This is a dual-output switch mode power supply reference design based on the MAX17116. The part and reference circuit can provide both negative and positive supplies to AMOLED displays. [via]
The MAX17116 includes two current-mode 1.4MHz switch mode power-supply (SMPS) regulators for active-matrix organic light-emitting diode (AMOLED) displays. The positive supply is provided by a step-up regulator with a synchronous rectifier. The negative supply is provided by an inverting regulator with a synchronous rectifier.
Dual-output DC/DC power supply for AMOLED - [Link]
