Join the Community
Main Menu
Forlinx RK182X AI Computing Card Offers Up to 20 TOPS
pSemi Launches Monolithic 2.4 GHz Front-End Modules for IoT Radios
Realtek RTL8773J Bluetooth 7 SoCs Combine Quad-Core CPU and AI Audio
NXP FRDM-IMXRT1186 Development Board Targets Industrial Automation and Real-Time Control
Analog To Digital Conversion - Sampling and Quantization
Temperature Sensors
The M.2 AI Computing Card supports offline 3B–7B LLMs and VLMs, with up to 5GB DRAM and PCIe 2.1 connectivity for Rockchip p...
The PE566212 and PE566213 fold a power amplifier, low-noise amplifier, and switch into a 1.8 mm square package for Bluetooth,...
Designed for TWS earbuds and wearables, this multi-core IC integrates advanced DSPs and AI accelerators to deliver...
Featuring dual Cortex-M7 and Cortex-M33 cores, dual Gigabit Ethernet with TSN, and EtherCAT support, the board targets industrial...
A new single-output unit crams 600W into a board barely over an inch tall, with three cooling routes and approvals spanning...
Featuring an STM32N6 MCU, Wi-Fi 6, Bluetooth 5.3, and 4MP imaging, this compact camera supports embedded AI vision and...
Built on TSMC's 3nm process, the new octa-core SoC combines Arm Cortex-X925 CPU cores, Immortalis-G925 graphics, Wi-Fi 7, and...
Four benchtop models pair low phase noise with pulse and analog modulation, an optional precision reference, and external IQ...
Targeting edge AI, this compact 90x70mm board combines an octa-core Cortex-A53 CPU, up to 16GB LPDDR4X RAM, NVMe and SATA...
A four-channel silicon beamformer that drives front-end modules directly, shrinking the external circuitry phased-array designers...
The new compact touchscreen HMI panel and 47 × 114 mm SBC combine a 1.1 TOPS NPU, industrial interfaces, wireless connectivity, ...
The $43.80 development board combines Nordic nRF52840 Bluetooth, DW3000 UWB ranging, an OLED display, and multi-anchor...
