Forlinx Embedded Partners with Allwinner to Launch the Powerful T536 SoM
1.068
FET536-C SoM
FET536-C SoM is designed SoM based Allwinner on the newly released T536 industrial-grade processor. With a 1.6GHz quad-core Cortex-A55 CPU and a 64-bit Xuantie E907 RISC-V MCU, it delivers high computational efficiency. The board supports 2TOPS NPU, secure boot, full-path ECC, AMPRT, and other advanced features. Additionally, it offers a comprehensive set of connectivity interfaces, including USB, SDIO, UART, SPI CAN-FD, Ethernet, ADC, and LocalBus, meeting diverse application requirements.
Beyond its high cost-performance ratio, the entire board is built using industrial-grade components, making it an excellent choice for data concentrators, FTU, DTU Charging Piles, Transportation Robot, Industrial Controlsystems, and other key sectors that require cost-effective yet robust solutions.
Allwinner’s New Generation High-Performance Chip
It integrates a powerful application core and an independent RISC-V MCU, supporting 2TOPS NPU, secure boot, full-path ECC, AMP, Linux-RT, LocalBus, and more. These features enhance edge machine learning applications.
Interface Rich Resources
AMP & Multi-core Heterogeneous
FET536-C incorporates a quad-core Cortex-A55 CPU and a 64-bit Xuantie E907 RISC-V MCU, supporting Linux RT, FreeRTOS, and bare-metal code. This combination ensures both high performance and real-time control capabilities.
NPU: 2TOPS Computing Power
Built-in neural processing unit (NPU) with computing power up to 2 TOPS provides Edge Computing powerful support for applications.
All Pins Are Exposed
Meets the diverse functional requirements of different products across various industries.
Supports parallel LocalBus
Supports parallel LocalBus with high data read/write speeds of 16-bit @100MHz or 32-bit @50MHz,ARMensuring convenient communication.
Security Features
ISP Greatly Improves Image Quality
Integrated ISP technology supports 8MP @30fps, WDR, and 3DNR, providing clear and accurate image data.
Continuously Updated User Documentation
Application Scenarios
With versatile functionality, it suits industries such as data concentrators, DTU, EV charging, transportation, robotics, and industrial control. Forlinx’s performance, interfaces, reliability, and support ensure fast deployment and industry leadership.
Video
more information:
