PROJECTS AT A GLANCE
Arduino & Raspberry
Multipurpose Motor Driver Shield for OLEDUINO v2
Mini Power Monitor Shield for OLEDUINO v2 using INA219
RS485 Shield for OLEDUINO v2
Electronic Weight Scale Shield For OLEDUINO-v2
Solenoid & DC Motor Driver Shield for OLEDUINO v2
Wireless Light Level Monitor – Transmitter Unit
OLEDUINO v.2 – An Improved Arduino Compatible OLED Display
External (hardware) and timer interrupts in microPython
Laser distance sensor with OLED display and RP2040
Installing and Running MicroPython on ESP32-C3 Super Mini
A more professional delay code without sleep() in microPython
Photodiode light level detection with Arduino
Wireless Humidity and Temperature Receiver Unit – Arduino
Wireless Humidity and Temperature Transmitter – Arduino
434Mhz Wireless Receiver – LED Dimmer – Arduino Compatible
434MHz Wireless LED Dimmer Transmitter – Arduino Compatible
Smart Soldering Iron Controller – Precision Heater Controller
OLEDUINO – Arduino compatible OLED display
434Mhz Arduino Wireless Analog Sensor Data Receiver
434Mhz Arduino Wireless Analog Sensor Transmitter
Inclinometer with 17 Segment BarGraph Display
Bootloader Programmer Tool for ATMEGA328 32Pin TQFP Arduinio ISP
Bluetooth Smart LED Dimmer – 4 Channel Bluetooth ON/OFF Switch
Arduino Bluetooth Relay Switch
Arduino 8 Channels High-Side Switch
10 Minutes Timer for AC Loads
Over Current Alarm with 15 Segment Bar-Graph Display
Arduino Compatible OLED Board with 4 Channel 16-Bit ADC
8 Channel ESP32 Remote Control
2 Channel Wi-Fi Relay Module Using ESP8266 NodeMCU
Single Channel PS3 Wireless Remote ON/OFF Switch
RC Servo Movement Recorder and Player
Installation of Casa OS on Raspberry Pi
Node Red with MQTT on Raspberry Pi
Raspberry Pi time-lapse Camera Setup
Node Red with Raspberry Pi Tutorial
LilyGO TTGO T5-4.7 E-Paper Weather Station
Mini Robot Controller Using Infra-Red Remote for Small and Medium Size Robot
2.5A Bipolar Stepper Driver with Micro-Stepping, Current and Decay Control – Arduino Compatible
Arduino 4-Digit 0.5″ Common Cathode 7 Segment Display Module
Arduino 3-Digit 0.5″ Common Cathode 7 Segment Display Module
Arduino 2-Digit 0.5″ Common Cathode 7 Segment Display Module
3 Channel Capacitive Touch Sensor with I2C
Radio Remote Control LED Dimmer Using NRF24L01 – Arduino Compatible
315Mhz RF Remote Transmitter – Arduino Compatible
315Mhz RF Remote Receiver with On Board Relay – Arduino Compatible
4 Channel 315Mhz RF Remote Transmitter – Arduino Compatible
Analog Style VU Meter on OLED Display – Arduino Compatible
DC Motor Speed, Direction and Brake Control with NRF24L01 RF Module – Arduino Compatible
Single Joystick Remote Control Transmitter using NRF24L01 – Arduino Compatible
Dual Joystick RF Remote Transmitter with NRF24L01 RF module – 2 Joystick Control
8 Channel RC Servo Driver Over RF Link using NRF24L01 RF Module – Arduino Compatible
4 Channel RF Remote Transmitter using nRF24L01- Arduino Compatible
Sound to Colour Light Effects – Arduino Compatible
Precision Thermocouple Amplifier (Thermocouple to Digital Converter with Linearization – SPI Interface)
Joystick Controlled 2 x RC Servo motors – Arduino Compatible
Humidity Meter Using OLED Display – Arduino Compatible
Automatic LED Stairway Lighting – Arduino Compatible
Two Channel Smart Low-Side Power Switch for Inductive, Resistive and Capacitive Loads – Arduino Shield
PIR Motion Sensor LED Ceiling Light – Arduino Compatible
16 High Power LEDs Knight Rider Light – Arduino Compatible
LCDduino – Arduino Compatible 16×2 LCD module
Arduino Nano- Switching ON/OFF Appliances Using Infra-Red Remote (Two Channel)
Temperature Controlled RGB LED Light Stick – Mood Light
24 LEDs Bargraph Display using 74HC595 Shift Register
ThermoDuino – OLED Display Thermometer and Tiny Arduino Board
Digital Pressure Gauge 0 to 10kPa (0 to 1.75 psi) with OLED display
Low Cost Room Thermometer Using 16×2 LCD and Atmega328
Smart RGB LED Light Stick – Arduino Compatible
RGB LED Controller using Atmega328
Current Meter Using 0.96″ OLED Display
Attiny85 8-pin Arduino Programming Shield
Lead Acid Battery Voltage Monitor using ATMEGA328
Optically Isolated Analog Input Module for Arduino
DIY PCB Exposure Box using Arduino Nano
Expansion Shield – Breakout Board for Arduino Nano
Brushed DC Motor Speed and Direction Controller Using Joystick
Brushed DC Motor Controller Using Infra-Red Remote
Arduino Compatible 2-digit 7-segment Display Board for Timer/Counter
8 Channel Infra-Red Remote-Control Arduino Shield Using ULN2803
Type K Thermocouple Sensor Amplifier Arduino Shield
Optically Isolated Bidirectional I2C Shield For Arduino
8 Channel Inductive Load Driver Arduino Shield
Programming STM8S Microcontrollers using Arduino IDE
USBASP Firmware update guide
Programming the ATtiny10 with Platform.io IDE
Sensirion Gas/Temp/Humidity Sensor Kit
Using the New ATtiny Processors with Arduino IDE (ATtiny412, ATTiny1614, ATtiny3216, ATtiny1616, ATtiny3217)
Build your own 0-24V/3A Lab Power Supply with current limit
2.7A PWM Valve/Solenoid Driver Arduino Nano Shield
Sound Sensor with onboard Relay Arduino Nano Shield
PiNAS: Raspberry Pi Based Network Attached Storage (NAS)
Indoor Air Quality Monitoring System
RS485 Shield For Arduino Nano
750mA Constant Current LED Driver Arduino Nano Shield
Interfacing BMP280 Pressure Sensor Module with Arduino
Measuring Water Flow Rate and Volume using Arduino and a Flow Sensor
Arduino based Milliohm Meter with LCD display
ESP32 LoRa Sensor Monitoring with Web Server (Long Range Communication)
ESP8266 based Online Weather Widget using Wemos D1
Introduction to LoRa – Send data between two Arduino using LoRa
Video Streaming Server on ESP32-CAM
Network Clock using ESP8266 and OLED display
Arduino RFID Reader using the ArduiTouch MKR Enclosure
Battery (Lithium, NiMH, NiCd) Capacity Tester Using Arduino
Isolated Gate MOSFET Driver Based DC Motor and Solenoid Driver Arduino Nano Shiled
Isolated CAN BUS Transceiver Arduino Shield
How to use STONEtech STVC035WT-01 intelligent TFT LCD module with Arduino
YADL: Yet Another Data Logger using TI SensorTag
Program ATtiny 0-Series Chips with a Miniature UPDI Dongle
Portable Fine Dust PM10 Analyzer with Large OLED Digits
New and Improved Geiger Counter – Now With WiFi!
IoT: Log Sensor Data to Google Sheets using NodeMCU
Arduino Air Quality Meter
Tiny Reflow Controller with OLED display
Temperature Controlled FAN using ATtiny10
PHmeter – Arduino pH meter
Chirp for Arduino – Send Data Over the Air with Sound
DIY Geiger Counter With an ESP8266 and a Touchscreen
Tiny Reflow Controller with character LCD
Getting started with the new ATtiny chips – Programming the Microchip’s 0-series and 1-series ATtiny with the Arduino IDE
Using Long Range 315MHz RF Wireless Transceivers with Arduino
32 band Audio Spectrum Analyzer using OLED display and Attiny85
PC Hardware Monitor with Nokia 5110 Display and Arduino
OLED display audio VU meter – AVR/Arduino project
Arduino OLED Hygrometer and Thermometer using DHT11
SIM800L GSM module with Nokia 5110 LCD and Arduino
Isolated High Power DC Solid-State Relay Shield for Arduino
Programming STM32 Based Boards with the Arduino IDE
Raspberry Pi 4 – A Look Under the Hood and How to Make most of it
InfraRed Robot Controller Shield For Arduino Nano
Nokia 5110 LCD based Arduino Datalogger with Menu
Arduino Voltmeter using SH1106 OLED display
Arduino FM Radio Receiver with TEA5767 and a Nokia 5110 LCD display
Using a 20×4 I2C Character LCD display with Arduino Uno
Getting Started with Adafruit.io IoT Cloud Platform
Multi Sensor Shield for Arduino Nano with Light, Magnetic Field & Temperature Sensor
Li-Po/Li-Ion Arduino Charger Shield using BQ21040
Room Weather Station Using Arduino and BME280 Sensor
Getting Started with the Arduino IoT Cloud
Using ESP32’s Flash Memory for data storage
16×2 LCD Shield for Arduino Nano
Using a 16×2 I2C LCD display with ESP32
Using the BLE functionality of the ESP32
ESP32 Webserver Tutorial
Arduino Menu Tutorial with a Rotary Encoder and a Nokia 5110 LCD display
Using Interrupts with Arduino
Menu on Nokia 5110 LCD display with Arduino
Getting Started with ESP32
10 x 1W White LED Shield For Arduino Uno
Display Custom Bitmap graphics on an Arduino Touch Screen and other Arduino compatible Displays
8 RGB LED Driver Shield for Arduino Nano with Optical Defuse Sensor
Home Automation using NodeMCU (ESP8266) board
Raspberry Pi Web-Based Data logger using MySQL and PHP
NodeMCU ESP8266 WebServer Tutorial
Arduino and BMP280 Based Weather Station
8 Channel Optically Isolated I/O Shield for Arduino Nano
Programming Arduino on Visual Studio Code Editor with Platform.io or Arduino extension
ESP8266 WiFi Air Conditioner Remote Control
Use RC522 RFID module with Arduino and an OLED display – RFID lock
DIY Altimeter using a NEO UBLOX GPS module, a Color OLED and Arduino
Using the Geekcreit ILI9325 2.8″ Touchscreen display with Arduino
Color OLED SSD1331 Display with Arduino Uno
Send an email with your Wemos D1 board using a PHP script – ESP8266
NRF24L01 Based Wireless Weather Station with DHT22 and 3.2″ TFT display
3.6A Bidirectional DC Motor Driver Shield for Arduino Nano
Arduino DIY Photo Frame using ST7735 1.8″ TFT Display
DIY Arduino Uno LCD Voltmeter
2 Channel High Current Arduino Relay Shield
Using an Optical Fingerprint Sensor with the Arduino
Using the Arduino IDE’s Serial Plotter Feature
Using the ILI9481 3.5″ Color TFT Display with Arduino
Using the 433MHz RF Transmitter and Receiver with Arduino
Arduino Real Time Clock and temperature Monitor using the DS3231 RTC and 3.2″ Color TFT display
Getting Started with the NodeMCU (ESP8266 Based Development Board)
Programming Atmega328p Microcontroller with Arduino IDE
Flashing Arduino Bootloader on Atmega328p Microcontroller
Automatic ON/OFF Power Switch For Arduino
Communication Between Two Arduinos Using NRF24L01
Low-Power Arduino Weather Monitoring Station
Using Waveshare 4.3″ E-paper Display with Arduino
Infrared Thermometer with Arduino and MLX90614 Temperature Sensor
Using the SG90 Servo Motor With an Arduino
Using the 3.2″ HX8357B Color TFT Display with Arduino
Using a Soil Moisture Sensor with Arduino
Using a Hall Effect Sensor with Arduino
Color Detector Using TCS230 Color sensor and Arduino
Using the 1.44″ Color TFT display (ILI9163C) with Arduino
4 Channel Relay Shield for Arduino UNO
Arduino Real Time Clock with Temperature Monitor
MP3 player using Arduino and DFPlayer mini
Using the ST7735 1.8″ Color TFT Display with Arduino
PIC Arduino for Motor Control Projects
Arduino Button Debounce Tutorial
Displaying Customized Graphics on OLED display using Arduino
Mini Infra-Red Remote Robot Controller Shield For Arduino Nano
PIC Arduino with RS485
Arduino distance meter with Ultrasonic Sensor (HC SR04) and Nokia 5110 LCD display
Arduino Communication with an Android App via Bluetooth
RGB Led Driver Shield for Arduino Nano
Arduino UV Meter using the UV30A Ultraviolet Sensor
Simple Arduino Data Logger
Interfacing Arduino with Micro SD card Module
Driving an 8×8 (64) LED Matrix with MAX7219 (or MAX7221) and Arduino Uno
3 in 1 Temperature Sensor Shield For Arduino Nano
DIY Light (Lux) Meter using BH1750 sensor, Arduino and Nokia 5110
DAC Shield For Arduino Nano using MCP4725
Arduino Real Time Clock with DS1302 and Nokia 5110 LCD Display
Arduino (Atmega328p) on a Breadboard
Arduino Nokia 5110 Tutorial #2- Displaying Customized Graphics
DS18B20 Sensor Based Thermometer with Nokia 5110 LCD display
Photoelectric Diffuse Sensor using S8119
Arduino Breathalyzer Using MQ3 Gas sensor and OLED Display
Arduino Nano to PIC40/28 Pin Shield
Distance Measuring Sensor Shield for Arduino Nano Using GP2Y0D810Z0F
Rotary Encoder with Arduino and Nokia 5110 LCD Tutorial
2 X AA Battery To 6V Boost Converter For Arduino Nano
How to drive Nokia 5110 84×48 LCD display with Arduino
Arduino Weather Station with DHT11 and BMP180
Arduino Weather Station using DHT11
Real Time Clock and Temperature Monitor using DS3231 Module
8 Digit Numerical 7 Segment SPI Display Shield for Arduino UNO
10 LED Bar-Graph Display with Op-Amp Shield for Arduino Nano
4 Digit 7 Segment Display Shield For Arduino Nano
2 Channel Relay Shield for Arduino Nano
1Amp Constant Current LED Driver Shield for Arduino Nano
How To Program ATtiny13/ATtiny13a using Arduino IDE
Arduino Analog Thermometer With DS18b20 Module
Real Time Clock On 20×4 I2C LCD Display with Arduino
Using I2C SSD1306 OLED Display With Arduino
4Duino – An Introduction and a Weather API Demo
Wireless temperature and humidity monitor for baby’s room
Arduino LED Scroll Bar using easyEDA
EGYDuino – Arduino compatible board
BO.Duino – ATmega328 Arduino Compatible board
LED Binary Clock – Arduino Shield Compatible
Arduino Solar Day Night Controller
View All Projects
Audio
Digitally Controlled Audio Processor using TDA7440
Audio Limiter
Current-to-Voltage Converter Circuit for Audio DACs
Stereo 2-Vrms Line Driver and Headphone Amplifier
Stereo Audio Digital-to-Analog Converter Module
Voltage Controlled Amplifier with Balanced Input
Voltage Controlled Amplifier – VCA
2.1 Channel Audio Processor with Subwoofer Output
Hi-Efficient 20W Mono Class-D Audio Amplifier
Stereo Audio Processor for Home TV Audio
3D Effect Audio Processor
Phantom Powered Microphone Preamplifier – Low Noise – Professional Quality
Voice Echo Processor Module – Delay Device for Sound Effects, Echo, Reverb
Mono 2W – Switch-Mode (Class D) Audio Power Amplifier
4 x 45W Quad Bridge Audio Amplifier
Dual 105mW Headphone Amplifier with Digital Volume Control and Shutdown Mode
2.5W Stereo Audio Amplifier using LM4752
Piezo Element Amplifier for Guitar and Violin
Audio Line Receiver using INA134
Audio Line Driver using DRV135 with Balanced Output
Dual 40W Audio Power Amplifier with Mute
Hi-End Microphone Preamplifier with Variable Compression, Noise Gating and Adjustable Gain
49W BTL 4 Channel Audio Power Amplifier
Pre-Amplifier for MEMS Microphone
10W Class-D Stereo Audio Amplifier with Mute, Shutdown and Four Gain Settings
MEMS Microphone Pre-Amplifier with Compression and Noise Gating – Studio Quality Microphone Pre-Amplifier
IR Remote Controlled Motorized Potentiometer – Arduino Compatible
Low Voltage Microphone Preamplifier with Variable Compression and Noise Canceling
5 W + 5 W Dual BTL Class-D Audio Amplifier
Microphone Preamplifier – Sound Sensor
Stereo Balanced to Unbalanced Audio Converter
3W Stereo Differential Input CLASS-D Audio Amplifier with UP/DOWN Volume
Audio-Balanced Line Driver – Unbalanced Audio to Balanced Audio Converter
Headphone Amplifier For DAC Converter
Audio VU/Sound Level Meter with LM339
50W Stereo Audio Power Amplifier based on TPA3116D2
Phantom Powered Microphone Pre-Amplifier using SSM2019
Stereo volume and balance control with Rotary Encoder using MAX5440
USB Powered Audio Amplifier using MAX4298
Mini Speaker Attached Audio Amplifier using TS4871
Differential Microphone Pre-Amplifier
Low Cost/Voltage 3W Class-D Stereo Audio Amplifier for Portable Gadgets
Hi-Fi Stereo Headphone Amplifier using LME49600
Universal OpAmp Evaluation Board Using LMV321
Tiny Professional Microphone Preamplifier
High Performance Stereo Audio Amplifier using LM3886
Balanced Audio to Unbalance Converter
Voice Record/Playback module using ISD1932 or ISD1964
Low noise Mini Electret Microphone PreAmplifier
Sound to Light Effect
3W Stereo Audio Amplifier using TDA7266D
LM386 SMD Audio Amplifier Module
Light To Audio Oscillator
Voice Changer
Tiny Mic Preamplifier
1.6W Mono Audio Amplifier
10W Stereo Audio Amplifier
6.5W Stereo Audio Amplifier
Mini Stereo Audio Amplifier
5.5W – 2 Channel Audio Amplifier
14W Stereo Audio Amplifier
Mini Audio Amplifier
MIC Pre-amplifier
50W Power Amplifier with LM3886
Audio Power Amplifier with TDA2050
3 Tone Siren
20W Audio Amplifier
Voice Echo
Digitally Controlled 2.1 Channel Analog Audio Power Amplifier
60 seconds Voice Record – Playback module
3 Tone Musical Bell
12W Audio Amplifier
Voice Modulator (Sound Effects – Funny Sound)
Tape Head Pre-Amplifier
120 Seconds Voice Record – Play Back
20 Seconds Voice Record – Playback
RIAA Corrector
Cheap Audio Booster
Universal Preamplifier
Portable Audio Amplifiers
600W Audio Amplifier
5-Band Graphic Equalizer
200W Audio Amplifier
Infrared cordless Headphone Amplifier
Three Channel Audio Mixer
Active Bass & Tremble Controller
20W Audio Amplifier using LM1875
20W Bridge Audio Amplifier
Stereo tape head preamplifier using LA3161
Tiny audio amplifier using LM386
5000W Ultra Light – High Power Amplifier
2N3055 Power Amplifier
Motorola Hi-Fi power amplifier
Amplifier of Acoustic Frequencies with Preamplifier
Sound Level Meter
FET Audio Mixer
10W Mini Audio Amplifier
20 to 80 Seconds Voice Record Playback
View All Projects
Automotive
Two Channel High-Side Switch with Current Sensing
High-Current Half-Bridge for Automotive Applications
Ingition Coil Driver
3.3V Automotive Step-Down Regulator – Low-Iq, Dual-Mode
Fuel Gauge with OLED Display
Fuel Level Monitor with 15 Segments Bar-Graph Display
Lamp Flasher with Timer IC and MOSFET for Automotive Applications
Two Channel High Side Driver with Analog Sense for Automotive Applications
Ground Isolation Audio Amplifier for Automotive Applications
Motorcycle Universal Gear Indicator
Synchronized multi-spark module (SMSM) for Electronic Ignition Devices (EID)
Nite Rider Lights
Simple but reliable car battery tester
Automotive 12V to +-20V converter (for audio amplifier)
Car battery Indicator
View All Projects
Game - Robots
Bluetooth Wireless Robot Car Controller
Robotics Arm Controller using PS3 Wireless Remote
Bluetooth Robot Car Controller using ESP32
RC Radio Controlled Switch with Relay
Interactive LED Coffee Table – Arduino Compatible
POV (Persistence of Vision) – Open-Source Arduino Nano Hardware
20 Non-Contact Infrared Reflective Sensor for Line Follower Robots
Dual Forward/Reverse DC Motor Driver with Brake for Robots
20 Segment Jumbo Size SPI BarGraph Display
The Aurora Boxealis – A Color Sensing and Mirroring Project
Dual DC Motor Driver For Robot with L298
Dual DC Motor driver using two L293D
AMP – Arachnoid Mobile Platform
Church bell Controller
BitCake – Electronic Birthday Cake
Halloween Scare using 12F683 and ISD2532
Hand Steadiness Tester
Bomb Game
Motion Activated Led Dice
LED effects
6V Ultra-Bright LED Chaser
High Power LED mood Lamp
3V LED Chaser
PIC16F84A discolight effect with bass beat control
View All Projects
Light - Power Control
H-Bridge for LLC and Phase-Shifted DC-DC Converters
Isolated IGBT Half-Bridge Gate Driver Module
Under/Over Voltage and Current Protection Switch – High Current
I2C Programmable PWMs to Control a DC Motor and LED
110V – 2.5 A Floating Half-Bridge Gate Drivers with Desaturation Protection and Charge Pump
Comparator Relay Board using LMV331
Overvoltage, Undervoltage and Reverse Supply Protection Controller
Fault Protected High Side Switch
High-Voltage Isolated Half-Bridge Driver (Up to 1kV)
Intelligent High-Side Switch with Current Monitor
High Voltage SiC-MOSFET Switch with Isolated Gate Driver and Isolated DC-DC Converter
High Voltage IGBT Module, Low-side Driver with Over-Current Protection and Fault/Enable
High Current Isolated Gate Driver for IGBTs
Half-Bridge Driver with Inbuilt Oscillator
Dimmable Linear LED Controller
PWM Heater Driver
High-Voltage Half-Bridge Board with Adjustable PWM Signal Generation
Half-Bridge with Over Current Protection – 400V/1A
Half-Bridge Driver Module – 48V/5A Load
Dual Channel Voltage-to-Current (V-I) converter circuit with BJT
High Current/High Voltage OPAMP with Boost Output Current Greater Than 1A
PI Temperature Control Amplifier for Thermoelectric Cooler (TEC) Driver
Single-Channel Smart High-Side Power Switch with Programmable Current Limit
I2C DAC Controlled Electronic Load – Battery Performance Tester
Half-Bridge with Ultra-Precise Current Sense Feedback for Solenoid
Xenon Flash Tube Driver
Solenoid, Relay, Valve Driver with Current Regulation
Self-Oscillating Full-Bridge Using IRS2453
DC Electronic Load – 1A
Linear Current Source LED Driver with Dimmer Input
55V – 3A Half-Bridge Power Driver Module
Dual 2A Power Amplifier Module for TEC
Electronic DC Load using TLE2141
21-Watt Universal AC LED Driver with Accurate Average-Mode Constant Current Control
DC Solid State Power Relay with Current Feedback
Closed Loop Constant LED Light Source Using OPT101 Light Sensor and OPA569 Power OPAMP
Crowbar Circuit Using TRIAC and TL431 Precision Programmable Reference
2 Channel Smart Dual Coil Latching Relay Board – 2 Channel Bistable Relay Module
Really Large Size 7 Segment Display with SPI Interface – 8 Channel SPI Relay Board
Under Voltage Lockout Relay – Latching Voltage Monitor
LED Dimmer for Super High Brightness LEDs
Dual MOSFET Driver – Two Channel DC SSR Using MOSFETS & Gate Driver
Low-Cost LED Dimmer using LM3578
Smart Dual Coil Latching Relay Driver – Bistable Relay Module
Power-Saving PWM Solenoid Controller
High Current Half-Bridge with Over Current Shutdown
High Current MOSFET Based Power Switch with Gate Driver
4-Channel Remote Receiver Using NRF24L01 Radio Module – Arduino Compatible
12W Constant-Current LED Driver with PWM Dimming – 12V DC@1A Input
600W – 230VAC – High Voltage DC Motor Speed Controller – Heater Controller – Lamp/LED Dimmer
Low Profile 2 Channel Solid State Relay for AC Loads
Low Voltage Lead Acid Battery Disconnect board – Prevents Deep Discharge Of 12V Lead Acid Battery
High Side Switch with Input Overvoltage and Overcurrent Protection
Galvanic Isolated 8 Channel High-Side Switch (0.6A per channel)
LED Fading Effect / LED Strobe using 555
60W LED Dimmer for 12V LEDs using 555 Timer
Infrared Remote-Controlled AC Load ON/OFF switch with SSR
1A Over Current Protection Load Switch
Adjustable Constant Current LASER Diode/LED driver
12W Dimmer with Soft Start for 12V LEDs
Programmable Thermostatic Switch using AD22105
Lithium Coin Cell Charger for Rechargeable Coin Batteries
LED Lighting Effects Generator using PIC16F886
Programmable Day-Night Light Controller based on ATmega8
4 channel RS485 Remote Controller
Sound Activated LED Light With Timer
LED Based Strobe For Entertainment, Events & Warning Signals
+9V to 60V PWM 2.3A Solenoid Valve Driver using DRV101
Large Current Relay with Dual Output DC-DC Converter for Hobby CNC/Router
4 Channel Large Current Relay Board
PWM Solenoid and Valve Driver using DRV103
4 Channel RF Remote Controller
Heat Activated Cooling Fan Controller
One Channel InfraRed Remote Controller
4 Channel Relay Board
Dark Sensitive Switch – LED Light
Dark Sensitive Lamp ON/OFF Controller
Over Current Protection Switch
Isolated Digital ON/OFF Switch for AC load
AC Solid state Relay for Inductive Load
DC Output Solid State Relay
Power ON Delay Switch
AC Solid State Relay
230 VAC Timer
PWM Halogen Lamp Dimmer
Warning LED Flash Light
RF Remote DC Motor Direction Controller
Large Current Relay Driver
4 Channel Infrared Remote Module
Single Channel SMD Relay Driver
Laser Diode Driver
4 Channel Triac Board
USB Single Cell LiPoly Charger
2 Channel Relay Board
LED VU Meter with LM3916
RGB LED Disco Lights
Microcontroller based running light controller
Triac based lamp dimmer
Temperature Controlled PC FAN
Valentine LED Chaser
PicoBuck – RGB LED Driver
DC Motor Driver using L293D
Super Flux RGB LED Controller
A Very Simple Power Failure Light
Digital Impulse Relay
Infrared Toggle Switch for Home Appliances
Super Bright Led Flasher
12V Relay on 6V power supply
555 stepper pulse generator
200W Lamp Flasher
5 Lamp / LED Flash Driver
Low cost / Automatic Emergency Light
On-Off Temperature Control
Sound Level Indicator
2500W Phase Control
View All Projects
MCU Development
Getting Started with STM8S using STVD and Cosmic C Compiler
20 PIN PIC Development Board
16X2 LCD Shield with LMD18201 Motor Driver
MP3 Module & RTC DS1307 Shield For 28/40 Pin PIC Development Board
PIC Development Board for RS485 & DMX512 Applications
8 PIN PIC Development Board – PIC12F683
PIC16F 28/40 Pin Development Board
AT89SXX Development Board
40 PIN & 28 PIN PIC18F USB Development Board
40 Pin & 28 Pin dsPIC Development Board
18 PIN PIC Development Board with Header IO
PIC16F 28-pin Development Board with LCD
Atmega8 Development Board
AT89C2051 Development Stick
ATmega16/32 Development Board
Multipurpose 18 PIN (16F628A) Microcontroller development board
PIC 18F – 28 PIN PIC Development Board
ATmega64 Development Board
89Sxx Development Board
View All Projects
Microcontroller
Serial-Input, Voltage-Output, 16-Bit DAC
12-Bit – 4-Channel SPI V-OUT DAC
Teensy 4.1 Expansion Board with DC-DC Converter
Teensy 4 Expansion Board with DC-DC Converter
RC PWM Signal to Stepper Pulse Generator
16-Bit I/O Expander with Serial Interface (SPI or I2C)
Sound to RC Servo Driver v2.0 – Arduino Compatible
Getting Started with TivaWare Launchpad
4 Channel High-Speed – Robust-EMC Reinforced Digital Isolators
4 Channel SPI Interface Isolator with three Forward and One Reverse Direction Channels
SafeBee – A GPS Tracker for Beehives
6-Channel Capacitive Touch Sensor Module
ATtiny85 push-button power switching: software-only solution
USB Auto MORSE Keyer
5W High Power LED Driver with PIC12F683
6 Channel RF Remote Controller Using CC2500 RF Modules
2 Digit Kitchen Timer 00-99 Seconds or 00-99 Minutes
Flex/Force Sensor to bargraph monitor using PIC16F886
LM35 LCD Thermometer using PIC16F676
RC Signal Monitor Using Bargraph & RC Switch using Relay
8 Channel RS485 Relay Board
8 Tact Switch board for microcontroller
8 Channel Optically Isolated IO Board
7 Segment LED Based SPI Display using 74HC595
16 Channel Tiny InfraRed Remote Controller – NEC Code
2 Digit Digital Up Counter Using PIC16F1825
16 Channel InfraRed remote controller – RC5 Philips Code
4 Channel RC Servo Controller Board
6 Digit Serial Display Driver with CAT4016
PIC16F628A Programmable Digital Timer
2 Digit 99 Seconds Timer
100MHz frequency counter with PIC16F628A – LCD Display
100MHz frequency counter with PIC16F628A – LED Display
USB PIC Programmer
Analog to Digital Converter module
DTMF Module
GLCD Module
LCD Adapter Board
IO Expander Board
EEPROM Module
40 & 28 PIN PIC Development Board with ICSP interface
Frequency counter with PIC16F628A
Simple timer with PIC16F628A
USB to Serial Converter using AVR microcontroller
Original PICKIT-2 microcontroller programmer
8 Opto-isolated Relay board
CAN to USB Interface
Serial AVR and PIC programmer
miniLOG – Precision Standalone Voltage Logger
Serial 4-digit seven segment LED display
DigiPot – Rotary Encoder Digital Potentiometer
Automatic School Bell
24×6 LED Matrix Control Circuit
Open Source 3.2” TFT Smart Display
Digital & Binary clock with thermometer & hygrometer
MultiKey – One Wire Keypad
MCS08DZ60 Evaluation Board
Microcontroller Clapper Switch
LED UV exposure box
OSCCAL Value Finder
USB Low Pin Kit
3-Wire Serial LCD using a Shift Register
Learning Board for Microchip PIC12F683 microcontroller
Build your Own PCB Exposure Box with Fluorescent Lamps and Countdown System
PIC based WWVB clock
Breadboard header for ATTiny 25/45/85
MCU controlled Bluetooth automation with infrared sensor
Digital Volt and Amp Meter with Temperature Control
AquaCont – Aquarium Control
EPROM adapter for ATMEL 89 Series Flash Microcontroller
Ponyprog Circuit for ATMEL’S AVR
PlayPIC
Ponyprog Circuit for AVR & PIC16F84
PIC diode tester
View All Projects
Miscellaneous
Auto-Reset – Electronic Circuit Breaker using LT1153
Four-Channel Digital Isolator – Reinforced – High Speed – Low-Power
Unipolar-to-Bipolar Level Translator 0V to 5V Unipolar to ±10V Bipolar Converter
Isolated RS-232 to RS-485 Signaling Converter
Isolator for SPI Interface with Inbuilt DC-DC Converter
Isolated RS485/RS422 Transceiver with Integrated DC-DC Converter
Voltage Attenuator
Voltage to Current (V-I) Converter
Video Driver with Built-in 6 Channel Input Selection Switch
Wideband, High-Output-Current – Single Ended-to-Differential Line Drivers with Enable
Ultra-High-Speed, Low-Distortion – Differential-to-Single-Ended Line Receivers with Enable
Balanced Line Driver for High Speed Digital and Video Signal
SPI Programmable-Gain Amplifier with Input VOS Trim and Output OPAMP
Balanced Line Receiver for Digital Signal Over Twisted Pair CAT-5 Cable
Twisted-Pair Cable-CAT5 – Composite Video Differential Receiver Amplifier
Single-ended Video/Digital input to differential output driver (High Speed Differential Driver)
+/-10V (Dual 10V) to Single-Supply Signal Converter for ADC
4 Channel Analog Video Distribution Amplifier
3 Channel Analog Video Splitter with Video Amplifier
Isolated, Single-Channel RS232 transceiver (Isolated RS232 to UART)
Isolated Full-Duplex RS-485 Transceivers
4-20mA / ±10V Analog Input Module for PLC
3D Gesture Controlled Robotic Arm using the Seeed MGC3130 and Raspberry Pi
Simple Soft Latch Switch using Push-Button
Smart fan with face detection camera
DIY Smart Home – Control AC from anywhere with Smartphone
72 Channels Serial To Parallel Driver Board Using 74HC595 & ULN2803
High Voltage Capacitor Charger for Photo-Flash Using LT3751
3A Thermoelectric Cooler (TEC) Driver
SPI Isolation Board
50 Segment Serial Bar-Graph Display Driver
Digital Potentiometer using Optical Encoder – 10KOhms
CMOS-TTL QUADRATURE ENCODER USING LS7084
4 Channel Opto-Isolated Module Using High Speed 6N137 Optocoupler
64 Key Infrared Remote Controller using PT2222M – NEC Code
STEP/DIR SIGNAL TO CW/CWW SIGNAL CONVERTER FOR CNC & MOTION CONTROL SYSTEMS
Inductive Proximity Switch Using TCA505
8 Channel Relay Board with onboard 5V regulator
DC Motor Direction Controller with tact switches
RS232 or RS485 Module
RS232 – MAX232 Interface Module
USB to Serial converter using FTDI FT230X
One Channel Relay Driver
Electronic Toggle Switch
Dot matrix LED running display v2.0
USB to Serial converter using PL2303SA
USB to RS485 Adapter
Toggle ON / OFF Switch with a single push-button
Solar Mailbox project
MAX6953 Development board
4 channel infrared remote relays
Dual Relay Driver Board
Solid state relay switch
IR Remote Volume Controller
Audio VU meter 9 leds
Flyback Transformer Driver
Phone Busy Indicator
Phone line indicator
View All Projects
Modules
Versatile Link Fiber-Optic Receiver
Versatile Link Fiber-Optic Transmitter
TL494-Based PWM Generator Module
Isolated Analog Input Module v2
Isolated Potentiometer and Switch Module using LOC110
Isolated Analog Control with Potentiometer
Push-Pull Voltage Mode PWM Controller
I2C Real-Time Clock module with DS3231M
4 Channel Optically isolated board with DC-DC converter
INA122 Single Supply Micropower Instrumentation Amplifier Module
16-Bit, 500ksps, ±5V SAR ADC with Internal Reference
10 Channel Analog-To-Digital (ADC) Converter – 32bit
8 Channel Digital – 2 Channel Analog Isolator Module
Half Bridge with Single PWM Input
Self-Oscillating Half Bridge Module
High-Voltage (180V) – High-Current (30mA) Operational Amplifier Module
2 Channel MOSFET Module
Universal Instrumentation Amplifier Module for SOIC8 Package with On-Board Reference
Universal Instrumentation Amplifier Module for VSSOP8 Package with On-Board Reference
Isolated RS-485 Transceiver with Level 4 EMC and Full ±42 V Protection
Easy Prototype Board for SOIC8/MSOP8/SOT23-3/4/5/6 Packages
Carrier Board for Advanced Phase-Shift PWM Controller UCC3895
3 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed)
4 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed)
2 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed)
4 Tactile Switch Breakout Board
USB 10-digit Seven Segment Display Module
LED Based Large Size 7 Segment Display
Proto Board with On Board 10X Box Header Connector
4 Digit 7 Segment 0.5″ Multiplexed Display Module
8 Tactile Switch Board with High & Low Outputs
8 Led Output Display Module
10 Pin Box Header Connector to single Line Header
Various Modules Mic LM35 Dual Pot Single Pot EP Socket
Slide Switch Single, Dual & Three PCBs
Dual Relay Board Using SMD Components
4 Digit MultiPlexed 0.33 Inch 7 Segment Common Anode Display
View All Projects
Motor Control
TMC429 Triple-Axis High-End Motion Controller with SPI Interface
3-Phase Brushless Motor Driver
1200V Inverter Module for 3 Phase Motors up to 2KW
Smart Power Module for 3-Phase Motor – 5A
3-Phase Advance Motion Module – 400VDC – 4A
High Voltage 3-Phase Full-Wave PWM Brushless Motor Driver
3 Phase IPM Module for Small Power AC Motor
3 Phase Inverter for Low Power AC Motor
H-Bridge for High Power Brushed DC Motor with Current Sense
Position and Speed Controller for DC Motor with Incremental Encoder
16 Channel RC Servo Driver with I2C Interface
3 Phase Brushless Motor Driver using L6235
DC Motor Control Using Joystick
Joystick Stepper Motor Controller
High Power Bipolar Stepper Motor Driver with SPI Interface
DC Motor Position Control Using Potentiometer – Arduino Compatible
Programmable Step-Direction Pulse Generator for Stepper, BLDC and AC Servo Motor Drivers
Brushed DC Motor Speed Controller Using Radio Control (RC) Remote
High Power DC Motor Speed and Direction Control using RC Transmitter – Arduino Compatible
50V – 5A DC Brush Motor Driver – High Performance, High Reliability
Brushed DC Motor Driver with Integrated Current Regulation
High Performance – High Reliability 50V DC Brush Motor Driver
Linear Actuator Controller with Limit Switch to prevent Overextension and Retraction
High-performance, High-reliability Bipolar Stepper Motor Driver
3-Phase Brushless DC Sinusoidal Sensorless Fan Motor Driver
PWM Temperature Controlled FAN using TC648 and NTC sensor
DC Motor Controller using Relay and MOSFET – Arduino Interface
Low-Cost DC Motor Direction Controller with Fast Brake using 2 Relays
BLDC Motor and DC Brushed Motor Driver
Brushed DC Motor Controller Using Rotary Encoder – Arduino Compatible
8A Brushed DC Motor Driver with Adjustable Constant Current, Direction Control, Brake Control, Speed Control
Bidirectional Speed Control for DC Motors
Signal Conditioner for Sensorless BLDC Operations
Closed Loop Analog Position Control using Brushed DC Motor and Potentiometer
Development board for Brushless Motor, DC Brushed Motor, AC Motors (Pre-Driver)
600V – 30A IPM Module Carrier Board for Variable Frequency Drive (VFD)
15V to 60V – Three-Phase Brushless DC Motor Pre-Driver
Sensorless FOC 3 Phase Low Power Brushless BLDC Motor Driver
H-Bridge Motor Driver with Integrated Current Sense and Regulation using DRV8874
Motorized Slide Potentiometer Driver
20A/40V Integrated Power Module for DC Brushless Motors (BLDC)
High Power Bidirectional DC Motor Driver using IFX007T
15A 100V Isolated Half-Bridge Driver
4A PWM Controlled Unipolar Stepper Motor Driver using STK672-740
MC33035 Brushless motor driver breakout board
3.5A Unipolar Stepper Motor Driver
50V – 10A Bidirectional DC Motor Driver Using A3941
10A 400V DC Intelligent Power Module (IPM)
3 Phase AC Motor Controller
2.5A 2Phase Micro-Stepping Stepper Motor Driver
Pulse Generator For Stepper Controller Using AD654
Intelligent Power Module (IPM) Board for Brushless Motors
4 Wheel Robot Motor Driver ( 4X 3Amps LMD18201 H-Bridge)
AC Motor Speed Controller for Modern Appliances Using LS7311
Harmonic Drive & Brushed DC Servo Motor Driver
4.5A H-Bridge DC Motor Driver Module Using TB6549HQ
2X L298 Dual DC Motor Driver Board for Robots
DC Motor & Direction Controller with Brake using MC33035
2.5A Bipolar Stepper Motor Driver using A3979
High Current Discrete Half-Bridge Based on IR2104 or IR2101
5 Amp H-Bridge DC Motor Driver using MC33886
4.5Amps Bipolar Stepper Motor driver based on TB6600
Half Bridge Driver based on IR2104
AC Motor Speed Controller using U2008B
DC Motor Speed and Direction Controller using L293D
4A Bipolar Stepper Motor Driver Based on LV8727E
LMD18200 H-Bridge Module for DC Motor
L293D DC Motor Driver Module
555 Based DC Motor Speed Controller
Dual Motor L298 H-Bridge Motor Control
DC Motor IR2104 H-BRIDGE
3A Unipolar Stepper Motor Driver
DC Servo Motor Driver – Analog Closed Loop Control
RC Servo Driver 0-5V
2.5A Bipolar Stepper Motor Driver LV8772E
Unipolar 4-Phase Stepper Motor Controller
Motorized Curtain with Remote control
PIC PWM Fan controller
Simple Servo Tester
DC servo motor driver
High current bipolar stepper motor controller
Automatic Fan Controller
Simple DC motor PWM speed control
View All Projects
Oscillators - Timers
Voltage Controlled Oscillator with Isolated Output
Function Generator Using AD9833 DDS – Arduino Compatible
PWM to Voltage Converter – PWM to Voltage Output DAC
Full Wave Rectifier Using Single Supply OPAMP
Universal OPAMP Board for SMD MSOP8 Package
Universal OPAMP Board for SMD SOT23-5 Package
Universal Op-Amp Board for SMD SOIC-8 Package
Universal OPAMP Board for DIP-8 Package
Clock Multiplier – Crystal Frequency Generator using PT7C4511
Voltage-Controlled Pulse Width Modulator (PWM) – PWM Signal Generator
Multiphase Oscillator with 40% Spread Spectrum Frequency Modulation and 250Khz Output Frequency
1Khz to 20Mhz Low Power Oscillator
PWM Module with Dual Source/Sink Outputs using SG3525
7-segment Mini Clock using PIC16F628A and DS1307 RTC
DS1307 RTC SMD Module
DS1307 Real Time Clock Module
Darkroom Timer v2.0A for PCB Exposure Box
1 to 100 Seconds Timer
Long Duration Timer
Pulse generator
230V Blinking LED
Adjustable High/Low Frequency Sine wave generator
Digital Stopwatch 0-60sec
Digital Stopwatch 0-99sec using digital ICs
View All Projects
PC Related
Isolated USB Repeater – USB2.0
Cooling Fan Controller Using Temperature Sensor LM35
USB Charging Port Controller using TPS2514
PocketAdmin – Keystroke Injection Device
Parallel Port Breakout board with Buffer for CNC & Routers
Optically Isolated LPT Breakout Board for CNC & Routers
USB to UART Converter with GPIO – MCP220
RS232 to RS485 Module
XBMC USB Controller
USB Sound Card with PCM2702
8 Channel LPT relay board
An Improved Infrared Receiver with Status LED
Infrared Receiver with status led
LCD2LPT with LIRC
The 8Way Relay Board
View All Projects
Power
Synchronous Boost Converter 12V Input to 24V Output @ 2A
Simple SMPS, 85-265VAC Input with Output 12VDC @ 750mA
Step-Up DC-DC Converter – 9V Output @ 500mA
Space-Efficient 12V Boost DC-DC Regulator using LM2735X
Boost Converter 5V DC Input – 12V DC Output
Step-Up DC-DC Converter – Li-Ion battery Input to 9V output
3W Switch Mode Power Supply – 12V output
48V DC Input DC-DC Converter – 5V USB C-Type Output
Buck Converter for E-Scooters – 4.5V to 95V input – 5V output
Buck Converter 12V-76V Input, 5V DC Output
Compact DC-DC Converter with Input 24V and [email protected] Output
Isolated Power Supply with 24V Input and Dual 15V Output
Simple Photovoltaic Charger – Solar Power module with Back-Up
Multi Output Step-Down Converter – Input 18-24V and Output 3.3V, 5V, 12V
Isolated Flyback Converter with 18V-28V Input and 12V Output
Boost Converter – Input 3.3V, Output 5V@500mA
±340V DC Output, 15V DC Input, Isolated Flyback Converter
12-95V Input – 5V Output – High Voltage DC-DC Buck Converter
12-75V Input to 10V Output DC-DC Buck Converter
12V Step-Up DC-DC Converter from 1.8V to 5V Input
Phase-Shifted Full-Bridge Controller with Synchronous Rectification using UCC28950
Adjustable Current Source – 0 to 1A
48V DC Input to 12V Output DC-DC Converter
350W Power Factor Boost Converter for Inverter-Fed BLDC and PMSM Motors
Breakout Board for UCC28019 and UCC28128 PFC Controller
Continuous Conduction Mode Pre-Converters Module for Power Factor Controller
Universal Input AC/DC Switching Buck Regulator – 85V -265V AC Input – 5V/150mA DC Output
Low-Cost Boost Converter 3.3V Input – 5V Output at 250mA
Step Up DC-DC Converter 12V Output – 5V Input
9V @ 45mA Boost Converter Output with Input 2.1V to 5.5V
3.3V-5A Output DC-DC Converter with 10 to 24V Input
5V – 4A Buck Converter using NR110E
Universal AC Voltage Step-Down Power Converter – 18V DC Output From 85-265V AC Input
High Current DC-DC Converter – 12V/6A Output from 16V to 38V DC Input
24V Boost Converter from 4.5V to 20V Input
Stepdown DC-DC Converter with Current Limit
Step Up DC-DC Converter – 24V/10mA Output from 12V DC Input – Compatible to TO220 LDO
Deep Discharge Protector for 3.6V Li-Ion Battery
Breakout Board for ATX Power Supply – Benchtop Power Supply
Li-Ion/Li-Po 18650 Battery to 5V Boost Converter
1200V High-Current Half-Bridge using FAN73912
High Current Half-Bridge with Over Current & Voltage Feedback for Step Down DC-DC Converter
3V to 5V DC Output Step-Up DC-DC Converter using MAX668
DC-HV DC Converter – 200V @ 20mA Output with 12V DC Input
Multiple Output Power Source – Dual 10V (+/-10V), 5V DC, 3.3V DC from 9V Battery
6V – 2.5Ah Sealed Lead-Acid Battery Charger
3 Phase (3 Wire) EMI Filter – 480VAC
Phase-Shifted Full-Bridge PWM Controller Module – LM5046 Breakout Board
AC Voltage Zero Cross Detector
Precision Full-Wave Rectifier – Dual-Supply
12V DC @ 120mA – 1.4W Universal Input Buck Converter – 85V AC – 265V AC INPUT
Dual Output Adjustable Linear Power Supply +/-1.2V to +/-12V @ 250mA
Dual +12V/-12V @ 400mA Regulated Linear Power Supply with AC input
Dual +5 V/-5V @ 200 mA Regulated Linear Power Supply
230V AC Input – 12V Output DC Converter, Non-Isolated Buck Converter
300W Off-line Power Factor Correction (PFC) Boost Converter
3 Phase AC input – DC Output – High Voltage DC Power Supply (2KW)
High Voltage DC Power Supply for Intelligent Power Modules
Active Rectifier Controller with Reverse Protection for Battery and Solar cell
TINY DC-DC Power Module – Input 8-28V DC – Output 5V DC 1A
Programmable Frequency – Continuous Conduction Mode (CCM) – Boost Power – Factor Correction (PFC) Controller
Dual-Level Float-Cum-Boost Charger with Pre-Charge for 12V – 3 to 6Ah Sealed Lead Acid (SLA) Batteries
1.2V to 50V @ 3A – Adjustable Power Supply with 55Vdc Input
60V Input – 5V @ 50mA Output High Voltage Fixed Output Regulator
42V Input – 3.3V @ 2A Output High Voltage Step Down Regulator
65V Input to 12Vdc Output – 1A synchronous buck DC/DC converter using LM5164
1.2V to 35V @ 3A Adjustable Step-down Regulator using LM2596
+/-18V Isolated DC-DC Converter Dual Supply Output from USB 5V Power Input
High voltage Half-Bridge with Current Feedback using L6390
Photovoltaic Cell Battery Charger / Solar Cell Li-Ion Battery Trickle Charger with MPPC
0 to 10 V Adjustable Lab Power Supply with Current Control
fpx: easy USB‑C power for all your devices
12V to 24V @ 1A Step-up switching regulator using LM2585
Dual USB Host/Hub Output with Constant Current Limit/Protection
HV Nixie DC-DC Switching Power Supply
3V To 5V Boost DC-DC Converter using MAX711
0-6V @ 1.5A Adjustable Power Supply With Current Limit using LT3081
12V SLA Lead Acid Battery Charger Using BQ24450
USB (5V) to Dual Output +/-15V or +/-12V Step-Up DC-DC Converter
50V to 5V @7A Synchronous Buck (Step-down) Converter
Single 18650 LiPo Battery to 5V Boost Converter
90V to 10V @ 500mA High Voltage DC-DC buck converter
High Voltage Regulator – 48V DC Output from 125V DC Input
Multi-output Power Supply Based on LM2576HV-ADJ
60V to 5V @ 3.5A Buck converter with USB output
USB to +/-5V Voltage DC-DC switching Converter
60V to 5V DC-DC Step-Down Converter using LMR16030
24V to 48V @ 1.5A Step-Up DC-DC Converter using LM2588
24V to 36V @ 2A DC-DC step-up Converter using LM2588
2x LiPO Battery to 12V and 5V Converter
Isolated Power Supply for RS485, RS422, RS232, SPI, I2C and Power LAN
60V input to 5V – 3A output DC-DC Converter for Industrial and Automotive using TPS54360
1.2V-25V/10A Adjustable Power Supply Using Power Op-Amp
USB To 12V Boost Converter using LM2577
Programmable Power Supply Using OPA548
24-48V to 5V – 3A DC-DC Converter
15V 1A Dual Output Flyback DC-DC Converter
High Voltage-Current Half Bridge Driver Using IR2153 & IGBT
5V to Dual 12V Step Up DC-DC Converter Using LM2588-ADJ
5V @ 3A Power Supply using TPS54302
6V Lead Acid Battery Charger using BQ24450
400V – 5A Power Supply For Brushless Motor Drivers
Step Up DC-DC Converter – 12V TO 28V DC 175mA
1.2V to 35V – 1A Adjustable Regulator Board
12V TO 24V 1A BOOSTER USING LM2588 FLY-BACK REGULATOR
Constant Current Laser Diode Driver Circuit Using OPA2350 OpAmp
2.7V-4.2V input to 3.3V – 0.6A output Buck-Boost Converter using LTC3440
Dual 90V/10A Unregulated Power Supply
Dual Adjustable Regulated power supply 1.2V TO 37V DC
9 VDC Regulated Power Supply
5V to -12V Inverting Switching Regulator
5V Step Down DC-DC Converter
12V to 28V Step Up DC-DC Converter
13.8V 2A Power Supply using LM338
3.3V @ 1.5A Buck Regulator
AmpStrike – Battery Powered Bench Power Supply
5V to 12V Step Up DC-DC Converter
-5V @100mA Switched Capacitor Converter
5V to 12V @400mA Boost Converter
1.2V to 37V Regulated Power Supply – 1.2A
5V @3A Switching Power Supply
5A Adjustable Regulated Power Supply
1.2V-32V @3A Variable Switching Regulator
5V to 12V @1.2A regulated power supply using LM2587
12V @ 120mA Transformerless Power Supply
5V Symmetrical Regulated Power Supply – 1A
12V @ 80mA Transformerless Power Supply
5V @ 2A Step Down Converter using TPS54202
2.5V-4.2V input to 3.3V output – 1A Buck Boost Converter using LTC3441
1.2V to 35V DC-DC Converter
5V & 12V Regulated Power Supply
3.3V Voltage Regulator
2.4V to 5V Step Up DC-DC Converter
+/-12V Dual Power Supply
Dual Adjustable Power Supply
9V to 48V DC-DC Converter
0-30V Laboratory Power Supply
Variable Power Supply with LM7812
MCU Controlled Spot Welder
Digital Multiple Voltage Power Supply
Mini variable power supply
Charger for mobile phones
Li-Ion Charger
Lead Acid Battery Charger #2
Lead Acid Battery Charger #1
Simple 78xx Current Booster
1.2v LED Flasher – Joule thief
13.8V/40A Stabilized Power Supply
Dual Voltage Power Supply
1.2 – 15V/3A adjustable regulated power supply
Pulse Charger for reviving tired Lead Acid batteries
400VA AC Light Dimmer
3-30 V/2.5 A Stabilized power supply
0-50V 2A Bench power supply
13.8V 20A power supply
0-30 Vdc Stabilized Power Supply with Current Control 0.002-3 A
View All Projects
Projects
Audio Limiter
RS485 Light Sensor Interface Board
Precision Digital Current and Power Monitor using INA260
Load Cell Amplifier HX711 for Weigh Scale and Strain Gauge Sensor
Ultra Precision Zero Drift Current Sensor – Range Up To 12A
Dual-Channel, 0V to 76V Current-Sense Amplifier
PWM Heater Driver
Two Channel Current Sensor for High Voltage Range
AMR Angle Sensor and Signal Conditioner Module
Isolated Undervoltage and Overvoltage Detection Module
RMS Noise to DC Converter – RMS Noise Measurement
RMS To DC Converter
One Channel RF Remote Relay Switch
Thermal Mass Air Flow Sensor – Constant Temperature Anemometer
10μA-10mA Low-Side Current Sensor
Precision Switched Integrator Transimpedance Amplifier
Signal Conditioner for Piezoelectric Sensors
Capacitive Humidity Sensor to Analog Output Converter
Linear Capacitive Proximity Sensor
Voltage Attenuator
Photo Diode Amplifier
Airflow Sensor
2 Channel Ultra-Precise Current Sensor
0-1A Single-Supply, Low-Side, Current Sensor with Output 0 to 4.9V
Liquid-Level Monitoring Using a Pressure Sensor – Bar-Graph Display
Programmable Bridge Resistive Sensor Signal Conditioner
4 Channel Current Sense Amplifier – Low and High-Side Voltage Output
6A H-Bridge with PWM-DIR input and SPI Interface
12-Bit Programmable Contactless Encoder Module
Contactless Potentiometer – 12bit Rotary Position Sensor with Analog or PWM Output
8 Channel RF Remote Receiver with Holtek and Serial Protocol
8 Channel RF Remote Transmitter with Holtek and Serial Protocol
Signal Conditioning Module for Magnetic Rotary Encoder with Clock and Up/Down Direction Signal Output
Precision Thermocouple Amplifiers with Cold Junction Compensation – Temperature Range −25°C to +400°C
Magnet Based Rotary/Linear Encoder Module with Quadrature Output
Stepper Motor Based Rotary Encoder with Clock and Up/Down Direction Signal Output
Variable Over-Current Detection Load Switch
Reinforced Isolated Current-Sense Amplifier with Precision ±250-mV Input, Differential output & Integrated DC/DC Converter
Overcurrent / Over-discharge Protector for Lead Acid Batteries
Isolated Voltage-Measurement with ±1V Input, Differential Output and Integrated DC/DC Converter
Thermistor Signal Amplifier for Thermoelectric Cooler using INA330
Over Current Trip Switch – Over Current Shutdown Relay
Accurate Acoustic Sensor – Sound Frequency to Voltage Converter
Dual Variable – Reluctance Sensor Interface Module – Stepper Motor Based Incremental Rotary Encoder
Under Voltage and Over Voltage Monitor for 5V
Over Speed Sensor – Over Speed Alarm using Magnetic Pickup Sensor
Current-Sense Amplifier with Dual Over Current Level Monitor & Alert Output
Single Key Touch Sensor using LM2907
Under Speed Warning Alarm for Magnetic Pickup sensor – Frequency Controlled Switch
Frequency To Voltage Converter (Tachometer) – Variable Reluctance Magnetic Pickup to Voltage Converter
250V AC Isolated Voltage-Sensing Circuit with Single output (250V AC Input 5V Output)
Humidity Sensor – Humidity to Frequency Output
3 Phase Isolated Hall-effect Current Sense Amplifier with +/-600V Working Voltage and +/-46A Measurement Range
High Accuracy Adjustable Overvoltage and Overcurrent Protectors using MAX17561
High Accuracy Current Sensor with 400Khz Bandwidth using ACS37002
Analog Light Sensor + Light Sensitive Switch using OPT101
Liquid or Air Pressure Switch with Relay
Strain Gauge Sensor Amplifier or Single Supply Instrumentation Amplifier
Photodiode Amplifier for Visible Light Using OPA381 – Arduino Nano Shield
Reflectance based Proximity Sensor using Si1102
0 to 5V output Analog Hall Sensor for Foot Controller
Proximity Distance Sensor using DRV5053 Hall effect Sensor
Capacitive Touch Sensor Toggle Switch
Current Limit Solid State Power Switch with Latch
Window Comparator – Window Detector with relay output
Inductive Proximity Sensor using TCA505
HS101: A high quality, and Cheap DIY Oscilloscope
Instrumentation Amplifier For Pressure Sensor
Contactless Automatic Wardrobe LED Light with Fade Effect
SPI Isolation Board
Current Sensor Amplifier & Over Current Switch
Simple Pressure Sensor Amplifier & Over Pressure Switch
Dual-Channel Quadrature Hall-Effect Bipolar Switch Module for Magnetic Encoder
+/- 1.7g Dual-Axis IMEMS Accelerometer Using ADXL203
ACS714-30A Current Sensor module
Magnetic field sensor using AD22151
Thermometer 0-99C Using PIC16F1825
Bargraph Current Meter 0-1A Range – PIC16F686
Bargraph Voltmeter 0-5V DC range – PIC16F686
Lux Meter Module
230 VAC Timer
Voice Changer
Digital Panel Meter – Voltmeter
Light and Dark Sensitive Switch
USB PIC Programmer
Laser Diode Driver
Sinewave generator
4×1 WiFi Wireless Antenna Switch
Audio Oscillator with Frequency Counter
0-20V Bargraph Voltmeter
Geiger counter with SBM20 tube
DTMF Module
GLCD Module
LCD Adapter Board
IO Expander Board
EEPROM Module
12V Lead Acid Battery Voltage Monitor
0-10V Voltage Monitor
Variable Range LED Voltmeter
Colpitts Crystal Oscillator
Tiny DDS – Open source DDS generator
NiCad-NiMh Battery Monitor
Advanced LC meter
Simple LC meter
Thermocouple Type-K amplifier
Simple SMD LED tester
Low Frequency Spectrum Analyzer for Automotive Suspension Analysis
TraId – Transistor Type & Polarity Identifier
PIC16F688 Digital Voltmeter
Digital Room Thermometer
PIC16F84A Gas Detector using GH-312 sensor
DDS Function Generator
Single Chip Temperature Data Logger
Ultra High Sensitive Probe
Voltmeter + Ammeter LCD panel
Simple Crystal Tester
Transistor tester
Logic Probe Plus
Logic Probe
Led display digital Voltmeter
Mosfet Tester
Electronic Stethoscope
Plants Watering Watcher
PIR Sensor
Sound Activated Switch – Relay
IR Remote Control Jammer
Programmable Home Security Alarm System
PIR Motion Sensor
Flood Detector
IR remote extender
Simple Touch Switch
iButton electronic lock
Water Level Alarm
Li-Ion Charger
MAX2606 – Hands-Free Car Kit for Cell Phones
FM VCO Transmitter
FM Transmitter using MAX4467 & MAX2606
4 Watt FM Transmitter
Simple FM Transmitter
LED UV exposure box
OSCCAL Value Finder
USB Low Pin Kit
PlayPIC
PIC diode tester
XBMC USB Controller
LCD2LPT with LIRC
Long Duration Timer
Pulse generator
230V Blinking LED
Simple Servo Tester
200W Lamp Flasher
2500W Phase Control
Bomb Game
LED effects
3V LED Chaser
Nite Rider Lights
MIC Pre-amplifier
3 Tone Siren
20W Audio Amplifier
Voice Echo
3 Tone Musical Bell
12W Audio Amplifier
RIAA Corrector
Cheap Audio Booster
Sound Level Meter
FET Audio Mixer
View All Projects
RF Circuits
FM VCO Transmitter
View All Projects
Science
View All Projects
Sensors - Detectors
Airflow Sensor
Lux Meter Module
PIR Sensor
PIR Motion Sensor
Flood Detector
IR remote extender
Simple Touch Switch
Water Level Alarm
View All Projects
Test - Measurement
RMS To DC Converter
Sinewave generator
Advanced LC meter
Simple LC meter
Transistor tester
Logic Probe Plus
Logic Probe
Mosfet Tester
View All Projects
