96Boards launched B-96AI & TB-96AIoT – their First Systems-on-Module (SOM)
https://www.electronics-lab.com/96boards-launched-b-96ai-tb-96aiot-first-systems-module-som/
Linaro announces 96Boards System-on-Module (SOM) Specification and Rockchip powered compute SOM design. At the first day of Linaro Connect Bangkok 2019, 96Boards SoM specifications have been announced, together with the introduction of Rockchip RK3399Pro powered TB-96AI and Rockchip RK1808 based TB-96AIoT, which are the first 96Boards compliant SoMs, along with 96Boards SoM Carrier Board. 96Boards […]
Type 1LV – Lowest power WiFi/Bluetooth module opens new applications
https://www.electronics-lab.com/type-1lv-lowest-power-wifi-bluetooth-module-opens-new-applications/
Type 1LV is a small and high performance module based on Cypress CYW43012 combo chipset which supports WiFi 802.11a/b/g/n + Bluetooth 5.0 BR/EDR/LE up to 72.2Mbps PHY data rate on Wifi and 3Mbps PHY data rate on Bluetooth. 2Mbps LE PHY is also supported. The WLAN section supports SDIO v2.0 SDR25 interface and the Bluetooth […]
New Artix-7 FPGA Board with M.2 Interface Fits in a Laptop
https://www.electronics-lab.com/new-artix-7-fpga-board-m-2-interface-fits-laptop/
The Aller board is specifically designed for development and integration of FPGA based accelerated features into other larger designs, it can be used with laptops, desktops, and servers featuring standard 2280 M.2 form factor M-key slot. Nowadays, most of the new laptops come with M.2 M-key slots for NVMe storage modules and Aller can be […]
High Precision Solder Paste Stencil Printer
https://www.electronics-lab.com/high-precision-solder-paste-stencil-printer/
This is the most traditional size and classic high precision Solder Paste Stencil Printer for PCBs. The platform can be rotated 30 degrees at most, and the precision can be kept all the way when repeat works. Easy to locate PCB board, high flexibility ensure high printing precision.The brackets using the bolt bar to adjust […]
Win a Texas Instruments Evaluation Module!
https://www.electronics-lab.com/win-texas-instruments-evaluation-module/
Presenting the Texas Instruments Evaluation Module Giveaway Here’s your chance to take home a Texas Instruments DUAL-DIYAMP-EVM. This “break apart” EVM has several popular op-amp configurations, including amplifiers, filters, stability compensation and other signal conditioning circuits that require two amplifiers. Build anything from a simple amplifier to complex signal chains by combining different configurations. To […]
Seco “SBC-C43” Module Features Cortex-A72 enabled i.MX8.
https://www.electronics-lab.com/seco-sbc-c43-module-features-cortex-a72-enabled-mx8/
Seco is developing a 3.5-inch “SBC-C43”, which runs Linux or Android on an up to hexa-core i.MX8, offering up to 8GB soldered DDR4 and 32GB eMMC plus WiFi/BT, 2x GbE, 3x USB, HDMI 2.0 in and out, 2x M.2, and -40 to 85°C support. Seco’s 3.5-inch SBC enables soldered memory and optional industrial temperature support. […]
Allwinner H5 SBC is loaded with WiFi, BT, LTE, GPS, and triple CSI
https://www.electronics-lab.com/allwinner-h5-sbc-loaded-wifi-bt-lte-gps-triple-csi/
Introducing one of the smallest, most upgrade-able, most complete SBC’s on the market sporting the Allwinner H5, the Prime Series 1. The H5 Quad Core SOM (System on a Module) in our dev kit is perfect for makers and developers. The SOM Module is loaded with features and the complete kit makes those features easier […]
First COM Express Type 7 Module with Intel Atom C3000 Processor
https://www.electronics-lab.com/first-com-express-type-7-module-intel-atom-c3000-processor/
MSC Technologies Presents First COM Express Type 7 Module with Intel Atom C3000 Processor for Server Applications Stutensee, Germany – MSC Technologies, the technology brand of Avnet Integrated Solutions, presents the MSC C7B-DV, its first COM Express™ module in accordance with the new Type 7 standard, at the embedded world 2018 in Hall 2, Booth […]
Qualcomm Unveils Snapdragon 855 Hardware Development Kit (HDK)
https://www.electronics-lab.com/qualcomm-unveils-snapdragon-855-hardware-development-kit/
Snapdragon 855 is a popular, high-end processor that is found in premium smartphones such as Samsung Galaxy S10 or Xiaomi Mi 9. Recently Snapdragon 855 Mobile Hardware Development Kit appeared on Qualcomm developer website. The Qualcomm® Snapdragon™ 855 mobile hardware development kit (HDK) is a highly integrated and optimized Android development platform designed for technology […]
Odroid-N2 SBC launches at $63 with new Cortex-A73 SoC
https://www.electronics-lab.com/odroid-n2-sbc-launches-63-new-cortex-a73-soc/
ODROID-N2 is a new generation single board computer that is more powerful, more stable, and faster performing than ODROID-N1. The main CPU of the N2 is based on big.Little architecture which integrates a quad-core ARM Cortex-A73 CPU cluster and a dual core Cortex-A53 cluster with a new generation Mali-G52 GPU. Thanks to the modern 12nm […]
