This is a digital clock project based on an ATtiny26 microcontroller, displaying time on four seven segment LEDs. The seven segment LEDs glow bright white and are multiplexed through PORTB pins, whereas the segments are driven by PORTA pins. The time is normally shown in hh.mm format but it can be switched to display mm.ss too. The time setting can be done with two push button switches. [via]
AVR digital clock with white seven segment LED display – [Link]
