Home Blog
12 Jan 2014
obr1384_1
With a height of only 4.5 mm are new terminal blocks able to connect LED modules and LED panels aesthetically and with a maximal reliability.
There are numerous SMT connectors on the market, which are suitable for usage on LED panels but even in other applications. That´s why it´s a logic question – why just Wago 2060?
Firstly it is because of a sophisticated construction of a terminal block with a globally known and million times proven screwless spring clamp CageClampS. This clamp has an optimum pressure on a wire ideally responding to a wire diameter, i.e. the thicker wire, the bigger pressure. Also thanks to this is the max. allowed current up to 9A (!). Further, it´s possible to install solid and ferruled wires even without tools. By a simple pressing to a terminal block (for example by a screwdriver), it´s possible to insert even fine stranded flexible leads and by similar way also to disengage. Features of a clamp don´t get worse neither after multiple disengaging of a connection and they remain stable even after a long period of operation.
From other positives it´s necessary to mention a “balcony” construction of an input portion, which makes installation of wires easier and faster. Sufficiently big flat area ensures a reliable application on assembly machines (pick-n-place). And finally – an aesthetic curved shape and a white/cream color cause, that connectors are inconspicuous and they don´t disturb on a PCB.
  Terminal blocks are available in 1,2 and 3-pole version. You don’t need to be in doubt that you missed development and you still don´t know a circuit operating on 1 pole :-) – naturally the single-pole version is intended for connecting of several modules into series. A big plus is also availability of interconnecting both-sided pins enabling easy and aesthetic creation of a row (string) of several modules.
Pin spacing is 4mm and there´s also available a version with 8mm pin spacing with operating voltage of up to 600V. Connector casing is made of an advanced material (glass fibre reinforced PPA) with a very wide range of operating temperatures.
Novelty is also a newer version – Wago 2061 with up to 12A max. current. Detailed information will provide you the Wago 2060 brochure.
Wago 2060 terminal blocks don’t overtop LEDs – [Link]
