SparkFun GNSS Timing Breakout Delivers 5ns Precision With ZED-F9T-20B
Built around the u-blox ZED-F9T-20B, this GNSS timing board supports multi-band GNSS, USB-C, Qwiic, and programmable timing outputs for precision applications.
SparkFun GNSS Timing Breakout Board
SparkFun has introduced the SparkFun GNSS Timing Breakout, a precision timing development board built around the u-blox ZED-F9T-20B GNSS receiver. The board targets applications that require highly accurate timing instead of precise positioning, including 5G infrastructure, distributed sensor networks, precision industrial systems, and high-accuracy NTP servers.
The SparkFun GNSS Timing Breakout achieves up to 5ns timing accuracy in absolute timing mode under open-sky conditions without requiring external GNSS correction data. The receiver supports multiple satellite constellations and frequency bands to improve timing stability and reliability. SparkFun also equips the board with USB-C, Qwiic connectivity, SMA connectors, and an onboard backup battery for fast startup.
Previously, we covered several GNSS development boards, including the SparkFun ZED-F9R GPS Pi HAT and the SparkFun GNSS-RTK L1/L5 Breakout Board. We also featured the Move-X Cicerone LoRa/GNSS Board, an Arduino MKR-compatible development board based on the MAMWLE LoRa module and the u-blox MAX-M10S GNSS module. If you’re interested in similar products, feel free to check out those articles as well.
ZED-F9T-20B block diagram
SparkFun GNSS Timing Breakout features:
  • GNSS Receiver:
    • u-blox ZED-F9T-20B multi-band GNSS timing receiver
    • Supports GPS/QZSS, Galileo, BeiDou, and NavIC constellations
    • Receives L1, L2/L5, E1/E5, and B1/B2 frequency bands
    • Galileo OSNMA support for GNSS data authentication
  • Timing Performance:
    • Up to 5ns timing accuracy in absolute timing mode
    • 2.5ns timing accuracy with GNSS correction data
    • Programmable time pulse output from 0.25Hz to 25MHz
    • Time pulse jitter of ±4ns
  • Connectivity:
    • Three SMA connectors (one antenna and two timing pulse outputs)
    • USB Type-C port for power and data
    • Dual Qwiic connectors for I2C expansion
    • Additional PTH pins for direct access to module signals
    • Default I2C address: 0x42
  • Operating Precision:
    • Horizontal positioning accuracy: 2.0m
    • Maximum altitude: 80km
    • Maximum velocity: 500m/s
  • Power Supply:
    • Operates from 5V or 3.3V input (3.3V logic)
    • Current consumption: 68mA to 130mA
    • Onboard rechargeable backup battery with RTC
    • Approximately 24-second cold start and 2-second hot start
  • Dimensions: TBD
SparkFun GNSS Timing Breakout Top and Bottom
SparkFun provides complete development resources for the board, including a hardware schematic, Eagle design files, board dimensions, hookup guide, and documentation for the ZED-F9T-20B module. Developers can configure the receiver with u-center software and integrate it into embedded projects through the SparkFun Arduino Library v3. The company also maintains a GitHub hardware repository and provides additional documentation for building high-precision GNSS systems.
Qwiic Connections
Qwiic Connections
The SparkFun GNSS Timing Breakout is available from the SparkFun online store for $314.95. The product page also includes complete documentation, hardware files, software resources, and purchasing information.
Images used courtesy of SparkFun.
