[Customadds id=643821] This is a low profile and small size two-channel MOSFET board that can drive loads up to 2 x 3A. The Power Supply is 5V to 14V DC. Inputs and input Enable are TTL-level signals. The Output is by default enabled and an active high signal disables the output. Parallel Operati... Read More
- full (1104x745)
- medium (850x574)
- medium_large (640x432)
- large (640x432)
- 1536x1536 (1104x745)
- 2048x2048 (1104x745)
- re_large (783x600)
- menu-24x24 (24x16)
- menu-36x36 (36x24)
- menu-48x48 (48x32)
- woocommerce_single (600x405)
- wp_rp_thumbnail_prop (150x101)
