Eero Pro 6E Tri-Band Wi-Fi 6E Router with Immersive Home 316 Platform and Qualcomm Traffic Management
1.100
The Eero Pro 6E is a Tri-Band Wi-Fi 6E router that supports 2.4 GHz, 5 GHz, and 6 GHz bands, enabling high-speed connectivity and lower latency for Wi-Fi 6E devices. It incorporates Eero’s patented TrueMesh technology to optimize network traffic and minimize drop-offs and dead zones. The router is powered by the Immersive Home 316 platform, allowing efficient management of backhaul traffic on the 6 GHz band and delivering Gigabit-class connectivity. The device supports 100+ connected devices and provides coverage for up to 6,000 sq. ft.
The Eero Pro 6E also functions as a smart home hub, integrating Alexa for managing Zigbee and Thread-compatible devices. It acts as a border router for Thread-enabled devices, ensuring seamless connectivity for smart home applications. With support for six spatial streams and 160 MHz channels, the router is optimized for emerging 6 GHz applications, making it suitable for future networking needs.
Eero Pro 6E Tri-Band Wi-Fi 6E router
Eero Pro 6E Wi-Fi router specifications:
  • Processor: 1 GHz dual-core processor
  • Memory: 1GB DDR3L RAM
  • Storage: 4GB flash storage
  • USB: Type-C USB 3.0 port
  • Networking:
    • Wi-Fi 6E Tri-band concurrent 2:2:2 (802.11ax) with 160 MHz channels in 5 GHz and 6 GHz bands
    • Supports 2×2/2×2/2×2 MU/SU-MIMO
    • Network speeds up to 2.3 Gbps (1 Gbps wired, 1.6 Gbps wireless)
    • Peak PHY rates:
      • 2.4 GHz: 574 Mbps
      • 5 GHz: 2402 Mbps
      • 6 GHz: 2402 Mbps
    • Wi-Fi generations supported: Wi-Fi 6E, Wi-Fi 6, Wi-Fi 5, Wi-Fi 4
    • IEEE Wi-Fi standards: 802.11ax, 802.11ac, 802.11n, 802.11g, 802.11b, 802.11a
    • Spectral bands: 6 GHz, 5 GHz, 2.4 GHz
    • Tri-band configuration with band steering and smart queue management
    • Channel widths: 160 MHz, 80 MHz, 40 MHz, 20 MHz
    • Up to 6 spatial streams
    • Radiated power:
      • 2.4 GHz: 31 dBm
      • 5 GHz: 31 dBm
    • Automatic channel selection
  • Security & Features:
    • Supported encryption: AES-CCMP, AES-GCMP
    • Security protocols:
      • WPA3-Personal transition mode (eero Labs feature)
      • WPA2-AES, TLS v1.2+
      • VPN passthrough, IPv6, NAT, UPnP, port forwarding, DHCP, static IP, cloud connectivity
    • Additional Wi-Fi features: WMM, Tx Beamforming, OFDMA
  • Ports:
    • One auto-sensing 2.5 GbE port
    • One auto-sensing Gigabit Ethernet port for WAN/LAN connectivity
  • Smart Home Integration:
    • Amazon Frustration-Free setup
    • Bluetooth Low Energy 5.0
    • Compatible with Alexa for smart home automation
  • Power supply: 27W external, 100-240V AC, 50-60 Hz
  • Operating temperature: 0°C to +40°C
  • Dimensions: 139 mm x 139 mm x 55.23 mm
  • Weight: 636 gm
The Eero Pro 6E is a Tri-Band Wi-Fi 6E mesh router designed to replace traditional routers, offering reliable, high-speed wireless coverage across the home. It supports 2.4 GHz, 5 GHz, and 6 GHz bands, providing reduced latency and optimal performance for modern smart homes. Powered by Qualcomm Multi-User Traffic Management technology, it efficiently balances traffic across multiple connected devices using advanced scheduling algorithms, buffering, and universal uplink data support.
The Eero Pro 6E is easy to set up with the Eero app, allowing users to configure their network and optimize device placement within minutes. Bluetooth integration further streamlines onboarding, enabling seamless connectivity and compatibility with advanced smart home applications.
Available online from the company website and Amazon, the Eero Pro 6E is offered in multiple packages:
  • 1-pack: $249.99
  • 2-pack: $399.99
  • 3-pack: $549.99
Additional details are available on the product page.
About Sayantan Nandy
view all posts by sayantan
