Firehat Is an Open-Source FireWire DV Capture HAT for SBCs with PCIe FFC
The open-source Firehat HAT brings a VIA VT6315N FireWire controller, DV/HDV capture, and onboard controls to PCIe-enabled...
Microchip Debuts 20A Radiation-Tolerant GaN Point-of-Load Converter
A surface-mount module for space-bound processors, the POL-05-20S-T steps 4.75V–13.2V rails down to as little as 0.7V while t...
Renesas RZ/G3L and RZ/G3SE 64-bit Microprocessor Units Target HMI and IoT Edge Devices
The 64-bit MPUs feature Arm Cortex-A55 cores, a Cortex-M33 coprocessor, low-power standby, and security features for industrial...
Orange Pi Zero 4 SBC Packs Allwinner A733 SoC and 3 TOPS NPU
The compact Orange Pi Zero 4 features up to 16GB RAM, 4K dual-display output, Gigabit Ethernet, Wi-Fi 6, and PCIe 3.0 expansion.
Nuvoton Smart Buzzer IC Pairs Voice Playback With Piezo Driving
The NSP2340BA24E packs Flash storage, a boost stage, and a Class-AB amplifier into one TSSOP-28 chip, letting designers swap bare...
Forlinx RK182X AI Computing Card Offers Up to 20 TOPS
The M.2 AI Computing Card supports offline 3B–7B LLMs and VLMs, with up to 5GB DRAM and PCIe 2.1 connectivity for Rockchip p...
pSemi Launches Monolithic 2.4 GHz Front-End Modules for IoT Radios
The PE566212 and PE566213 fold a power amplifier, low-noise amplifier, and switch into a 1.8 mm square package for Bluetooth,...
Realtek RTL8773J Bluetooth 7 SoCs Combine Quad-Core CPU and AI Audio
Designed for TWS earbuds and wearables, this multi-core IC integrates advanced DSPs and AI accelerators to deliver...
SoC / SiP by Debashis Das
NXP FRDM-IMXRT1186 Development Board Targets Industrial Automation and Real-Time Control
Featuring dual Cortex-M7 and Cortex-M33 cores, dual Gigabit Ethernet with TSN, and EtherCAT support, the board targets industrial...
Vox Power EIRE600 Open-Frame AC-DC Supply Delivers 600W in 1.1 Inches
A new single-output unit crams 600W into a board barely over an inch tall, with three cooling routes and approvals spanning...
CamThink NeoEyes NE302 Is a Compact 600 GOPS Edge AI Camera
Featuring an STM32N6 MCU, Wi-Fi 6, Bluetooth 5.3, and 4MP imaging, this compact camera supports embedded AI vision and...
MediaTek Dimensity CX C10 Max Octa-Core SoC Targets Googlebooks
Built on TSMC's 3nm process, the new octa-core SoC combines Arm Cortex-X925 CPU cores, Immortalis-G925 graphics, Wi-Fi 7, and...
