EDATEC ED-IPC3100: Raspberry Pi CM5 and Broadcom BCM2712-Based Industrial Computer with 4G LTE and 4K HDMI
The EDATEC ED-IPC3100 industrial computers feature a durable metallic case designed to withstand external shocks and support DIN-rail installation. Built around the latest Raspberry Pi Compute Module 5 (CM5) powered by the Broadcom BCM2712 SoC, the ED-IPC3100 offers advanced connectivity options, including dual-band 2.4GHz/5GHz Wi-Fi, Bluetooth, and 4G LTE.
Raspberry Pi Industrial Computer
The system provides up to 16GB LPDDR4 RAM and 32GB eMMC storage, with additional support for a Micro SD card and a SIM card slot. A Micro USB port is available for flashing the system to eMMC, and storage can be expanded via an M.2 NVMe SSD slot. The device also includes an HDMI Type-A port compatible with the HDMI 2.1 standard, enabling 4K resolution displays at 60Hz.
Designed for industrial applications, the ED-IPC3100 supports a 9V to 36V input range and comes with a 12-pin 3.5 mm pitch Phoenix terminal with an I/O isolator. It features four isolated RS232/RS485 COM ports, equipped with electrostatic and surge protection for reliable communication in demanding environments.
The EDATEC ED-IPC3100 industrial computers specifications:
  • System-on-Module (SoM): Raspberry Pi Compute Module 5 (CM5)
  • Processor: Broadcom BCM2712 SoC
    • Quad-core Cortex-A78 (ARM v8) 64-bit @ 2GHz
    • VPU: H.265 (HEVC) up to 4Kp60 decode
    • GPU: OpenGL ES 3.1 & Vulkan 1.2
  • Memory:
    • 2GB, 4GB, 8GB, or 16GB LPDDR4-4267 SDRAM
  • Storage:
    • Up to 64GB eMMC storage
    • Micro SD card slot for storage expansion
    • M.2 NVMe SSD options: 128GB, 256GB, or 512GB
    • 4KB EEPROM storage
  • Display:
    • 1x HDMI Type-A port (HDMI 2.1) supporting 4K resolution at 60Hz
  • Networking:
    • 1x Gigabit Ethernet RJ45 port
    • 1x 10/100M Ethernet RJ45 port
    • Optional Wi-Fi 5 (802.11 a/b/g/n/ac) and Bluetooth 5
    • 4G LTE via Quectel EC20/EC25 mini PCIe module with Nano SIM card slot
    • 2x optional SMA connectors for antennas
  • USB Ports:
    • 2x USB 2.0 ports (Type-A, 5-pin, 1.5mm pitch)
    • 1x Micro USB port for flashing OS to eMMC
  • Expansion:
    • 40-pin GPIO header (Raspberry Pi-compatible, 2×20-pin, 2.54mm pitch)
    • 10-pin GPIO header with 8 GPIOs (2×5-pin, 2.54mm pitch)
    • M.2 Key-B connector for 2030/2242 SSDs
    • 4x isolated RS232/RS485 COM ports (12-pin Phoenix terminal) with electrostatic and surge protection
  • Additional Features:
    • Reset button, system and user LEDs, UART status LEDs
    • Real-Time Clock (RTC) with 1F SuperCAP backup and CR1220 battery holder
    • ATECC608 encryption chip for secure authentication
    • Watchdog timer (software under development)
  • Power Supply:
    • Input: 9V–36V via 2-pin Phoenix terminal or optional PoE
    • Output: 1x 5V DC/1A, 3x 12V DC/1A (up to 24W consumption)
  • Mechanical:
    • Dimensions: 143 mm x 100 mm x 35–55 mm
    • Weight: 750g
  • Environmental:
    • Operating Temperature: -25°C to 60°C
    • Storage Temperature: -25°C to 60°C
    • Humidity: 5%–95% (non-condensing)
EDATEC ED-IPC3100 Raspberry Pi CM5 industrial computers block diagram
Previously, we have covered various industrial computers, including the EBOX-58E, EBOX-58, and POC-40. We have also reviewed industrial SBCs like the ASUS X7433RE-IM-A, GENE-EHL7, CT-MCL01, and ECM-3455J, among others. Feel free to explore these articles if you’re interested.
EDATEC provides Raspberry Pi OS 32-bit/64-bit (Desktop/Lite) for the Raspberry Pi CM5-based industrial PCs. Apart from the Raspberry Pi CM4 being replaced by a CM5, the specifications for the ED-IPC3100 industrial computers look identical to the ones for the ED-IPC2100 family.
At the time of writing, the company has not disclosed pricing details for the EDATEC ED-IPC3100. For more information, please refer to the product page and the documentation page.
