ISL91128 - A New Buck-Boost Regulator With I2C Interface From Intersil
If your application requires a changing supply voltage, then this new IC is ideal for you. Intersil announced the ISL91128, a new buck-boost regulator. The new regulator has an I2C interface to select a broad set of features including output voltage range and slew rate. This eliminates the need of f... Read More
- full (319x319)
- medium (300x300)
- medium_large (319x319)
- large (319x319)
- 1536x1536 (319x319)
- 2048x2048 (319x319)
- re_large (319x319)
- re_xmedium (319x236)
- re_medium (319x319)
- menu-24x24 (24x24)
- menu-36x36 (36x36)
- menu-48x48 (48x48)
- sendpress-max (319x319)
- woocommerce_single (319x319)
- wp_rp_thumbnail_prop (150x150)
