Join the Community
Main Menu
What Is DECT NR+? Examining the New 5G Non-Cellular Mesh Standard
Microchip MTCH3380P and MTCH3240P Touch Controllers Offer Parallel Sensing
Firehat Is an Open-Source FireWire DV Capture HAT for SBCs with PCIe FFC
Microchip Debuts 20A Radiation-Tolerant GaN Point-of-Load Converter
Analog To Digital Conversion - Sampling and Quantization
Temperature Sensors
DECT NR+ shares a name with cordless phones but not their design.
The new capacitive-touch controllers support up to 64 keys, with enhanced noise immunity, glove support, and sensing through...
The open-source Firehat HAT brings a VIA VT6315N FireWire controller, DV/HDV capture, and onboard controls to PCIe-enabled...
A surface-mount module for space-bound processors, the POL-05-20S-T steps 4.75V–13.2V rails down to as little as 0.7V while t...
The 64-bit MPUs feature Arm Cortex-A55 cores, a Cortex-M33 coprocessor, low-power standby, and security features for industrial...
The compact Orange Pi Zero 4 features up to 16GB RAM, 4K dual-display output, Gigabit Ethernet, Wi-Fi 6, and PCIe 3.0 expansion.
The NSP2340BA24E packs Flash storage, a boost stage, and a Class-AB amplifier into one TSSOP-28 chip, letting designers swap bare...
The M.2 AI Computing Card supports offline 3B–7B LLMs and VLMs, with up to 5GB DRAM and PCIe 2.1 connectivity for Rockchip p...
The PE566212 and PE566213 fold a power amplifier, low-noise amplifier, and switch into a 1.8 mm square package for Bluetooth,...
Designed for TWS earbuds and wearables, this multi-core IC integrates advanced DSPs and AI accelerators to deliver...
Featuring dual Cortex-M7 and Cortex-M33 cores, dual Gigabit Ethernet with TSN, and EtherCAT support, the board targets industrial...
A new single-output unit crams 600W into a board barely over an inch tall, with three cooling routes and approvals spanning...
