Pironman 5-Max PC Case for Raspberry Pi 5 Features Dual NVMe, Hailo-8L Support, RGB Fans, and 0.96-inch OLED
SunFounder has recently unveiled a new PC case named as the Pironman 5-Max for the Raspberry Pi 5, supporting Hailo-8L AI Accelerator PWM Tower Cooler. Pironman 5-Max is an update of the Pironman 5 tower PC case for the Raspberry Pi 5 with a new sleeker design made of black aluminium and semi-transparent black acrylic panels.
Pironman 5-Max Raspberry Pi 5 PC Case
Featuring a dual NVMe PiP expansion board for two M.2 NVMe SSDs with NAS RAID 0/1 configuration support, Hailo-8L AI Accelerator, a PCIe Gen. 2 switch, PWM [Pulse-Width Modulation] tower cooling, dual RGB fans, dual transparent panels with programmable RGB lighting, and a 0.96-inch smart OLED display with vibration wake-up or tap-to-wake-up, the Pironman 5-MAX turns the Raspberry Pi 5 into a miniature gaming desktop.
Pironman 5-Max specifications:
  • Designed for Raspberry Pi 5 and compatible SBCs
  • Storage:
    • Dual M.2 NVMe SSD slots (2230/2242/2260/2280)
    • PCIe 2.0 x1 lanes (limited by onboard switch)
    • Supports RAID 0/1 for NAS applications
    • Spring-loaded microSD card slot
  • Display and Video:
    • 2x full-size HDMI outputs
    • 0.96-inch OLED screen with CPU temp, usage, IP, RAM, disk stats
    • Vibration-triggered OLED wake with auto sleep support
  • Networking:
    • Gigabit Ethernet (RJ45)
    • Wi-Fi 5 and Bluetooth 5 (via Raspberry Pi 5)
  • USB:
    • 2x USB 3.0 ports
    • 2x USB 2.0 ports (from Raspberry Pi 5)
  • Expansion:
    • External 40-pin GPIO header with labeled pins
    • 2x M.2 PCIe 2.0 x1 slots for SSDs or Hailo-8L AI modules
  • Misc:
    • 4x WS2812 addressable RGB LEDs
    • IR receiver for media control
    • Safe shutdown support via metal power button
    • Camera FPC cable slot
    • RTC battery support
    • Dual programmable RGB LED fans
    • PWM-controlled tower cooler
  • Power: 5V/5A input via USB-C power supply
Pironman 5-Max Raspberry Pi 5 PC Case specifications 1
In terms of software, Pironman 5-Max PC Case supports Raspberry Pi OS, Ubuntu Desktop/Server 24.04, and Home Assistant. Applications include Home Assistant hubs and boost the performance of AI edge computing devices.
Pironman 5-Max Raspberry Pi 5 PC Case specifications 2
SunFounder has opened pre-orders for the Pironman 5-MAX on its website at $71.24, or a 25% early bird discount over the regular $94.99 price tag; the Raspberry Pi is not included for that price, but can be added alongside NVMe storage, camera modules, AI accelerators, and a power supply as optional extras.
2 Comments
welldonepower
A good computer case will allow the computer room to dissipate heat better, and the IT transformer will also protect the computer room.
Fenhar
High-quality FR-4 can be used as the PCB substrate for computer hosts.
