MINIX Z150 mini PCs combine Intel N150, fanless cooling, and compact design for edge applications
MINIX has introduced the Z150 series Mini PCs, offering compact, fanless designs for silent, energy-efficient performance in edge applications, personal and professional settings. Powered by the Intel Twin Lake N150 processor (up to 3.6GHz) with Intel UHD Graphics, these systems support up to 32GB DDR4 memory and offer fast storage with 256GB or 512GB NVMe SSDs, expandable up to 4TB. Both models feature Wi-Fi 6, Bluetooth 5.2, and advanced connectivity options including USB-C, USB 3.2 Gen 2, HDMI 2.1, and dual RJ-45 Ethernet ports (1G + 2.5G). Most specifications are almost similar, but let’s check them in detail.
MINIX Z150-0dB Fanless Mini PC
With a fanless design for silent operation, dual external Wi-Fi antennas, and VESA mount support, the MINIX Z150 series is considered perfect for home offices, digital signage, edge computing, and more.
Z150-0dB Specifications:
- Processor: Intel Twin Lake N150 processor (4C/4T), 6MB cache, up to 3.60 GHz, 6W TDP
- Graphics: Intel UHD Graphics @ 1000 MHz
- System Memory:
- 8GB or 16GB DDR4-3200MHz SO-DIMM (expandable up to 32GB)
- 1x DDR4 SO-DIMM slot
- Storage
- 256GB or 512GB M.2 PCIe 3.0 x4 NVMe SSD (upgradeable up to 4TB)
- 1x M.2 2280 PCIe 3.0 x4 slot
- 1x microSD card slot up to 2TB
- Video Output: 2x HDMI 2.1 TMDS, up to 3840×2160 @ 60Hz
- Audio: 3.5mm combo audio jack (headphone + mic)
- Networking:
- 1x RJ45 2.5GbE Ethernet port
- Dual-band Wi-Fi 6 (802.11ax, 2.4GHz/5GHz)
- Bluetooth 5.2
- USB Ports:
- 1x USB 3.2 Gen 2 Type-C (data only, up to 10Gbps)
- 2x USB 3.2 Gen 2 Type-A (up to 10Gbps)
- 2x USB 2.0 Type-A
- Misc:
- LED indicators: Power, LAN (Activity/Status)
- Antenna: 2x external dual-band Wi-Fi antennas
- 1x Power button
- 1x Clear CMOS button
- Power:
- Input: 12V/3A DC-IN
- Power consumption: 12W (typical), 25W (max)
- Operating Conditions:
- Temperature: 0 to 50°C
- Humidity: 5 to 85% RH (operating), 10 to 95% RH @ 40°C non-condensing (storage)
- Dimensions:
- Product: 123 x 120 x 46 mm
- Package: 200 x 100 x 60 mm
- Weight:
- Product: 0.890kg
- Package: 1.65kg
- Certifications: (Not listed)
This is the upgraded version of the MINIX Z100-0dB Mini PC we have covered previously, but quieter and faster with an N150 processor. The design and features are nearly identical for both of these Mini PCs.
MINIX NEO Z150-Aero PRD Mini PC
A DisplayPort, 8K video support, combo audio jack, and dedicated power/reset buttons are added by the MINIX Z150-Aero variant with active cooling, making it ideal for media editing and industrial use.
NEO Z150-Aero Specifications:
- Processor: Intel Twin Lake N150 Processor (4C/4T), 6MB cache, up to 3.6GHz, 6W TDP
- System Memory: 16GB DDR4-3200MHz SO-DIMM (expandable to 32GB)
- Storage: 512GB M.2 PCIe 3.0 x1 NVMe SSD (expandable up to 4TB)
- BIOS: AMI EFI x64
- Networking:
- 1x RJ45 Gigabit Ethernet port
- 1x RJ45 2.5 Gigabit Ethernet port
- WiFi 6 (802.11ax)
- Bluetooth 5.2
- Video Output:
- 1x HDMI 2.1 TMDS (up to 4K@60Hz)
- 1x DisplayPort (up to 4K@144Hz)
- 1x USB 3.2 Gen 2 Type-C with data, Power Delivery, audio, and video (up to 8K@60Hz)
- Audio:
- 1x 3.5mm combo audio jack (Mic-in + Headphone-out)
- Audio codec: SN6140 (compatible with CX11880)
- USB Ports:
- 2x USB 3.2 Gen 1 Type-A (up to 5Gbps)
- Misc:
- 1x Power button
- 1x Clear CMOS (BIOS reset) button
- BIOS: AMI EFI x64
- LED indicators for Power and LAN (Active/Status)
- Power:
- Operating Condition:
- Operating temperature: 0°C to 50°C @ 5 ~ 85% RH
- Storage temperature: -20°C to 70°C
- Humidity: 10% ~ 95% @ 40°C, non-condensing
- Dimensions:
- Product: 127 x 127 x 43 mm
- PAckage: 175 x 230 x 72 mm
- Weight:
- Product: 0.89 kg
- Package: 1.64 kg
It is almost identical to the previous version, the MINIX Z100-AERO, but more powerful and actively cooled with an N150 processor. Feel free to check this out if you want to compare both of these Mini PCs.
Both Mini PCs ship with pre-installed Windows 11 Pro, ensuring seamless multitasking and reliable performance. A power adapter, an HDMI cable, and mounting accessories for easy setup are included with each unit.
As of now, the MINIX Z150-0dB (16GB/512GB) is listed on Amazon for $226.90 with a $25 coupon applied, and it’s priced at $249.00 on the official store. Meanwhile, the MINIX NEO Z150-Aero PRD is also available on Amazon for $224.90 after the same coupon discount, while the official store lists it at $269.90.
