Magnetic Field Sensor.pdf - Electronics-Lab.com
2
Magnetic field sensor using AD22151
[Customadds id=643821] Magnetic field sensor project using AD22151 IC from Analog Devices, The AD22151 is a linear magnetic field transducer. The sensor output is a voltage proportional to a magnetic field applied perpendicularly to the package top surface. The sensor combines integrated bulk Hal... Read More
