Helix 521-PLC Fanless Edge Controller Runs CODESYS on Intel Core Ultra
OnLogic’s Helix 521-PLC combines Intel Core Ultra processing, up to 96GB DDR5 memory, 2.5GbE networking, and industrial I/O for m...
Infineon Adds Post-Quantum Security to Quad-Motor Control MCUs
The new PSC3M/P6 controllers run up to four brushless DC motors from a single Arm Cortex-M33 core and verify firmware with...
HPMicro HPM5100 MCU Series Brings 480 MHz RISC-V and 16-bit ADCs
Featuring 416 KB SRAM, 1 MB flash, integrated analog peripherals, USB 2.0 OTG, CAN FD, and 32 PWM channels for motor control.
What Is DECT NR+? Examining the New 5G Non-Cellular Mesh Standard
DECT NR+ shares a name with cordless phones but not their design.
Microchip MTCH3380P and MTCH3240P Touch Controllers Offer Parallel Sensing
The new capacitive-touch controllers support up to 64 keys, with enhanced noise immunity, glove support, and sensing through...
ICs by Sayantan Nandy
Firehat Is an Open-Source FireWire DV Capture HAT for SBCs with PCIe FFC
The open-source Firehat HAT brings a VIA VT6315N FireWire controller, DV/HDV capture, and onboard controls to PCIe-enabled...
Microchip Debuts 20A Radiation-Tolerant GaN Point-of-Load Converter
A surface-mount module for space-bound processors, the POL-05-20S-T steps 4.75V–13.2V rails down to as little as 0.7V while t...
Renesas RZ/G3L and RZ/G3SE 64-bit Microprocessor Units Target HMI and IoT Edge Devices
The 64-bit MPUs feature Arm Cortex-A55 cores, a Cortex-M33 coprocessor, low-power standby, and security features for industrial...
Orange Pi Zero 4 SBC Packs Allwinner A733 SoC and 3 TOPS NPU
The compact Orange Pi Zero 4 features up to 16GB RAM, 4K dual-display output, Gigabit Ethernet, Wi-Fi 6, and PCIe 3.0 expansion.
Nuvoton Smart Buzzer IC Pairs Voice Playback With Piezo Driving
The NSP2340BA24E packs Flash storage, a boost stage, and a Class-AB amplifier into one TSSOP-28 chip, letting designers swap bare...
Forlinx RK182X AI Computing Card Offers Up to 20 TOPS
The M.2 AI Computing Card supports offline 3B–7B LLMs and VLMs, with up to 5GB DRAM and PCIe 2.1 connectivity for Rockchip p...
pSemi Launches Monolithic 2.4 GHz Front-End Modules for IoT Radios
The PE566212 and PE566213 fold a power amplifier, low-noise amplifier, and switch into a 1.8 mm square package for Bluetooth,...
