Nuvoton Smart Buzzer IC Pairs Voice Playback With Piezo Driving
The NSP2340BA24E packs Flash storage, a boost stage, and a Class-AB amplifier into one TSSOP-28 chip, letting designers swap bare...
Forlinx RK182X AI Computing Card Offers Up to 20 TOPS
The M.2 AI Computing Card supports offline 3B–7B LLMs and VLMs, with up to 5GB DRAM and PCIe 2.1 connectivity for Rockchip p...
pSemi Launches Monolithic 2.4 GHz Front-End Modules for IoT Radios
The PE566212 and PE566213 fold a power amplifier, low-noise amplifier, and switch into a 1.8 mm square package for Bluetooth,...
Realtek RTL8773J Bluetooth 7 SoCs Combine Quad-Core CPU and AI Audio
Designed for TWS earbuds and wearables, this multi-core IC integrates advanced DSPs and AI accelerators to deliver...
SoC / SiP by Debashis Das
NXP FRDM-IMXRT1186 Development Board Targets Industrial Automation and Real-Time Control
Featuring dual Cortex-M7 and Cortex-M33 cores, dual Gigabit Ethernet with TSN, and EtherCAT support, the board targets industrial...
Vox Power EIRE600 Open-Frame AC-DC Supply Delivers 600W in 1.1 Inches
A new single-output unit crams 600W into a board barely over an inch tall, with three cooling routes and approvals spanning...
CamThink NeoEyes NE302 Is a Compact 600 GOPS Edge AI Camera
Featuring an STM32N6 MCU, Wi-Fi 6, Bluetooth 5.3, and 4MP imaging, this compact camera supports embedded AI vision and...
MediaTek Dimensity CX C10 Max Octa-Core SoC Targets Googlebooks
Built on TSMC's 3nm process, the new octa-core SoC combines Arm Cortex-X925 CPU cores, Immortalis-G925 graphics, Wi-Fi 7, and...
Siglent’s SSG3000X Plus Generators Cover 9 kHz to 3.2 GHz
Four benchtop models pair low phase noise with pulse and analog modulation, an optional precision reference, and external IQ...
OrangePi O1 SBC Features Sophgo BM1688 with 16 TOPS TPU
Targeting edge AI, this compact 90x70mm board combines an octa-core Cortex-A53 CPU, up to 16GB LPDDR4X RAM, NVMe and SATA...
SoM / CoM by Debashis Das
Qorvo QPX0252 Targets Crowded X-Band Radar Arrays
A four-channel silicon beamformer that drives front-end modules directly, shrinking the external circuitry phased-array designers...
SECO Launches Industrial HMI and SBC Powered by Dragonwing IQ-2390
The new compact touchscreen HMI panel and 47 × 114 mm SBC combine a 1.1 TOPS NPU, industrial interfaces, wireless connectivity, ...
Displays by Debashis Das
