics-lab.com/bosch-glue-pen-teardown/
electrobob @ electrobob.com tipped us with his latest teardown of a battery powered Bosch glue pen. He writes: On the right side we can see the fuse and a IRF3711Z 6mΩ 20V HEXFET driving the heating element. At the glue melting end there is no temperature sensor, they are probably relying on the positive thermal […]
Pastilda: Open-source Hardware Password Manager
https://www.electronics-lab.com/pastilda-open-source-hardware-password-manager/
Pastilda is an open-source hardware password manager, designed to manage your credentials in a handy and secure way. Pastilda works as a middleman between your computer and keyboard. It provides easy and safe auto-login to your OS, bank accounts, mailboxes, corporate network or social media. Pastilda stores encrypted passwords in its memory. You can request […]
Integrated Load Switches versus Discrete MOSFETs
https://www.electronics-lab.com/integrated-load-switches-versus-discrete-mosfets/
Alek Kaknevicius @ ti.com discuss about load switches and the advantages of intergrated switches over discrete ones. The most common approach to load switching solutions is to use a Power MOSFET surrounded by discrete resistors and capacitors; however, in most cases using a fully integrated load switch has significant advantages. While both discrete and integrated […]
Arduino Easy Module Shield Tutorial – Is this the best Arduino Shield
https://www.electronics-lab.com/arduino-easy-module-shield-tutorial-best-arduino-shield/
Our friends on educ8s.tv uploaded a new Arduino tutorial. Let’s check it out. Dear friends welcome to another Arduino Tutorial! Today we are going to take a first look at this very promising new shield for Arduino, the Arduino Easy Module Shield! Also we are going to build a couple of projects with it. Let’s […]
Water Out Of Thin Air
https://www.electronics-lab.com/water-thin-air/
Due to the advances of technology, we are able now to produce water out of thin air without using the resources usually applied like mains utilities. Such approach would be perfect in places that lack natural resources like deserts. Working from the effects of direct solar radiation, a group of researchers at UC Berkeley had designed such […]
Soldering pen for Weller RT tips with OLED display
https://www.electronics-lab.com/soldering-pen-weller-rt-tips-oled-display/
vlk @ hackaday.io build a very nice soldering pen with a OLED display. I found some projects where is used Weller soldering tips designed for WMRP soldering iron with standard 3.5mm jack and inside the tip is also thermocouple for sensing temperature. These tips are not so cheap but the quality is really great, especially […]
Digital Battery Operated Powersupply
https://www.electronics-lab.com/digital-battery-operated-powersupply/
ThomasVDD @ instructables.com writes: A while back I built a powersupply from an old ATX PSU, and while it works great, I wanted to step up my game with a digital powersupply. As already said, it is powered by batteries (2 lithium cells to be precise), and it can deliver a maximum of 20 V […]
Orthrus – SD card secure RAID USB storage
https://www.electronics-lab.com/orthrus-sd-card-secure-raid-usb-storage/
Nick Sayer @ hackaday.io build a SD card RAID USB storage board. He writes: This project is a hardware mechanism to provide secure “two man control” over a data store. It is a USB microSD card reader, but it requires two cards. The data is striped in the style of RAID 0, but the data […]
