Banana Pi BPI-CM6 RISC-V Compute Module Features SpacemiT K1 Octa-core AI SoC with Optional IO Board for Expansion
1.044
Banana Pi is launching the BPI-CM6, an industrial-grade RISC-V-based core module designed for high-performance edge computing and embedded applications. Powered by the SpacemiT K1 octa-core 64-bit RISC-V AI CPU, it delivers up to 2.0 TOPs of AI computing power and integrates a GPU (IMG BXE-2-32@819MHz) supporting OpenGL, OpenCL, and Vulkan. It comes equipped with 8GB or 16GB LPDDR4 RAM and eMMC storage options ranging from 8GB to 128GB.
Banana Pi BPI-CM6
The module features robust connectivity and expansion capabilities, including HDMI 1.4, USB 3.0 and 2.0, MIPI DSI and CSI, SDIO WiFi/BT, PCIe 2.1 lanes, RGMII, and 10 UART interfaces. With dimensions of 40x55mm, the BPI-CM6 is designed using board-to-board connectors, similar to the Raspberry Pi CM4, for enhanced stability. It operates within a wide temperature range from -40°C to 85°C, making it ideal for harsh environments. Applications include NAS, laptops, intelligent robotics, industrial control, AI edge computing, automation, and cloud computing.
Previously, we have covered other SpacemiT K1 SoC -based boards, including the LicheePi 3A, the Bit-Brick K1, and others. Compared to those, the BPI-CM6 comes equipped with the more powerful K1 octa-core SoC and offers a wider range of I/O options.
Banana Pi BPI-CM6 specifications:
  • SoC: SpacemiT K1
    • CPU: Octa-core 64-bit RISC-V processor @ 1.6 GHz
    • GPU: IMG BXE-2-32 @ 819 MHz, supports OpenGL ES 1.1/3.2, EGL 1.5, OpenCL 3.0, Vulkan 1.3
    • NPU: 2.0 TOPS AI computing power with RV64GCVB architecture, RVA22, RVV 1.0
    • VPU: H.265 and H.264 1080p60 decoding and encoding
  • System Memory: 8GB or 16GB LPDDR4 (default: 8GB)
  • Storage: 8GB / 16GB / 32GB / 128GB eMMC 5.1 flash (default: 16GB)
  • Wireless: Supports SDIO WiFi/BT module
  • Networking:
    • 1x RGMII interface
    • Integrated RTL8211F PHY
    • Gigabit Ethernet
  • USB:
    • 1x USB 3.0
    • 2x USB 2.0
  • Display Output:
    • 1x HDMI 1.4
    • 1x MIPI DSI (4-lane)
  • Camera Interface: 3x MIPI CSI interfaces
  • Expansion:
    • 5-lane PCIe 2.1
    • 10x UART
    • Board-to-board connectors (compatible with IO board)
  • Power: P1 PMIC
  • Dimension: 40 x 55 mm
  • Operating Temperature: -40°C to +85°C
Software support is available through Linux-based distributions like Ubuntu and Debian, with system images provided via Google Drive and Baidu Cloud. Developers can access U-Boot, OpenSBI, and the Linux 6.1 kernel through Banana Pi’s official repositories. There’s also support for Bianbu Linux and OpenWrt, along with tools compatible with both Windows and Linux systems.
BPI-CM6 IO board
Banana Pi has introduced an I/O board specifically designed for the BPI-CM6 module. This carrier board offers dual Gigabit Ethernet ports, HDMI output, both USB Type-A and Type-C connectors, two M.2 M-Key slots with PCIe support, and multiple MIPI CSI interfaces. It has a compact 56x85mm footprint, includes a 12V DC power input, and features a 26-pin GPIO header. However, detailed pinout information is still pending.
BPI-CM6 IO Board Specifications:
  • Storage:
    • 1x MicroSD card slot
    • 2x M.2 M-Key slots (with 2-lane PCIe interface)
  • Networking: 2x Gigabit Ethernet RJ45 ports
  • Display Output:
    • 1x HDMI Type-A output
    • 1x MIPI DSI interface (4-lane)
  • Camera: 2x MIPI CSI interfaces (4-lane each)
  • USB:
    • 1x USB 3.0 Type-A port
    • 1x USB 2.0 Type-A port
    • 1x USB Type-C OTG port
  • Expansion:
    • 26-pin GPIO header
    • 2x M.2 M-Key sockets
  • Misc:
    • Power, Reset, and MaskROM KEY
    • RTC battery
    • RGB LED
    • BootStrap Switch
  • Power: 12V DC input (5.5/2.1mm barrel jack)
  • Dimensions: 56 x 85 mm
At the time of writing, Banana Pi has not disclosed the launch date and pricing for the BPI-CM6. However, a dedicated Wiki page is available, offering documentation, detailed specifications, and helpful resources along with a Getting Started guide for developers interested in the module.
About Debashis Das
view all posts by das
