Efinix Ti125 FPGA Targets Compact, Power-Sensitive Edge AI
The Ti125 packs 123K logic elements, sub-milliwatt static power, 2.5 Gbps MIPI I/O, and hardware SEU correction into a footprint as small as 5.5 × 5.5 mm.
Efinix has expanded its Titanium architecture with the launch of the Titanium Edge family, a collection of FPGAs engineered specifically for edge AI workloads where power budgets are tight, board space is scarce, and reliability cannot be compromised. The flagship of the new lineup, the Ti125, arrives with 123,000 logic elements and a hardware profile tailored to the kind of real-world constraints that designers working at the edge know all too well.
Power, Footprint, and Integration
Static power consumption has long been a sticking point for always-on edge deployments, and the Ti125 addresses this with a 50% reduction over the existing Titanium family, which is already a benchmark for FPGA power efficiency. The result is a device that can sustain continuous AI inference in thermally constrained enclosures without demanding elaborate cooling solutions.
The SiP variant of the Ti125, designated Ti125 M225S4F4, takes the integration story further by combining the FPGA die with 512 Mb of HyperRAM and SPI boot flash in a single package. Compared to an equivalent discrete design, this arrangement shrinks PCB footprint by up to 60%, with the smallest packages measuring just 5.5 × 5.5 mm. For engineers working on embedded vision modules, IoT gateways, or compact robotics platforms, that kind of density is a meaningful design enabler.
High-Speed I/O and Multi-Sensor Pipelines
Vision-driven edge applications typically demand high-bandwidth connectivity to one or more image sensors, and the Ti125 meets that need through its HSIO2 architecture. The device supports MIPI interfaces with x1, x2, x4, and x8 data-lane configurations, reaching up to 2.5 Gbps throughput. High-speed and low-power MIPI modes are both supported, and the dynamic power reduction built into HSIO2 for MIPI receivers helps keep the overall system energy envelope in check. DDR3L memory interfaces operate at up to 1,333 Mbps, rounding out the connectivity picture for applications that need both fast sensor ingestion and local data buffering.
Critically, these capabilities arrive without requiring external bridge components, a detail that simplifies board design and reduces BOM complexity in multi-camera pipelines for applications ranging from smart surveillance to medical imaging systems.
Industrial smart cameras are among the Ti125’s primary target applications, where low static power and high-speed MIPI I/O combine to enable compact, always-on vision systems. Image used courtesy of Adobe Stock
Reliability, Security, and the Broader Ecosystem
Radiation-induced soft errors are a genuine concern in aerospace, medical, and outdoor industrial deployments. The Ti125 integrates a dedicated hardware SEU scrubbing engine that continuously monitors and corrects configuration memory, guarding against bit flips without relying on software intervention. This is a meaningful distinction from approaches that depend on periodic readback or user-initiated correction routines.
Security variants of the Ti125 and Ti95, planned for sampling in Q4 2026, will extend the platform with post-quantum-ready cryptography aligned with CNSA 2.0 guidelines. The feature set includes ML-DSA-65 signature authentication, AES-256-GCM encryption, PUF-based key derivation, secure boot with a chain of trust, and full key lifecycle management, including rotation, revocation, and anti-rollback protection. JTAG disable and secure debug round out the hardened configuration.
All Titanium Edge devices are supported by the Efinity IDE, providing a complete RTL-to-bitstream flow. The broader Efinix ecosystem also includes Sapphire SoC solutions that pair embedded RISC-V cores with FPGA fabric for AI acceleration, as well as standalone post-quantum cryptography accelerators that support ML-DSA, ML-KEM, SHA-3, and SHAKE.
The Ti125 is sampling now, with the SiP variant expected in August 2026 and higher-capacity or security-enhanced options following in Q4 2026. For engineers designing next-generation vision systems, compact embedded platforms, or safety-critical edge devices, the combination of ultra-low static power, integrated memory, high-speed MIPI connectivity, and hardware-level resilience makes the Titanium Edge family worth a close look—particularly in sectors like autonomous vehicles, medical imaging, industrial automation, and smart surveillance where the margin for error is effectively zero.
