Switching Theory
https://www.electronics-lab.com/article/switching-theory/
Switching Theory The switching theory uses switches in order to understand the operation and functioning of digital logic gates and circuits. The switching theory helps in developing better theoretical knowledge and concepts of digital logic circuits involving logical inputs producing a specific relational logical output. As it has already been discussed that Boolean data type […]
BIVROST® LITE5 – a breakthrough IoT and edge computing enterprise single-board platform
https://www.electronics-lab.com/bivrost-lite5-a-breakthrough-iot-and-edge-computing-enterprise-single-board-platform/
BIVROST® Lite5 is an extremely compact industrial computer that breaks through I/O bandwidth barriers for the most demanding applications, including machine vision and the edge computing work model based on neural network accelerators. Using Intel Xeon and Intel Core processors and supporting 5 M.2 slots, only 5 inches in size (mini-STX standard), the data processing […]
Portescap Demonstrates Wide Variety of Miniature Medical Motor Technologies
https://www.electronics-lab.com/portescap-demonstrates-wide-variety-of-miniature-medical-motor-technologies/
Portescap returns in person to Medical Design & Manufacturing West 2022 for the first time since 2020 to discuss the benefits of its medical motors, which power surgical hand tools, medical pumps, lab automation and ventilation equipment, and several other medical devices. Portescap will demo its Surgical Motor Solutions — featuring sterilizable motors and controllers […]
Monolithic Power Systems (MPS) MP2733 Battery Charger Management Devices
https://www.electronics-lab.com/monolithic-power-systems-mps-mp2733-battery-charger-management-devices/
Monolithic Power Systems (MPS) MP2733 Battery Charger Management Devices are highly integrated switchmode battery charger management devices for single-cell Li-ion or Li-polymer batteries. These devices work with Narrow Voltage DC (NVDC) system power path management. The MP2733 devices feature a low-impedance power path that optimizes efficiency, reduces battery charging time, and extends battery life. These devices support a wide […]
Analog Devices Inc. LTC4249 Dual Electronic Circuit Breaker (ECB)
https://www.electronics-lab.com/analog-devices-inc-ltc4249-dual-electronic-circuit-breaker-ecb/
Analog Devices Inc. LTC4249 Dual Electronic Circuit Breaker (ECB) provides independent overcurrent protection to a pair of loads. Each channel has a precision enable input, current monitor output, and ready status output. A single resistor configures the ECB threshold. If either channel detects an overcurrent condition, the corresponding breaker disconnects the input from the load. […]
Infineon CoolSiCTM MOSFET for 650 V, 1200 V, and 1700 V at Rutronik
https://www.electronics-lab.com/infineon-coolsictm-mosfet-for-650-v-1200-v-and-1700-v-at-rutronik/
Infineon’s CoolSiC™ MOSFETs use an optimized, state-of-the-art trench semiconductor process that enables both the lowest losses in the application and the highest reliability in operation. The products, with voltage classes of 1700 V, 1200 V, and 650 V and forward resistances from 27 mΩ up to 1000 mΩ, are ideally suited for integration in applications […]
DIY CircuitMess Chatter Uses LoRa Connectivity for Text Messaging
https://www.electronics-lab.com/diy-circuitmess-chatter-uses-lora-connectivity-for-text-messaging/
Satellite messaging devices have been around for several decades and with the introduction of various energy-efficient wireless technologies, many hobbyists and startups designed smartphone-like messaging devices, one being CircuitMess’ Chatter that uses LoRa communication and does not demand a cellular network or SIM card slot to work. Through its minimalistic design, the device creates its […]
Meet SmartCow’s Apollo Development Kit for Conversational AI Capabilities
https://www.electronics-lab.com/meet-smartcows-apollo-development-kit-for-conversational-ai-capabilities/
NVIDIA brought Jetson Xavier NX with supercomputer performance to edge locations delivering up to 21 TOPS to run neural networks in parallel and process data from several high-resolution external sensors. To  take advantage of the NVIDIA Jetson Xavier NX, many manufacturers developed custom hardware for AI and NLP applications that could be deployed at edge […]
Orange Pi 4 LTS – An optimized version of the original Orange Pi 4
https://www.electronics-lab.com/orange-pi-4-lts-an-optimized-version-of-the-original-orange-pi-4/
Shenzhen Xunlong released its new board design Orange Pi 4 LTS, with almost the same specifications and layout as Orange Pi 4 but with minor changes. It is considered to be an optimized version of the original Orange Pi 4 integrated with readily available components while keeping the prices fairly reasonable. Built around the Rockchip […]
iWave Systems launches iW-G39RH – The Rugged HMI series designed to withstand extreme and tough operating conditions
https://www.electronics-lab.com/iwave-systems-launches-iw-g39rh-the-rugged-hmi-series-designed-to-withstand-extreme-and-tough-operating-conditions/
Increased interaction between humans and machines has led to an increased requirement for rugged solutions and displays for Industry 4.0, automation, and automotive applications. iWave Systems is excited to launches iW-G39RH: A rugged HMI solution catering to this requirement. Powered by the i.MX 8M Mini application processor from NXP, The HMI solution delivers an unrivaled […]
