ASUSTOR Flashstor Gen2 NAS Offers AMD Ryzen V3C14, 12 NVMe Slots, Dual 10GbE, and 40Gbps USB4 Connectivity
The ASUSTOR Flashstor 6 Gen2 and Flashtor 12 Pro Gen2 (FS6812X) are high-performance NAS (Network Attached Storage) devices powered by an AMD Ryzen Embedded V3C14 processor with Zen 3 cores, offering efficient operation and low power consumption. Designed for data-intensive tasks, features six or twelve M.2 slots for NVMe SSDs (up to PCIe 4.0 x4), dual 10-Gigabit Ethernet ports with SMB Multichannel support, and server-grade DDR5-4800 ECC memory expandable to 64GB for enhanced stability and reliability.
These NASs are super fast! They have USB4 ports that can transfer data at 40 gigabits per second. That is very quick, even for big files like 4K videos. They are small but powerful, perfect for editing videos, creating content, or using them for enterprise applications. Advanced features like RAID support, snapshots, cloud integration, and a comprehensive multimedia center supporting photo, video, and audio streaming are included.
Additionally, the system includes a powerful surveillance feature that supports up to 72 camera channels, along with Docker compatibility through Portainer for easy application deployment. These NAS boxes are very secure, using AES-256 encryption to keep the data safe. They also have antivirus protection to stop viruses, and ECC memory to make sure your data is always correct. Their three-year warranty and extensive App Central ecosystem enhance their flexibility and reliability for professional and multimedia environments.
Previously, we have written a review of the TerraMaster F2-212, which is a compact 2-bay NAS with an ARM V8.2 quad-core processor, 1GB DDR4 RAM, and 4K video hardware, and the QNAP TS-216G NAS, which has a 64-bit Arm quad-core processor, with 4 GB RAM and an NPU for AI tasks. We have also covered some similar products including TerraMaster’s 4-bay F4-424 Pro NAS and the Storaxa, which is a combination of NAS and WiFi router, offering over 100TB of storage capacity in RAID 0, 1, 5, 6, and 10 configurations, and a blazing fast 2.5GbE & WiFi 6 home network.
The Flashstor Gen2 series operates on ASUSTOR Data Master (ADM 5.0) running Linux 6.6, which is accessible via a web interface. Additionally, it has supports for Windows 10, Windows 11, Windows Server editions (2016, 2019, 2022), macOS, UNIX, and BSD. For storage, it uses EXT4 and Btrfs for internal drives, while external drives connected through USB or Thunderbolt are compatible with multiple file systems, such as FAT32, NTFS, EXT3, EXT4, HFS+, exFAT, and Btrfs.
ASUSTOR Flashstor Gen2 NAS Specifications:
- Processor: AMD Ryzen Embedded V3C14 Quad-Core (Zen 3, 6nm)
- Memory:
- 8 GB DDR5-4800 ECC for Flashstor 6 Gen2
- 16GB DDR5-4800 ECC (expandable up to 64GB) for Flashstor 12 Pro Gen2
- Storage:
- 6x M.2 NVMe SSD slots (PCIe 4.0) for Flashstor 6 Gen2
- 12x M.2 NVMe SSD slots (PCIe 4.0 x4 support) for Flashstor 12 Pro Gen2
- Supports RAID (RAID 0, 1, 5, 6, 10), Single, JBOD, Snapshots, and MyArchive
- Networking:
- 10-Gigabit Ethernet ports for Flashstor 6 Gen2
- 2x 10-Gigabit Ethernet ports for Flashstor 12 Pro Gen2
- Single 10-Gigabit SMB Multichannel support for higher transfer speeds
- Up to 1179 MB/s / 1181 MB/s (for Flashstor 6 Gen2)
- Dual 10-Gigabit SMB Multichannel support for higher transfer speeds
- Up to 2331 MB/s / 2358 MB/s (for Flashstor 12 Pro Gen2)
- USB:
- 2x USB 4.0 Type-C (up to 40Gbps, compatible with Thunderbolt 3/4)
- 3x USB 3.2 Gen 2 Type-A (10 Gbps)
- Expandability:
- Compatible with AS5004U expansion units for additional storage
- Docker support via Portainer
- Misc:
- Efficient Cooling fan (80mm) designed for thermal dissipation with low noise
- Reset button
- Power Supply:
- for Flashstor 6 Gen2:
- Input with 90W adapter
- Operating Power Consumption: 17.9 W
- Sleep Mode Power Consumption: 1.2 W
- for Flashstor 12 Pro Gen2:
- Input with 120W adapter
- Operating Power Consumption: 32.2 W
- Sleep Mode Power Consumption: 2.8 W
- Dimensions: 308.26 x 193 x 48.3 mm
- Weight: 1.45 kg
- Temperature:
- Operating: 0°C~40°C
- storage: -20°C~70°C
- Noise Level: 18.6dB
- Humidity: 5% to 95% RH
- Certifications: FCC, CE, VCCI, BSMI, C-TICK, KCC, BIS, CCC, and UKCA
More importantly, the Flashstor Gen2 series NAS comes with an enhanced cooling system that includes two silent fans and efficient heat pipes. Consistent heat dissipation from the processor, network ports, and SSDs is ensured by this setup, maintaining optimal performance while keeping noise levels low.
The ASUSTOR Flashstor 6 Gen2 and Flashstor 12 Pro Gen2 are available on Amazon, priced at $999 and $1399 respectively. For more information, you can visit the product page or refer to the press release.
