USB bootloaders for AVR microcontrollers
Probably most proper microcontroller programming method is using a bootloader program. Because you don’t need any special programming adapters or special knowledge – you just need to connect standard cable from your PC to target board and run special program on PC which communicates with MCU bootloader program. The idea is simple.
USB bootloaders for AVR microcontrollers - [Link]
